I have added Rich Johnson's Recoilless Rifle (M40 I believe) to my M113. I have a spare IR bulb from another Tongde project that I will install in the barrel. TD's IR bulbs are 3mm in diameter, which fits in the barrel. The barrel comes with a 3mm brass tube, so wires will fit through it and out a small hole the RJ has incorporated in the M40 print. Traverse will be accomplished by a servo linkage activated by the slider on Heng Long's v.7.1 transmitter. The servo plugs into the CH5 port on the HL 7.1 board.
The TD IR isn't as powerful as the aftermarket 6mm bulbs we use in our tanks, but is stronger than the stock HL IR bulbs. The effect of this is that the M113 will have to get closer to get a hit on a tank, making it vulnerable until it does, which can reflect it's relative weakness vs a MBT.
I also added a photo of a real M113 that shows the dusty condition they often were in, to justify my weathering.
