Armor Group South Central Florida RC Tank Club
  • HDMM
    • Feb 2020
    • 77
    • Florida
    Originally posted by Chris curran
    What's going on over at FB?
    FB politics and muppets basically. Social media is alotnof garbage for the most part.
    • Meter Rat
      • 504
      • Argyll and Bute, Scotland
      I have not been on the FB page for this group, so now’t to do with me. To far to visit. I have left face book because of those reasons, and opinionated persons.
      • SoCalBobS
        • 2717
        • Southern California
        A contraction I haven't seen before, "now't". I'll have to start using it! Maybe it's a Haggis term?
Name:	Screenshot 2024-01-17 065324.jpg
        • Meter Rat
          • 504
          Click image for larger version  Name:	Screenshot 2024-01-17 065324.jpg Views:	0 Size:	109.6 KB ID:	395020
          Bob, it’s pure Derbyshire. The county where I grew up, after leaving Scotland and before moving back. As in ‘owert and nowert, meaning anything or nothing. The collective noun for haggis is a “stooshie”
          • Chris curran
            • Aug 2020
            • 215
            Oh Yeah. All that.
            • DANOEL
              Another Day in Paradise
              • Nov 2023
              • 40
              • Florida
              Custom Russian Half Track I finished up recently. Going to add a few decals, that's about it. I built it using a JJRC Q60 truck for the frame, cab, front drive axle and transmission and a WPL E1 tracked vehicle for the traced portion. I shortened the E1 by about 1-1/4", used WPL metal track set (shortened), dual hobbywing 1060 esc's mixed with my Futaba 4PM radio, steering converted to servo, tail lights added and did a little dremel work to fit in a 3500 mah battery under the hood (to help put some more weight over the front axle), added a rear window into the cab, etc. A lot of trial and error and scratch building went into this project, but it came out pretty decent and drives well.
              Click image for larger version  Name:	414201051_122117866514098443_2021473805335121803_n.jpg Views:	0 Size:	145.1 KB ID:	395169
              Click image for larger version  Name:	413967804_122117867114098443_6640379731817809970_n.jpg Views:	0 Size:	136.4 KB ID:	395168
              Click image for larger version  Name:	414620283_122117867210098443_782174605039362816_n.jpg Views:	0 Size:	145.9 KB ID:	395167
              Click image for larger version  Name:	414438746_122117867156098443_2569071264053799495_n.jpg Views:	0 Size:	149.2 KB ID:	395170
              • quitcherbitchen
                • 923
                • Altadena, CA
                Fantastic job. Just need to weather her up.
                • MrChef
                  • Jan 2023
                  • 501
                  • New York, Not the city
                  Yes Excellent work Dan. My wife is sitting next to me and even said it's cool. But, green.
                  • DANOEL
                    • Nov 2023
                    • 40
                    • Florida
                    One of the short videos I made of the Halftrack one of it's first test runs outside.
                    • Meter Rat
                      • 504
                      Do the tracks help the steering? Brilliant work.
                      • DANOEL
                        • Nov 2023
                        • 40
                        • Florida
                        Thank You. The steering is all done via the front axle, with the front axle being driven and using dual ESC's I can mix the ratio's between the track drive and front axle drive to adjust for the difference in final drive ratios. By doing this, I have the front axle set slightly faster, like overdrive in a rock crawler, this helps it to steer much better. Also which helps is that the JJRC front axle has a differential instead of being locked, this also aids in steering. Although there are MFU's, like Clark that have a half track mode, there was no way to account for the different final drive ratios between the front and rea, so dual ESC mixing was really the best way to get this done. Actually was a lot cheaper than buying aftermarket MFU as well. I have about $200 total into this entire project.
                        • quitcherbitchen
                          • 923
                          • Altadena, CA
                          Can you provide the parts list for the ESC you purchased? Sorry if it is an inconvenience. I like what you did very much
                          • Meter Rat
                            • 504
                            Thank you for the reply.
                            If I read this right, you have an esc for the front axel and motor? And an esc for the rear motor drive? Like an electric differential between the two. I presume that both rear tracks drive at the same speed, and you cannot use them, like a tank to assist in the steering? Hence, why you said about half track boards.
                            • DANOEL
                              • Nov 2023
                              • 40
                              • Florida
                              Correct, one HW ESC controls the front motor / transmission to power the front axle, the second HW ESC powers the 2 track motors in parallel. The tracks don't assist in steering. Technically a halftrack doesn't quite work the way a tank does, they use a differential to drive the tracks and then use a brake to slow one down to assist in steering (US half tracks anyways). I wanted to try and use a spare truck differential to drive the tracks, but there just wasn't enough room and still have the proportions decent.
                              • DANOEL
                                • Nov 2023
                                • 40
                                • Florida
                                I used (2) Hobbywing Quicrun 1060 ESC's, can get them on Amazon for about $22 each. I had one on hand, so just needed to pick up a second one to do this project. Tried to keep this very budget friendly. Also running one of the Amazon aux lighting control switch to turn the ights on and off via a spare channel on the transmitter.
                                • Meter Rat
                                  • 504
                                  Excellent confirmation. Thank you.
                                  • Angel
                                    • Jul 2024
                                    • 2
                                    Hello all, im new to rc tanks and im very excited to see who is out there with same hobby. Looking foward to venture more with my tanks would love to know if this group is still active for rc meet up events?
                                    • Hank Slaght
                                      • Jul 2024
                                      • 5
                                      Hey Angel , I'm new here as well. Just ordered my first tank , so I decided to join this group. Doesn't seem to be much action around here. 😕
                                      • tdriver113
                                        • Apr 2023
                                        • 106
                                        • Peoples Republik of Illinois
                                        A few better pics of the 6x6. I've done a little detail painting, some weathering, flat clear, the lexan windshield pieces and some cargo. Calling it done for the most part, should compliment the M60A3 nicely. Might add some dust effects pigment, here and there, that's about it.
                                        Click image for larger version Name:	400484657_373518568664689_3654283407322643881_n.jpg Views:	0 Size:	156.7 KB ID:	390579
                                        Click image for larger version Name:	401497673_373518608664685_239143516690606341_n.jpg Views:	0 Size:	173.7 KB ID:	390581
                                        Click image for larger version Name:	400604302_373518635331349_286536394084260783_n.jpg Views:	0 Size:	144.0 KB ID:	390580
                                        Click image for larger version Name:	401655384_373518618664684_6734997338718860551_n.jpg Views:	0 Size:	173.1 KB ID:	390578
                                        Click image for larger version Name:	400774665_373518581998021_1562953619101171726_n.jpg Views:	0 Size:	162.4 KB ID:	390582
                                        Great job on that M35 6x6. Turns out this is a timely bump to this thread. I'm currently working on an upgrade to my M35 to make it look more like the actual one. Maybe I will start a thread in the RC truck section.
                                        • JohnDoyle22
                                          • Jul 2024
                                          Hello, I’m also new to this forum. I just came across three rc tanks and am interested in learning more and any meet ups in Central FL. I’m located on the East coast.
