VOTE NOW! MARCH MAYHEM CUSTOM MOTION RC AIRCRAFT CHALLENGE!
This topic is closed.
ID:	239872 My 80mm Avanti s
    USAF t-bird style.
    • A Father's Day tribute to my father who flew the A-4 for the USMC from 1966-1977. I worked with Callie Graphics to get the same squadron VMA-121 he flew with in his tour of Vietnam including air support for the seige of Khe Sanh. The decals are so accurate that (1) the tail number 150092 matches the plane he flew on several occasions as we verified in his log book. (2) Capt Doug Walton and the 300 bomb decal appears as it did on his real jet.
      • Originally posted by lwalton816 View Post
        Fantastic post lwalton816 and welcome to HobbySquawk! Nothing beats customizing an aircraft than when you can attach that kind of history to it as well. Just awesome
        • Originally posted by Dapreacherman43 View Post
          My 80mm Avanti s
          USAF t-bird style.
          Very nice! Always love a T-Bird scheme!
          • Base Jet: Freewing Stinger 90
            Modifications:
            1) Custom paint design
            2) Custom designed graphics printed by Callie
            3) RC Geek LED afterburner
            4) Reduced 6 wing servo connections to 2 using Chris Hansen's locking polarized connectors
            5) 4 Final clear gloss coats of exterior Spar Urethane
ID:	239903Click image for larger version
ID:	239904Click image for larger version
              • Base Jet: Freewing ARF 90mm F-16 Super Scale
                Modifications:
                1) Freewing 12 blade 4068-1835kV inrunner/Castle 130 amp ESC/Castle 10amp BEC
                2) 4 Separate liveries designed for 1 plane, interchangeable in 5 minutes
                3) Custom paint, graphics by Callie, custom graphics for 4 noses by Callie
                4) Additional LED afterburner by RC Geek in addition to stock ring AB
ID:	239918Click image for larger version
ID:	239920Click image for larger version
                • lwalton816, Welcome to "The Squawk". Great Tribute Airframe Livery. Bravo Zulu, Sir. Glad you're here. Best, LB
                  • Flightline 2000mm B-24 Liberator Silver version
                    Modifications:
                    1) Custom Paint Scheme
                    2) Graphics by Callie, Custom Designed Pin-up printed by Callie
                    3) 3D printed cockpits, front and top turrets, pilot/co-pilot and 2 gunners added along with servo's for operational front/top turret
                    4) Mr. RC Sound with multi-engine sound card and 2 transducers
                    5) 4 final coats of clear gloss exterior Spar Urethane
ID:	239931Click image for larger version
                    • Flight Line 1600mm Corsair Bubble Top version
                      Modifications:
                      1) Custom paint scheme with graphics by Callie
                      2) Cowl Flaps added
                      4) Warbirds Pilot with moving head
                      5) Radial engine modification with copper tubing
                      6) Mr. RC Sound with Double-Wasp engine
                      7) 3 1/2" Robart Main Wheels
                      8) 4 final coats clear gloss exterior Spar Urethane
ID:	239944Click image for larger version
ID:	239946Click image for larger version
                      • Base Jet: Freewing 90mm F4 camo version
                        Modifications:
                        1) Repainted to the Blue Angles Scheme
                        3) 3D printed cockpit and pilot modifications
                        4) RC Geek LED afterburner
                        5) 3D Exhaust Nozzles (added recently with afterburners)
                        6) 4 final coats of clear gloss exterior Spar Urethane
ID:	239951Click image for larger version
ID:	239953Click image for larger version
ID:	239955Click image for larger version
                        • Base Jet: Freewing 70mm BaE Hawk, base grey.
                          Modifications:
                          1) Repainted to Ace Combat 4 "Yellow Squadron" livery
                          2) Graphics by Callie (nomenclature only) and cut my own modex numbers.
                          3) Mixed my own greys to contrast with the original base grey. Masked and painted yellow for underside. Then, masked off first layer of dark camo, then followed up with light camo. Final coat with satin polycrylic!
                          • Here is one of the fleet. Freewing Mig 21 in Russian desert camo. Center mount fuel tank mod added.
                            Todd
                            • My freewing f14 tomcat
                              • Comment
                                • My customized Freewing 70mm Base Gray Bae T1 Hawk:
Name:	Bae T1 Hawk-AR-1.jpeg
                                  • Matt_Chapman10 & Hollywood Welcome To Hobby Squawk. Glad you're on board. Best, LB
                                    • Glad I’m not a judge for this contest. A lot of beautiful and well built aircraft!
                                      Roy Mayoral
                                      • Click image for larger version  Name:	IMG_4193.JPG Views:	0 Size:	92.0 KB ID:	240146Click image for larger version  Name:	IMG_4089.jpg Views:	0 Size:	88.2 KB ID:	240147 Click image for larger version
                                        • My second submission.. Roban airwolf on trex 500 mechanics. Lots of mods :)
