Battleship in all honesty you could throw an entirely different turret in there if you wanted all 5 on this model are interchangeable.
Here are a few Ideas from fairly simple to Major overhaul on what you could do include
1 remove a foward turret and set up a GoPro Camera to get some first person views of your cruises (use a small mount to anchor it in the turret mounts hole)
2 you could probably take the turret you have in Nr 3 position (middle gun) move it to the broken spot and set up a small platform with a couple of AA mounts on it. You might be able to find some that fit size wise at your local model ship. Or simply fashion some out of balsa a few bits of wire and some small dowels. In WWII there was more than one ship that spent some time in odd configurations due to damage, upgrades, and/or testing. Frankly being that there is no hull number and as long as you are not a hardcore purist demanding she be exactly by historical fact in all details the best part on that is you can make up your own story about why and how she ended up like that.
3 With a little work and imagination you could probably even kit her out as a float plane tender. (DD 479 Stevens, DD 480 Halford, and DD 477 Pringle were actually kitted out before before the idea was scrapped and they were retrofitted found only a few full pics of the ships there were more but these get the point out.)
https://warfarehistorynetwork.com/20...n-the-pacific/
looks like a remove hut on aft superstructure some skewer sticks and Popsicle sticks assembled into something resembling a catapult find the right sea-plane model (OS2N Kingfisher float airplane but any float plane that fit could work in all honesty or just sail her without a plane found a pic of Halford with no plane on deck) and you'd have a couple of weeks of fun assembling a version of this ship that would be pretty unique among any of the others on the water. Do it right an she shouldn't even take much to put back. Use the same base as Nr 3 mount. Use some care when removing the aft torpedo launcher and Doghouse so you don't destroy them or the deck under them and you should even be able to pick the version you put on the water each time. Like I said before don't worry too much about paint matching they used whatever was on hand at the time.
Some of the most interesting models I've seen were actually where someone took something fictional and put one together that moved. If your a fan of Star Trek I've seen submarine versions of the Enterprise and for Star Wars a few flying X-wings and Tie Fighters. Another cool one was a Spaceship Yamamoto from a Japanese TV show. So in the end you could put anything you want into that position up to and including a teddy bear. So the only limits on what you can do to her is your imagination and what the hull can carry on the water (wouldn't suggest anything too heavy or she could get real tippy)
It is all how much time and effort do you want to put into her. And how much fun you have doing so. Frankly I only did what I did to my Fletcher because I had a blast doing it and love seeing her on the water in the Measure 32.
