Heng Long 7.0 and 7.1 speaker failures
  • Rubicon99
    • 3311
    Many have reporting issues with their 7.0 version tanks having the speakers die unexpectedly shortly after purchase. This is also happening with the upgraded 7.1 optional system and their speakers.
    After studying the problem it is my belief the problem is the power/volume level going to the speakers. The speakers just can’t handle a volume above setting 3 for extended run times or frequent usage.
    So to avoid “blowing out” your 7.0 and 7.1 systems I highly recommend not using high volume/sound levels.
  • Sureshot
    • 235
    Do you know of an after market speaker that might work better?
    Steve
    • Rubicon99
      • 3311
      Steve
      I will be replacing all my 7.0 and 7.1 speakers with Tamiya speakers as they blow outs. In the mean time I am keep the volume no higher the setting 3.
      • Zippersnapper
        Insane Unknown
        • Mar 2021
        • 502
        • SW Texas
        • Woohoo\o/
          • Feb 2020
          • 186
          • Cape coral Florida
          Mine blew on my t90. I went to a store called "five & below" and bought a bluetooth speaker and the package states the ohms and watts. 4 ohms 3w. The speaker was just slightly larger than the original but still fit into the stock circle speaker box of the t90. I've been having the volume maxed out and sounds really good.
          • cmdrcody
            "Grumpy"
            • Dec 2022
            • 228
            • Largo, FL USA
            Originally posted by Zippersnapper
            Which of these speakers listed did you use exactly? Did you wire it direct to the TK-7.0 board or use the shown amplifiers from the same company with the speaker?
            My speaker on my T90 blew out in less than 5 seconds on full volume.
            • Zippersnapper
              Insane Unknown
              • Mar 2021
              • 502
              • SW Texas
              This will help explain further....my channel
              I make my own tank speaker boxes......like they are supposed to be made. Using whatever speaker of choosing.
              • Zippersnapper
                Insane Unknown
                • Mar 2021
                • 502
                • SW Texas
                The FRS-5 I currently have in my KV-2 and is plenty loud for a 8ohm speaker running on a stock Henglong MFU. Lets discuss speakers.
                1. A 8ohm speaker will handle more power then a 4ohm (generally speaking) However, at the cost of volume or loudness. 2. The higher the sensitivity rating of a speaker, the louder it will be, given a set amount of amplifier volume. 3. For every 3db increase in volume, it is a perceived double loudness to the human ear. 4. Speakers of this size- the free air resonance is not of concern so building a box trying to calculate the cubic volume is a waste of time. A sealed enclosure will handle more amplifer power than a ported one. The amplifiers dampening factor plays an important role in sound quality as it controls the speakers ability to move out AND move in (tight response-less distortion).....I could go on and on, but im not building audiophile stuff for a tank.
                Ohhh...and did you know stock Henglong speakers are wired out of phase? Big No-No
                • cmdrcody
                  "Grumpy"
                  • Dec 2022
                  • 228
                  • Largo, FL USA
                  Great video for hearing the differences between speakers using the sameTK-7.1 board. I guess the HL TK-7.0 & 7.1 boards have too much output for the stock 4 ohm 3 watt speakers that come in the T90 tank. Due to the limited space in the T90 chassis the OEM speaker box is 2" round and 1-1/8" wide as you probably know with not much room for putting anything larger in there due to the low profile of the upper deck and rotating turret.
                  I see most of the speakers you used were 8 ohm but no mention of the wattage rating. What are the wattage you recommend? What is wired out of phase? - Never mine, I just googled it and found out the polarity is reversed.
                  • Zippersnapper
                    Insane Unknown
                    • Mar 2021
                    • 502
                    • SW Texas
                    "the wattage rating" refer back to parts express for that info as I dont know off the top of my head.
                    https://www.hobbysquawk.com/forum/rc...ker#post361837
                    2 stock speakers wired in series to make 8ohms....all in the same size enclosure as the factory one.
                    Because I make my own, and not someone else's, I can custom fit my boxes to accomodate any tank. Its just a matter of choosing the correct size driver and measuring.
                    • Zippersnapper
                      Insane Unknown
                      • Mar 2021
                      • 502
                      • SW Texas
                      I must point out that I run all my tanks full volume, have TK 6.0's all the way to 7.1's...using the factory henglong speakers and have never "blown" any. Your not the first to say they have, but I have no clue as to why.
                      Listening to loud Rock all my life, Extreem loud car & home audio, plus being a rodie for a band...trust me when I say I dont hear very well...so yea, I crank my stuff up to the max.
                      • cmdrcody
                        "Grumpy"
                        • Dec 2022
                        • 228
                        • Largo, FL USA
                        I can relate to that as working as a shooting range officer for a few years and being a pro-auto racing crew chief for 13+ years. My ears have heard it all. Been waiting for the price to come down on hearing aids as FDA has now made them available over the counter.
                        • cmdrcody
                          "Grumpy"
                          • Dec 2022
                          • 228
                          • Largo, FL USA
                          "the wattage rating" refer back to parts express for that info as I don't know off the top of my head.
