Discussion: Heng Long's 1/16 scale M1A2 Abrams RTR, Upgrade Edition!
  • Woohoo\o/
    • Feb 2020
    • 186
    • Cape coral Florida
    I think I found the size bearings needed.
    od 14mm
    id 8mm
    w 4mm
    • barron06
      • 60
      • Greenville, NC
      Anyone know what the correct color is for the Abrams tank. Also, what type of paint should be used.. acrylic? Frankly, I don't like the broad dark "panel lines" and want to clean these up. If motion has plans to carry these I'm all ears.
      • Rubicon99
        • 3311
        I like enamel ModelMaster 2136 “US Gulf Armor Sand”. I prefer enamel when painting directly over the HL factory paint as it “sticks and covers” better then acrylic paints. Acrylics tend to chip and scratch easily if painted directly over factory paint. Enamel is much tougher.
        • Rubicon99
          • 3311
          od 14mm
          id 8mm
          w 4mm
          This one was pulled right from the HL bearing support housing.
ID:	240248Click image for larger version
          • Woohoo\o/
            • Feb 2020
            • 186
            This is the bearing that supports the 8mm shaft correct? Or is this bearing installed onto the gearbox itself?
            I'm trying to support this area in the pic below
            • Rubicon99
              • 3311
              That is a ZTZ99,not an Abrams. Totally different support used on the Abrams.
              • Woohoo\o/
                • Feb 2020
                • 186
                Yeah lol I'm just using it as an example sorry. So the bearing you are showing came from here right? Minus the collar shown in photo.
                • Woohoo\o/
                  • Feb 2020
                  • 186
                  I know this isn't the Abrams but this is where I place the bearing to support the shaft correct? Normally there's a brass bushing?
                  • Rubicon99
                    • 3311
                    Yes that is an older bearing mount before the one made specifically for the Abrams became available. The Abrams one is of the same style but about 1/2” longer, both use the same bearing size. The one shown is from a T90/72 and is shown installed in one of my older Abrams hulls (posted on RCU.com)
                    I still use the T90/72 bearing mounts on my older HL Abrams, M41s and M26 (not a direct fit on the M41 or M26). The new Abrams specific mounts offer a little more support for heavier metal/rubber padded track paired with higher torque motors and all metal road wheels which was a welcome sight when they first came out and only made an already tough tank even tougher.
                    • Rubicon99
                      • 3311
                      Yes that is where the bearings mount would go on the Abrams. There is no brass bushing just a plastic hole that the drive axle passes through.
                      • Rdex2
                        • 40
                        I made bearing supporter for my many tanks.This's my M 41 A3.
                        • Rdex2
                          • 40
                          Some of mine.Bearing size recommend 8x14x4 mm. and 8x16x5 mm.
                          • Woohoo\o/
                            • Feb 2020
                            • 186
                            Thanks a ton rubicon.
                            rdex2, what glue did you use? Looks fairly simple.
                            Update: yeah I've been over thinking this. I received my Abrams, did the 2 minute test all was great (great sound btw) and began taking her apart. The paint is waay too dark. Gonna paint her up.
                            Rubicon I see where the bearing goes now. Sorry for run around. I just don't understand why wouldn't they add some bearings? I would gladly pay an extra $15-20 for the added feature.
                            • Rdex2
                              • 40
                              I use 5 mm acrylic sheet to made a holder and fix with hot glue. And flange bearing size is 8X12X2.5 mm. may be use without any holder. In this clip 2.35 min show how he easy put it into a hole(see comment below).https://www.youtube.com/watch?v=8qdKRZmD62Q
                              • Woohoo\o/
                                • Feb 2020
                                • 186
                                Ok thats great. Yes I saw that video. So all I really need is a flange bearing? Will the bearing fall off easily? Or should I hot glue the bearing for extra security? Thank you.
                                • Woohoo\o/
                                  • Feb 2020
                                  • 186
                                  Here is my Abrams without decals and weathering. Just bare paint. Not exactly accurate paint as the real life Abrams but $4 camo paint sand color and 30 minutes of work and it's better than the coffee brown color.
                                  • Woohoo\o/
                                    • Feb 2020
                                    • 186
                                    Can I use 8x12x3.5 flange? The 2.5 cost $20 each 😣
                                    • Rdex2
                                      • 40
                                      The problem of 8x12x2.5 mm or 8x12x3.5 mm is real inner hole 7.9 mm and a little bit sanding shaft is necessary.
                                      • Sappo
                                        • Feb 2020
                                        • 346
                                        Gday from New Zealand, glad to have found this site. I have a m1a2, it's only a 5.3 version but I'm slowly getting it upgraded. Was given a 6.0 mfu and am just waiting on the new transmitter and wiring harness as well as the slip ring. Already have the 360 degree turret drive. The tank has had a paint job and I have made a few accessories like the drawbar on the bow and a few bed rolls, tarp and extra storage boxes for the back of the bustle rack. One thing I noticed was the way the tank bounced around going off road, my fix for that was to add lead to the front and rear of the vehicle until the suspension started to deflect, then I removed a few bits till the suspension levelled out. The lead was then melted into blocks and put back in. Oh yeah the smoke unit was pulled out, when was the last time you saw a m1 smoke. The tank now flows over obstacles like they weren't there.
                                          Sappo Kia Ora! Welcome, and thanks for the tips. I did a similar thing with my Leopard 2A6, adding adhesive lead weight to the forward hull.
