M113 from Tongde review Rich Johnson Models N Stuff
  • SoCalBobS
    • 2754
    • Southern California
    I have added Rich Johnson's Recoilless Rifle (M40 I believe) to my M113. I have a spare IR bulb from another Tongde project that I will install in the barrel. TD's IR bulbs are 3mm in diameter, which fits in the barrel. The barrel comes with a 3mm brass tube, so wires will fit through it and out a small hole the RJ has incorporated in the M40 print. Traverse will be accomplished by a servo linkage activated by the slider on Heng Long's v.7.1 transmitter. The servo plugs into the CH5 port on the HL 7.1 board.
    The TD IR isn't as powerful as the aftermarket 6mm bulbs we use in our tanks, but is stronger than the stock HL IR bulbs. The effect of this is that the M113 will have to get closer to get a hit on a tank, making it vulnerable until it does, which can reflect it's relative weakness vs a MBT.
Name:	M113 ACAV 13.jpg
ID:	439241 Click image for larger version
Name:	M113 ACAV 12.jpg
    I also added a photo of a real M113 that shows the dusty condition they often were in, to justify my weathering.
    • SoCalBobS
      • 2754
      I found some "M113 Tank Crew" 3D print figure files online at "MyMiniFactory". I had JVM3DConcepts print them out for me. Here are the first two (of six, still painting).
ID:	440164 Click image for larger version
      • SoCalBobS
        • 2754
        A couple more. Two to go. I'd be interested to hear from anyone who knows how these figures are generated. 3d laser scanning, or? Many details are similar, like the flak jackets, shoes and limbs, but they are in different poses. The proportions are accurate allowing for leg and arm bending, etc. It's not the same as the traditional physical sculpting. Opinions?
        • DooHickey
          • 9
          Love the look of the figures, Sounds like my next project! I am really liking My M113, fully compatible with my other Heng Long tanks in battle. Great spot for the IR receiver. Still working on weathering. Will have pics soon.
          • RichJohnson
            • 1276
            Very nice. You need to post the link where you got the figures.
            I still have a few of each M113 in stock too.
            • SoCalBobS
              • 2754
              Details are in post #22.
              • SoCalBobS
                • 2754
                Here are the six poses in the set:
ID:	440358 Click image for larger version
ID:	440359 Click image for larger version
ID:	440360 Click image for larger version
                • DooHickey
                  • 9
                  Finished my M113 . Photos taken at our RC flying field, a work in progress! Hardest part was finding a gunner that fit. Modified his arms to reach the gun. Very nice tank! Smoke tank was broken when I received it but was an easy fix Click image for larger version
ID:	441428 Click image for larger version
Name:	thumbnail m113 c.jpg
                  • RichJohnson
                    • 1276
                    Some new products to customize the Tongde M113 into other tactical offensive battlefield AFVs.
                    Up first the M901 kit. A dual TOW middle launcher which gives an IR battle capable 113 the advantage of height over its IR Receiver and ability to hide behind cover and fire at tanks. Click image for larger version
ID:	441479 Click image for larger version
ID:	441480 Click image for larger version
                    • RichJohnson
                      • 1276
                      Up next is my new ADAT turret for the M113. That is an Air Defense Anti Tank styled closely after the product tested by the US Army and purchased by several foreign nations. It fired laser guided missiles similar to Stingers.
ID:	441482 Click image for larger version
ID:	441483 Click image for larger version
                      • Waxweazle
                        • Jan 2026
                        • 3
                        Originally posted by DooHickey
                        Finished my M113 . Photos taken at our RC flying field, a work in progress! Hardest part was finding a gunner that fit. Modified his arms to reach the gun. Very nice tank! Smoke tank was broken when I received it but was an easy fix Click image for larger version  Name:	thumbnail m113.jpg Views:	119 Size:	136.1 KB ID:	441428 Click image for larger version  Name:	thumbnail m113 c.jpg Views:	95 Size:	150.7 KB ID:	441429
                        Nice build 👌🏻 Did you disassemble the M113 for painting? What color did you use?
                        • DooHickey
                          • 9
                          Yes, i disassembled it. I used gun bluing on the metal tracks. Used rattle can green camouflage from Rust-oleum . Hardest was to paint the face on the gunner . I also dab a little green over the decals to simulate fading and chipping using a sponge .
                          • Waxweazle
                            • Jan 2026
                            • 3
                            Rust-Oleum 1920830?
                            • DooHickey
                              • 9
                              279175 flat deep forest green
                              • Waxweazle
                                • Jan 2026
                                • 3
                                I asked the boss of Tongde if they would also produce an M548 in addition to the M113, he said he would discuss it internally
                                • Razvan1974
                                  • May 2026
                                  • 2
                                  • Razvan1974
                                    • May 2026
                                    • 2
                                    Yes, indeed! The 548 would be the obvious, normal choice, for everyone of us, alongside the M577. But, before all of this, they would do an even greater job releasing some , let’s say so,” upgrade “, scale-correct, separate metal track sets, for the M113 versions they already released.
                                    And here I want to mention the Diehl 513B track, used on the MRV. And the greatest thing would be to make all 3 versions of them with rubber pads: the T130E1; the T150 and the Diehl 513B. And the next variants of the M113 chassis shall have these as a standard equipment.
                                    I count on you, giving the fact that you are out link with the command board on Tongde Model!
                                    • SoCalBobS
                                      • 2754
                                      I thought I'd posted these earlier, but not so here they are: what's an APC without soldiers standing around waiting to mount up?
Name:	M113 Crew 12.jpg
ID:	449123 Click image for larger version
Name:	M113 Crew 13.jpg
