The specs and images shown are for the upgrade edition. The professional edition comes with metal upgrades and can be found here.
Motion RC is pleased to offer Tongde RC tanks and IFV’s to global RC tankers! Offering unique subjects, these models are available in similar versions to other familiar manufacturers. When combined with Motion RC’s industry-leading selection, parts support, and customer service, Tongde RC models deliver an unbeatable value for RC armor enthusiasts.
Originally designed as a replacement for the M48 Patton, the M60 series became a primary MBT during the Cold War, with more than 15,000 units manufactured. The M60A3 was a significant improvement over the A1 variant, featuring updated turret configuration, crew comfort and safety enhancements, improved propulsion systems, and more powerful and accurate weapon systems. Italy, Austria, Greece, Morocco, Taiwan, and other countries upgraded their existing M60A1 fleets under defense contracts with Raytheon and General Dynamics during the mid to late 1980’s, while surplus Army M60A3 MBTs were sold to Oman, Bahrain, and Saudi Arabia.
This upgrade version offers nylon tracks and road wheels for light weight and budget friendliness, while delivering an extensive feature list that includes LED lights, sound, airsoft BB launch, IR battle system (compatible with other brands), and more. All of Motion RC’s Tongde 1/16 scale tanks utilize the latest TD 2.0 MFCB (Multi-Function Control Board) for outstanding control, performance, playability, and upgrade potential!
Compact and Efficient Gearboxes Tongde Upgrade models feature lightweight, economical nylon gearboxes while Professional versions include a metal-geared unit. |
LED Lights and Scale Details The ideal balance of scale detail and practical RC Tanking, each Tongde model has LED lights and arrive factory painted and includes accessory detail parts to further enhance the tank's realism. |
Ready to Run Each Tongde model arrives "Ready to Run" (RTR) to allow enthusiasts to join the exciting world of RC Tanks quickly and easily! |
Airsoft BB Launch In addition to IR battle capability, the M60A3 can safely fire 6mm plastic airsoft BBs at targets up to 10M (30’) away. Please always take safety precautions and wear eye protection. |
- Latest generation TD 2.0 Multi-Function Control Board (MFCB)
- Proportional acceleration, steering, turret traverse, and gun elevation/depression
- Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed/ low speed modes, etc.
- Cannon recoil system
- Adjustable track tension
- Smoke effect (on/off)
- LED lights (on/off)
- Sound effects volume
- Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
- Track recoil
- Fires a 6mm plastic BB (10 meters with minimal accuracy and limited velocity, but should still be treated with caution and with adequate eye protection)
- Fires an invisible IR signal to be used as part of Tongde’s Infrared Battle System, which disables other tanks when hit five times during simulated combat.
- Independent suspension on all road wheels
- Tongde US M60A3 Upgrade Edition 1/16 Scale Battle Tank - RTR
- 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
- 2S USB LiPo/Li-ion battery charger
- 12 channel 2.4GHz radio transmitter
- Magnetic infrared (IR) battle system receiver
- Painted cosmetic accessory parts
- Adhesive decal sheet
- 6mm plastic BBs (50 Pack)
- Smoke oil
- Comprehensive instruction manual
- Four (4) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : 1 Hour
| Scale | 1:16 |
| Length | 59.5cm / 23.2in |
| Width | 23cm / 9.0in |
| Height | 20cm / 7.8in |
| Weight | 4,350g / 155oz |
| Body Material | ABS plastic |
| Chassis Material | ABS plastic |
| Track Material | Plastic |
| Motors | Two 380 motors (28x37mm) |
| Bearings | Metal bushings |
| Gearbox Gear Material | Plastic |
| Adjustable Gear Ratio | No |
| Differential Type | N/A |
| Suspension Type | Torsion bar |
| Sprocket | Plastic |
| Road Wheels | Plastic |
| Idler Wheel | Plastic |
| Adjustable Idler | Yes |
| Turret Rotation | 320 degrees |
| Lights | Yes |
| Sound | Yes |
| Exhaust Effect | Yes |
| IR Battle Ready | Yes |
| Airsoft BB Launch | Yes, 6mm |
| Track Recoil | Yes |
| Cannon Barrel Recoil | Yes |
| Required Battery | 2S 7.4V 1800mAh Li-ion battery with Tamiya connector (included) |
| Required Radio | 12 channel 2.4GHz (included) |
| Skill Level | Beginner |
| Build Time | 1 hour |
| Recommended Environment | Indoor / outdoor |
