  • jetfool
    • Nov 2022
    • 1291
    • Crawfordsville, Indiana
    SoCalBobS.
    Thank you for the information. I want to paint a winter camouflage on my Tiger 1 and thought this would be a good time to install while disassembled.
    Best Regards, Rex
    • SoCalBobS
      • 2728
      • Southern California
      Go for it! I'd love to add one to my Tiger 2.
      A couple of thoughts. One, if you turn off the smoke ,which you would if you're outside or running the tank for an extended period, the flash still works. Second, as you pre-think the install, you'll want to place the smoke reservoir somewhere that it's upright and that you can access the top to refill the fluid.
      • jetfool
        • Nov 2022
        • 1291
        Thank you for the advice. Will start on my Tiger after I finish my P-47 in the airplane forum. Rex
        • RichJohnson
          • 1276
          • SoCalBobS
            • 2728
            The movie "Tanks For Stalin" depicts two prototype T-34/76's being driven to Moscow for a demo. Here's my interpretation.
            An early T34/76, showing headlight and spot light placement.
            Click image for larger version  Name:	T34-76 20.jpg Views:	0 Size:	67.9 KB ID:	418602
            A screen capture from the movie showing their spotlight.
            Click image for larger version  Name:	T34-76 19.jpg Views:	0 Size:	92.8 KB ID:	418603
            A couple of head-on shots of my tank. I relocated and added headlights, and added the spotlight.
            Click image for larger version  Name:	Screenshot 2025-01-23 083627.jpg Views:	0 Size:	196.6 KB ID:	418605
            Click image for larger version  Name:	Screenshot 2025-01-23 084128.jpg Views:	0 Size:	143.7 KB ID:	418606
            The drum style gas tanks were removed in favor of the early side fuel tanks.
            Click image for larger version  Name:	IMG_1320.jpg Views:	0 Size:	190.4 KB ID:	418607
            The turret and side tanks were 3D Printed by JVM3DConcepts from a Cults3D file.
            • Meter Rat
              • 504
              • Argyll and Bute, Scotland
              Great work, as normal Bob.
              • DavidN
                • May 2021
                • 3193
                • Los Angeles, CA
                My newly acquired Flak panther. It has the Clark TK50 board inside with the flakpanther sound programmed.
                Click image for larger version  Name:	IMG_2781AB.jpg Views:	30 Size:	319.4 KB ID:	418936 Click image for larger version  Name:	IMG_2790AB.jpg Views:	24 Size:	256.0 KB ID:	418937 Click image for larger version  Name:	IMG_2788AB.jpg Views:	24 Size:	411.1 KB ID:	418938 Click image for larger version  Name:	IMG_2793AB.jpg Views:	24 Size:	318.0 KB ID:	418939
                • Panzermechaniker
                  • Feb 2023
                  • 144
ID:	418949 Click image for larger version
ID:	418950 Click image for larger version
                  • jetfool
                    • Nov 2022
                    • 1291
                    Fantastic!
                    Not a LOVE BUG but a DEVIL BUG. LOL
                    • SoCalBobS
                      • 2728
                      I learned something at last Sunday's San Diego battle evet. We had many tanks this time, and spread out over a huge field with a lot of flora. This made it difficult to spot other tanks, since one's head had to be on a swivel. I saw the value of camouflage, something that isn't so important at a small confined field, or with fewer tanks.
                      So I'm going to try something. I have some tan netting which I draped over my Heng Long M1Abrams. I made tiny L-hooks to attach them, and I sprayed some light brown patches. It remains to be seen if it will be effective at our clay field, but I've seen pictures of real tanks in the mideast with this treatment. I'll be tinkering with this over time. Some considerations are important; the netting has to be away from the wheels, the turret has to rotate without catching the netting, and there will be inevitable snags as it maneuvers. Of course, if some gets torn off, there's more where that came from! Hopefully as time goes by the netting will start to drape
ID:	420692 Click image for larger version
ID:	420693 Click image for larger version
                      • SoCalBobS
                        • 2728
                        I didn't like the netting. I'm trying another type.
ID:	420736 Click image for larger version
                        Definitely can't drive through brush with this stuff. Dunno if I'll keep it.
                        By the way, here's an interesting color scheme:
Name:	Screenshot 2023-08-16 080019.jpg
                        • Rubicon99
                          • 3314
                          Click image for larger version  Name:	IMG_1891.jpg Views:	0 Size:	148.9 KB ID:	420736 Click image for larger version  Name:	IMG_1890.jpg Views:	0 Size:	157.0 KB ID:	420737
                          Click image for larger version  Name:	Screenshot 2023-08-16 080019.jpg Views:	0 Size:	95.4 KB ID:	420735
                          I have been having reasonable success with the camo scheme below in the drier Southwest US terrain. But it's a big tall tank so it's still hard finding enough to hide in/behind.
                          Click image for larger version  Name:	IMG_2955.jpg Views:	0 Size:	412.0 KB ID:	420740
                          • SoCalBobS
                            • 2728
                            Looks good, R! Your khaki drab is a perfect fit for Southern California brush. I'm not satisfied with my results, so experiment terminated.
                            • SoCalBobS
                              • 2728
                              Something to look at; a short YT video clip showing “how our sausages are made”.
                              How’d you like to spend your work day like this?
                              • Rubicon99
                                • 3314
                                All those $6.00 a day disposable workers and that's only one line of production. I always love how they have no safety equipment. The guy is test firing the airsoft unit, points it at another worker then fires in past her into a back stop area and neither have any eye protection on. OSHA would loose their minds walking through most Chinese factories.
                                • SoCalBobS
                                  • 2728
                                  I've been posting on the specific M109 thread, but here it is. Pretty much done. Handsome AFV.
ID:	423358 Click image for larger version
ID:	423359 Click image for larger version
ID:	423360 Click image for larger version
                                  • Scott Larkins
                                    • Jan 2024
                                    • 19
                                    After just over a week of work, my new Bulldog is put together, repainted and weathered. Now she's ready to go. I know that the American Army never actually ran the Bulldog in any war, I still went with the American motif anyways. To make it my own, I added the sandbags and the stripes on the barrel.
                                    • MrChef
                                      • Jan 2023
                                      • 502
                                      • New York, Not the city
                                      Just another Tiger...
                                      • SoCalBobS
                                        • 2728
                                        No pictures from me this time. Instead a question. YT has started removing some of my tank videos, a Panther and a PzKpfw 1 so far. I'm guessing it's the iron cross decal that triggered the so smart AI. Any suggestions on where to post future historical models of nasty tanky videos that won't offend someone? (If you don't like it, don't look, I always say.)
                                        • Rubicon99
                                          • 3314
                                          Welcome to the club. I have had stuff pulled because the offending material had scenes from an IR tank battle with red lights flashing for hits. "Removed for Violent Content". But it's OK to post all the video game "screen recordings" of combat and killing all you want.
                                          It only takes one person complaining that their feelings were offended and poof you material is gone, except if its footage from a video game.
