  • quitcherbitchen
    flyingiceberg, I flew mine with a two blade on a stock 540kv motor using the spinner from a version 6 FMS mustang and an extended adapter from Small Parts CNC. You can't use a two blade on the 650kv motor as the prop adapter is too short and no one makes an extended adapter yet. I asked Small Parts if they were thinking of making one, but of course only if demand is there. I like mine now on the 650kv motor and stock 4 blade so I gave up on that idea.
    It worked for me, but I didn't go an overly huge sized zip tie. Right now, I'm running KV580's in mine. With 85A Mantis ESC's
  • moodg16
    Another question, on the FMS 1400 P51 V8, if I go the route of using the stock FMS 4250-KV540 Motor with 4s 3600mah 40C batteries with the zip tie prop mod, is the stock FMS 70 amp ESC sufficient or do I need a larger one?
  • moodg16
    OLWARBIRDS has some great info! At the beginning of the thread, you posted:
    "Motors: Popular 4S http://www.motionrc.com/fms-4250-kv580-motor/ nothing xtra needed..." Question, I'm planning on trying this combo using 3600 40C 4S batteries on my FMS 1450 V8 Duchess Arlene without prop mod, is the stock FMS ESC sufficient or do I need higher?
  • flyingiceberg
    Originally posted by fhhuber View Post
    Assuming you mean a hub/shaft that bolts to the motor bell...Only thing you can do is try.
    The fit has to be exact or the hub won't center properly.
    Unfortunately, the makers seem to like being 0.5mm off from each other.
    I guess I should have looked more before I leaped! The prop shaft on the T-Motor only has three screws, so the FW Old Crow prop shaft will not work.
    I left them unglued as well. Makes it much more convenient if I need to move it over long distances again. For regular transport to the field, I just leave them on.
  • flyingiceberg
    Just curious as to what people are doing with the wings? Are you leaving the wing plates unglued for easier transport? I have a truck so I can transport either way. I have a Red Tail still in the box. The Marie I have does not have the plates glued on.
  • flyingiceberg
    I ordered the parts. I will see what happens when they come in?
    This is a link to the specs on the T-Motor. http://www.hobbypartz.com/02p-motor-...530-kv570.html Not sure how to interpret them?
  • fhhuber
    Originally posted by flyingiceberg View Post
    Would I be able to use the prop shaft from the Freewing on the T-Motor with the Freewing spinner? It seems like it would be a simple mod if the prop shaft would work.
  • flyingiceberg
    Maybe a different spinner, check out True Turn or, if thats too expensive, maybe find out what the stock spinner was. If you have to put 2 1/4 oz at the tail end of the fulcrum, that's got to be one heavy spinner, or the prop maybe too heavy, a wooden prop may be better. don't know what the length of your plane is, but, for arguments sake, lets say 30 inches and your CG is at 25 inches from the tail.
    25"x 2 1/4 oz=56.25
    56.25/5"=11.61 oz
    If you need 2 1/4 oz at 25" aft of the CG, in order to balance the fulcrum, the front end of the plane, ie, the prop and spinner would have to weigh 11.61 oz. at 5" forward of the CG.
    Originally posted by F106DeltaDart View Post
    I believe some have also used this setup with the stock 4 blade for those interested in keeping the scale prop.
    I was one of those. I posted a little while back that the stock 4-blader drew a lot of amps. I'm running a 120A ESC and after about 3 or 4 full throttle runs, the ESC would cut out. You'd need something more than 120A. There seems to be a lot of drag on the stocker. The Olympus 2-blade, never a problem but it just didn't look right.
  • flyingiceberg
    What about the Freewing P-51 Old Crow spinner it's for a 2 blade prop. I did not think of it until now
    Originally posted by xviper2 View Post
    Just buy the Olympus spinner and back plate.
    On my 6s set up, I used the Olympus motor, spinner and prop.
  • wrongroad
    G'day FIB,
    I just measured the prop on the FMS Olympus [650kv donk and the model lives in my lounge room, lucky am I not???;)] and it measures at 15".
    The Mustang Measures, for the same purpose of measurement, 14 & 1/2".
    Some of the earlier V7 units came with spinners with cut outs to suit a two blade. If you can locate one of those, the Olympus prop might be an option.....I did say MIGHT!!!!:D:D
    This is one thing I have not done so it is total guess work on my behalf.
    Regards and respect
    Daryl
  • Flygirl
    Any suggestions for a spinner for a 2 blade prop?
    I have never flown this plane. I bought it from my instructor who had flown it. Not sure what changes where made before I got it.
    Measure the diameter of your current spinner and then search for Dubro two blade plastic spinners for electrics. If you have a local hobby shop they most likely will have one. If not, Tower Hobbies carries them.
  • flyingiceberg
  • Flygirl
    Thanks Delta! The FMS 650 motor is I think 276g and yeah, T-Motors are really high quality.... Iceberg, think you can change the spinner out to fit that prop?
  • flyingiceberg
    Sorry! I meant the FMS 650kv. I would need a 2 blade spinner for it since that is what it is setup for. Is the T Motor AT 3530 kv570 a good motor?