                          Well I ordered and installed the two MakerHawk 4 ohm 3watt speakers I got through Amazon in my T90 with the TK-7.0 board. I trimmed off the two mounting tabs on each one, hot glued them together, wired them in series and hot glued them in place at the rear. They are louder on full volume than the OEM speaker that came with the tank. The low profile of the speakers was excellent for clearing the wiring harness & turret rotation. I'll keep you all informed how they hold up under constant full volume applied.
                          • Zippersnapper
                            Insane Unknown
                            • Mar 2021
                            • 502
                            • SW Texas
                            Good deal. Im in the process of cutting out a box for a single HG speaker. I did find out this one was wired in phase as opposed to two others that werent. I also did a Ohm check with my multimeter, and it Ohm'd out at 3ohm. I wonder if thats the reason why folks are burning out their speakers......
                            • cmdrcody
                              "Grumpy"
                              • Dec 2022
                              • 228
                              • Largo, FL USA
                              Good deal. Im in the process of cutting out a box for a single HG speaker. I did find out this one was wired in phase as opposed to two others that werent. I also did a Ohm check with my multimeter, and it Ohm'd out at 3ohm. I wonder if that's the reason why folks are burning out their speakers......
                              This is why I always question items made from China to be what they claim to be. There's no dependable QC department.
                              • Zippersnapper
                                Insane Unknown
                                • Mar 2021
                                • 502
                                • SW Texas
                                You got that right. Quality control much less consistancy in manufacturing are like speaking english to them.
                                • JennyC6
                                  • Nov 2022
                                  • 55
                                  The thing about Chinese factories is they will do exactly what the customer company pays them to do. They can build world class quality and consistency into every single box that comes out the door if they are told and paid to do so. They can also build the absolute worst dreck that barely has a crib death rate less than 50%. The have no shame, no qualms about scraping either end of the barrel. IT's all in who's paying the factory and what the terms of the contract state. If you approach one to contract out a production run of absolute garbage they will happily churn absolute garbage out all day every day just the same as they will churn out world class quality rivalling the best from the West if you sign the right contract.
                                  I fly a lot of nitro airplanes and I absolutely adore Magnum 4-stroke engines. I have three, all 52s, and all run every bit as well as the OS FS52 Surpass they're a grey market clone of. They start on the first flip, they never deadstick, they barely use any fuel, they seldom need their carbs tweaked, they make great power, they sound great...absolute dreamboats. I would not hesitate to buy one new over an OS if they were still in production! They're an example of someone ordering good QC, consistency, quality in general out that way. I've also bought 99 cent earbuds that lasted all of a week before one side failed. And yes, I have some genuine OS Surpass 4-strokes as well, I know how well they run just the same.
                                  • Brad G
                                    • Jan 2026
                                    • 5
                                    2 HL speakers blown out in 2 days. Now they are tough to source. Tank isn't the same without the sound system working
                                    • RichJohnson
                                      • 1276
                                      With the stock speaker that comes in 7.0 tanks you can’t turn the volume up past 3 or it will blow out. The audio amp on the 7.0 puts out more wattage than the speaker can handle. You need to upgrade to the 7.1 speaker. It looks almost the same except it has two speakers in the box.
                                      sadly I bought some 7.1 speakers from motion a while back and they were just 7 speakers with a 7,1 stuck over the 7 sticker. Typical chicom marketing. If the buyer doesn’t have a person there at the factory they will screw you when they run out of the right part. They will sub a different lower quality part on you and not tell you just to fill the order.
                                      anynway you need a 7.1 speaker or go get a aftermarket bigger speaker and wire it up.
                                      • keilau
                                        • Mar 2021
                                        • 1815
                                        • Windy City
                                        [QUOE=RichJohnson;n449208] With the stock speaker that comes in 7.0 tanks you can’t turn the volume up past 3 or it will blow out. The audio amp on the 7.0 puts out more wattage than the speaker can handle. You need to upgrade to the 7.1 speaker. It looks almost the same except it has two speakers in the box.
                                        anynway you need a 7.1 speaker or go get a aftermarket bigger speaker and wire it up.[/QUOTE]
                                        The DKLMRC speaker is highly recommended. More realistic sound for both the diesel (high bass) and turbine (low treble).
                                        3D Print Speaker unit with VISATON FRS7S speaker # Custom speaker box size avaliable! Contact us for Details # New design speaker box with nice sound speaker from Germany! We choose to use VISATON Full Range System speaker (FRS7S). The bass from the speaker is far better than regular FRS7. You will not just heard loudly tank sounds mixed together! Speaker Unit show as pic. Dimension : approx. 8x9x3.7 (cm) Pre-assemblied and soldered with regular HX2.54 plug that fit most tank board on the market. We print in different colors, speaker box ship with random colors.
                                        ​I built mine using plastic project box and lined the inside with elastic damping liner (3M). I used Dayton Audio 2.5" with larger magnet and higher efficiency. I like it a lot.​
                                        Click image for larger version  Name:	IMG_5487.jpg Views:	43 Size:	157.1 KB ID:	449212 Click image for larger version
