SoCal RC Tank Club
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
ID:	403589 Click image for larger version
ID:	403590 Click image for larger version
    • DavidN
      • May 2021
      • 3189
      • Los Angeles, CA
ID:	403593 Click image for larger version
ID:	403594 Click image for larger version
      • DavidN
        • May 2021
        • 3189
        • Los Angeles, CA
        • Viper 178
          • Feb 2024
          • 10
          • Live in Singapore 🇸🇬
          Hi there.
          anyone out there know how to open the new version of HL snow leopard A2?
          Course from day 1 till now i still can't find the way to remove the top cover 😒.
          • DavidN
            • May 2021
            • 3189
            • Los Angeles, CA
            A few pics from our event earlier today
ID:	403860 Click image for larger version
ID:	403861 Click image for larger version
            • DavidN
              • May 2021
              • 3189
              • Los Angeles, CA
ID:	403864 Click image for larger version
ID:	403865 Click image for larger version
              • DavidN
                • May 2021
                • 3189
                • Los Angeles, CA
ID:	403870 Click image for larger version
ID:	403871 Click image for larger version
                • DavidN
                  • May 2021
                  • 3189
                  • Los Angeles, CA
ID:	403874 Click image for larger version
ID:	403875 Click image for larger version
                  • DavidN
                    • May 2021
                    • 3189
                    • Los Angeles, CA
ID:	403878 Click image for larger version
ID:	403879 Click image for larger version
                    • DavidN
                      • May 2021
                      • 3189
                      • Los Angeles, CA
                      • DavidN
                        • May 2021
                        • 3189
                        • Los Angeles, CA
                        To all members who will attend our event in the future, all IR apples must be above all accessories on your tanks. Your tank will not be allow to battle if there is a crewman, a hatch, a machine gun or any item that would obstruct the IR beam coming from the opponent's tank. This additional rule will create fairness in our games. Thank you for your understanding.​
                        • Rubicon99
                          • 3311
                          • DavidN
                            • May 2021
                            • 3189
                            • Los Angeles, CA
                            As we continue to improve our game, I decide to modify our rules of battle a bit more.
                            This next change in rule is about IR battle tank destroyers:
                            For all RC tank destroyers, the LegoDEI tank destroyer sunshade is allowed to be installed. One of the IR bulbs in the receiver must face directly forward. The tank destroyers will slightly be protected at the 45 degree angles but not at 90 degree angle. There will be no more electrical taping at the front of the IR receivers except for the Tamiya IR receivers. I don't have the solution for the Tamiya IR receiver yet if it is installed on the Tamiya tank destroyers. However, not any player in my club has a Tamiya tank destroyer (except me, heheh)
                            So for players with tank destroyers, you can protect yourselves by turning your tanks at the 45 degrees toward the enemy. When you want to shoot, you turn your guns toward the enemy. You can shoot and be vulnerable to get hits at the same time. I did some testings and I feel it will be quite fair in battle for both tanks and tank destroyers going against each other.
                            We will test out this setup the next few events and see how our players will respond.
                            Click image for larger version  Name:	IMG_5622.jpg Views:	0 Size:	144.8 KB ID:	405098
                            • Rubicon99
                              • 3311
                              For the Tamiya tank destroyer all you need to do is "twisted" the internal IR pyramid mirrors 1/4 turn. This will move the built in deflection to 45 degrees off the front, think "X" pattern. The tank will be invulnerable from beyond 20 feet to hits at the 12, 3, 6 and 9 o'clock position. This set up has been in use by the clubs at Danville, PHX, LA, SD, TX, FL for years.
                              Setting up the Lego in the same "X" pattern with the IR bulbs at the 2, 4, 8 and 10 o'clock positions and using the "45 shade" will accomplish the same thing as twisting the Tamiya mirror. With the IR bulb forward in the 12 o'clock as you have it shown above will not improve the difficulty of hitting it from the front and in fact only will mimic the standard hit and deflection arrangement of the unmodified Tamiya IR receiver. Which means it will be easy to hit anywhere in the front 45deg arc of the tank.
                              • DavidN
                                • May 2021
                                • 3189
                                • Los Angeles, CA
                                I see! I will open up one Tamiya IR receiver to "twist" and test it out. Thank you!
                                • DavidN
                                  • May 2021
                                  • 3189
                                  • Los Angeles, CA
                                  Getting ready to battle at our secret battlefield this Sunday.
ID:	405186 Click image for larger version
                                  • DavidN
                                    • May 2021
                                    • 3189
                                    • Los Angeles, CA
ID:	405190 Click image for larger version
ID:	405191 Click image for larger version
                                    • DavidN
                                      • May 2021
                                      • 3189
                                      • Los Angeles, CA
ID:	405194 Click image for larger version
ID:	405195 Click image for larger version
                                      • DavidN
                                        • May 2021
                                        • 3189
                                        • Los Angeles, CA
                                        A fun day of battling at our secret battlefield.
ID:	405613 Click image for larger version
ID:	405614 Click image for larger version
                                        • DavidN
                                          • May 2021
                                          • 3189
                                          • Los Angeles, CA
ID:	405617 Click image for larger version
ID:	405618 Click image for larger version
