View Post
if I will not use them in the tank I will use them in other RCS I have.
I think those are to be mounted on the hole of the outside plastic bracket between the hull and the sprocket wheel and will provide enough support to not wobble, then I will see the possibility to add the flange bearing by the inside. I am also in 5he process of chosing a 3d printer so if needed then probably will print a plastic part to be able to assemble by the inside also another bearing that will add up the ridgidity of the shiaft output from the gearbox.
At the moment I am very busy with other stuff.
Personal issues to deal but as soon the bearings arrive o will try and provide pictures and inform if they fit or not to help others as well.
