  • David asked me to post this. It was a work in progress nearing completion before I decided to pause. It's much too fragile to battle and I'm awaiting a 3dp M8 Greyhound from Carlos to do that instead. All my stuff is geared toward battle so I prefer robust over details.
    Andy's M8 Greyhound, I converted using 3d printed parts I measured up and hacked the body to make work. Key features:
    Custom wheel hubs to adapt the Andy's wheels to the WPL axle
    True 6x6 using WPL style parts for the axles and driveshaft
    Dual motors, one motor for the front axle, one motor for the two rear axles
    Leaf suspension from WPL
    Servo steering on custom bracket and motor mount
    Custom turret traverse gear
    Custom recoil unit
    Custom elevation unit
    IR emitter in mantlet
    I presently have an old Clark TK22 in it and it's driveable. Just pending install of the skirts. In order to make it serviceable I have to come up with a way to make the skirts removable (I'll probably use magnets).
    Gathering 1-2x monthly/All Ages & Experience levels welcome
    • Originally posted by DavidN View Post
      Maybe you should start a thread for this armor car.
      I just started my 1/16 Andy's HHQ M8 Greyhound RC Conversion in the RC Truck section. Check it out! Once again, Youtube is limiting the amount of videos I can upload in 24 hours. I've had a CommieTube account for more than 10 Years, and they want me to verify my account. I've tried to do it a couple of times, and I'm told they can't verify my ID!!!!!!!!!!!!!!!!!!!
      • Originally posted by Tang - RC.Senshado View Post
        Custom recoil unit
        Tang, it looks great!!! Yes the kit is fragile. I don't use my RC vehicles as you in IR battles. I have a 3DP, but I haven't yet learned to use 3D CAD to make my own parts. I scratch build everything the old fashion way. I've used very similar parts as you've used in your build. Mine is a true 6 wheel drive as yours is and the others made by Carlos. I got bogged down with other things and I set my M8 build aside, but I'll begin working on it along with trying to finish my Tongde M24.
        Thank you very much for sharing your work, I appreciate seeing how others decide to build/convert things into RC vehicles.
          I am finally done with my British tank group for WWII.
ID:	450893 Click image for larger version
ID:	450894 Click image for larger version
ID:	450895 Click image for larger version
ID:	450896 Click image for larger version
ID:	450897 Click image for larger version
ID:	450898 Click image for larger version
ID:	450899 Click image for larger version
ID:	450900 Click image for larger version
          OMG David!!!!!!! You're a prolific RC Tanker if I've ever seen one!!!!! Most of us get one tank at a time, you get tanks by the platoon!!!!! I've never seen anyone do what you're doing before.
