Rumors of Future Releases
  • PanzerLoco
    • May 2024
    • 104
    Extract from the manual guide from the upcoming TORRO Sd.Kfz.251.
    Can someone could identify the type of the battery connector?
    I was hoping a JST-2Pin connector ,..
    Cheers PZLoco
Name:	Capture d’écran_7-11-2024_2430_manuals.plus.jpg
Name:	Capture d’écran_7-11-2024_2822_manuals.plus.jpg
Name:	Capture d’écran_7-11-2024_2329_manuals.plus.jpg
Name:	Capture d’écran_7-11-2024_2108_manuals.plus.jpg
    • tank_me
      • Feb 2022
      • 1197
      The white connector is a JST 3-pin, but that is the balance plug used during charging. The black connector is too blurry for me to make out what it is. I would seriously doubt the black one is a JST though as you wouldn't put two of the same connector on the battery as it would cause confusion.
      • keilau
        • Mar 2021
        • 1844
        • Windy City
        Cheers PZLoco
        I do not have the TORRO Sd.Kfz.251 nor plan to get one. Looking at your manual picture, it is very similar to that of my 1/16 scale JWT military truck. The black 2P connector is the power supply connection to the motherboard. The white JST is for the balance charge. When you receive your Torro truck, measure the battery capacity using your smart charger.
        Military vehicles, tank or truck, runs relatively slow. Manufacturer use small motor and often supply low quality battery to save cost. They also use small battery pack because it is harder to find space in a half track (vs. a RC tank).
        My JWT truck came with a 270 motor and a battery pack made of 2 14500 Li-Ion cells. I replace them with a Mubichi 360 and a DIY 2S18650 battery pack. It is worth doing it. I can run the truck for many hours without recharging.
        Click image for larger version  Name:	IMG_5400.jpg Views:	0 Size:	100.8 KB ID:	413280 Click image for larger version  Name:	IMG_5401.jpg Views:	0 Size:	97.7 KB ID:	413279 Click image for larger version  Name:	IMG_5261.jpg Views:	0 Size:	136.5 KB ID:	413281
        Building battery pack is not difficult if you are handy with the soldering iron. I invested in a portable spot welder which makes the job even easier. (The spot welder cost is only a very small portion of your Torro truck.) I prefer Lithium-Ion battery much over Lithium Polymer for safety reason. If you shop carefully, you can find Lithium Ion battery with builtin protection circuit to prevent overheating. Lithium Polymer is much cheaper, lighter and smaller in physical size for the same charge capacity, but no protection circuit.
        • cleong
          • Feb 2024
          • 34
          Well if you were a fan of one of the world's most-produced tanks but have a pathological aversion to Hooben, here's an alternative on the horizon:
          • Rubicon99
            • 3316
            https://www.youtube.com/watch?v=O7R8xzTUhp8
            It cost $375 for the all green version and $475 for the camo version plus another $180 shipping from China. Overall build quality is similar to the latest HL Merkava.
            Its control system is not HL or TD and based on information seen appears to be a TK 16 copy. Gearbox are HL steal version types with red motors, suspension is torsion bar with metal arms and road wheels. It has an active idler system and all the wheels use brass bushing. (Those will need to be replaced with bearings).
            It's not easy to find at this time. You will need a third party that has connections to buy it and then ship it to you. Hopefully Toucan picks it up soon or one of the reputable seller on Aliexpress.
            The brand name its sold under is: Hu Bugui.
            • keilau
              • Mar 2021
              • 1844
              • Windy City
              Do you have a link to the manufacturer or any of their distributor? Is the YT guy selling this tank?
              • Rubicon99
                • 3316
                The manufacturer is not selling at this time outside of China. I had my "middle man" do the inquiry for me and where my numbers came from.
                There is no all plastic versions at this time.
                • quitcherbitchen
                  • 928
                  • Altadena, CA
                  Looks very similar to my Hooben, but the battery compartment looks interesting. Obviously completely new tooling on the mold. Wonder if some of the parts are interchangeable?.
                  • RichJohnson
                    • 1276
                    Based on my experience with 3 hooben tanks, not likely
                    • Rubicon99
                      • 3316
                      Not at all a copy of the Hooben T55 it is a completely new tank that uses internal parts compatible with HL tanks.
                      • keilau
                        • Mar 2021
                        • 1844
                        • Windy City
                        Heng Long dominant the low end 1/16 scale RC tank market. It is a marketing mistake if the manufacturer make their parts not compatible with Heng Long. The main reason that I stopped purchasing more Tongde tanks after the M60. It is important for small time collector like me, only 7 tanks.
                        • Rubicon99
                          • 3316
                          The internals of the T55 (T59).
ID:	414577 Click image for larger version
ID:	414578 Click image for larger version
ID:	414579 Click image for larger version
                          • quitcherbitchen
                            • 928
                            • Altadena, CA
                            Well the internals are certainly looking better then my Hooben T-55. I like the more conventional turret rotation gear and motor. I also see the gearbox looks and I mean looks better then my Hooben. Would love to see the crowded inside of the turret. I had to fabricate most of mine for servo recoil.
                            • RichJohnson
                              • 1276
                              If you watch the video this thing had recoil built in with airsoft but you can bet it has a standard airsoft gun with means my recoil unit will most likely fit.
                              I plan on getting one when I can
                              • PanzerLoco
                                • May 2024
                                • 104
                                Hello,
                                Concerning the upcoming TORRO Sd.Kfz.251.
                                The pre-Order for a March, 2025 released/delivery is available on their site.
                                For some unknow reasons; all info about it as disapear from Zandatoys site (CA - U.S.A)
                                And still no info on Motion RC about it :(
                                So,.. no supplier this side of the pond for now,..
                                Worth mention is the Camo pattern that is different from the 1st batch.
                                I prefer definetely the second pattern scheme
                                the price tag is 269 E
                                but was charged 229 E when my pre-orde was processed
                                cheers!
                                BELOW new camo pattern
                                BELOW 1st camo pattern
                                • SoCalBobS
                                  • 2754
                                  • Southern California
                                  For you non-FBers, this was posted today:
                                  • keilau
                                    • Mar 2021
                                    • 1844
                                    • Windy City
                                    French Lecterc RC tank is definitely a unique and welcomed addition to our hobby.
                                    • Rubicon99
                                      • 3316
                                      This says they have been listening 😉😉.
                                      • cleong
                                        • Feb 2024
                                        • 34
                                        It’s nice to see TongDe constantly come up with completely new designs, the hobby has never seen a new manufacturer come into this segment and offer so many new tanks within a short period of time. Love it!
                                        • DavidN
                                          • May 2021
                                          • 3203
                                          • Los Angeles, CA
                                          They provide and we must support them.
