EDF to Turbine Conversions
Im using a festo shutoff valve in my X45 install with zero issues. Jet cat sell a barbed shutoffComment
Has anyone ordered a thrust tube that was a proper fitment for the Freewing Avanti? I want to order one but there are so many sizes I am afraid to order the wrong one.
Would really appreciate any links of thrust tubes that fit this aircraft. Thank you in advance!Comment
Which engine are you using? That information will narrow the results and help everyone help you
This one will fit. http://www.grumania.com/xtcommerce/J...KG45::957.html
Plus, lot's of good imfo here. https://www.rcgroups.com/forums/show...-turbine-power
https://www.hab.se/bygghobby/hab-cnc/fms-avanti-80mm-turbin-konverteringskitt-komplett-p20-1Comment
Gotcha. As mentioned above, HAB has a conversion kit (linked below) for the K30 and K45 specifically for the Freewing Avanti S.
For product questions and to order, either Tomas or Amir at the email addresses below:
Tomas: tomas@hab.se
Amir: amir@hab.se
Hello to everybody. I would like to install a 4.5 Kg turbine in a Freewing A-10 in one engine nacelle. What should be the angle of misalignment and to which side. Thank you for any feedback.Comment
I am new to turbines and want to get a proper refueler. I know Jersey Modeler offers a nice setup for kerosene but way too expensive. Slimline offers a Flilghtline Refueler that is a manual pump setup but advertises it as a Gas refueler. My question is, are the refuelers that can be used for gas safe to use for kerosene. I would not want contamination if the seals, tubing or pumps would deteriorate using kerosene. Any help would be appreciated.Comment
I've just finished my conversion of my Freewing F22 Raptor using a X45 and I must say, it's my best flying small jet yet! Very quiet in the air and the flattened home made pipe fives a real throaty growl at military power!! It balances without lead by having a 2200 battery in the nose cone and my home made one litre tank fits right over the CG and take-off weight is about 4.3kgs, so a 7-10 minute flight is possible. Here are some pictures of the build and a hat-cam video of a flight. https://www.youtube.com/watch?v=uc1Vzg5KxRkComment
This pump works Great!I am new to turbines and want to get a proper refueler. I know Jersey Modeler offers a nice setup for kerosene but way too expensive. Slimline offers a Flilghtline Refueler that is a manual pump setup but advertises it as a Gas refueler. My question is, are the refuelers that can be used for gas safe to use for kerosene. I would not want contamination if the seals, tubing or pumps would deteriorate using kerosene. Any help would be appreciated.
I have the Slimline can too.
I use a 2 cell lipo to drive the pump simple and very affordable.Comment
At the 4 hour 38 minute mark in the video below, someone who converted it to a turbine jet using the Xicoy X45 flew at the Horizon Hobby Airmeet 2021 event right after the EDF version flew.
No not yet. One person I fly with did and is supposed to bring it the field today for maiden. The video RcInformer did is great. Look it up on YouTubeComment
