What did you fly today?
    • Nov 2013
    • 2789
    • Cody, WY
    Some of our wonderful club members came out to the field before I got there and mowed down all the weeds around the perimeter of the runway, and a bunch that had grown up through the cracks in the asphalt. Whoever you were, I Salute you! You did a great job!
    I flew my Flightline 1.6M Corsair this morning, a little windy but mostly down the runway. My Corsair was up to the task. This old airplane, which dates back to about 2019 or earlier, has been one of my favorites of all time. I just marveled how well it tracked the centerline for takeoff and landing, with very little input from me. It's just a wonderfully designed airplane, and one of my faves of all time. I have no idea how many flights I have on it since I bought it, gotta be at or over 200 or so. I recently replaced both the main gear retracts and it is running in tip top shape.
    I also took up my FMS F-86 on its 75th flight today. One complication I noticed a small flash of light (the airplane is silver) and I suspected maybe one of my large foam wing drop tanks had departed the airplane. As it got closer to me, it was indeed gone, but the airplane was still pretty manageable flying. without it. The plane landed fine and then I made the trek through the field to find my tank. Sure enough, it was WAY out there on line with the runway. The little plastic clip that is glued onto the foam tank and attaches to the pylon on the wing had come undone (it is a new tank from FMS and probably needed more glue) but I have remedied that with some good E6000 glue and will let it set up overnight or longer before I try flying it again. Overall, a nice day to celebrate National Aviation Day!
    Cheers
    Davegee
      • Nov 2013
      • 2789
      • Cody, WY
      The other day I took up my Flightline 1.6M P-51D Hurry Home Honey up to do some more ordnance and drop tank testing at the local field. The first flight went great with dropping the two OEM 75 gallon, foam drop tanks from an altitude of about 80 feet or so. Came out great, and they landed undamaged within about 3 feet of each other on the ground.
      Then, I put two of my printed 500# bombs up for their second test. The first test went perfect. So, I was hoping for a repeat performance. Unfortunately, I might have released the bombs just a second or two late and they sailed again in a ballistic arc well past where I planned to retrieve them. Instead, they landed in a bunch of sagebrush and their OD color didn't help pick them out in the bushes! I found one of the bombs quickly but just could not find the other one, and I was assuming it would land closeby. But I started a search in expanding circles around that tank, still no go. Eventually, I got a bit disoriented and couldn't find the First bomb again! I tried and tried, but after an exhaustive search, it was as if the Earth itself had swallowed them.
      I decided to print up two more bombs, and just completed them this afternoon. Callie made some nice stencils for me to put on the bombs. I plan to do another test next week.
      Of the two larger 110 gallon drop tanks, I did get in one drop test last week, but one of the two tanks broke up on landing. The other one was just fine. There was no salvaging that one, but this time I printed a thicker tank, with advice From Elbee for changing a few parameters on my Prusa mini printer. They are printed now, but I won't be done with them unitl next week sometime. Then I'll see how strong they are.
      Always something, but still fun and a challenge. I have learned to bring some flags on sticks with me to mark the initial tank that I find in the brush, should I do that again. And the second thing is to try to get better at placing the drops near a clearer part of the field. That's not easy, at our remote field.
      Here's a couple pics I just took of the bombs and big tanks. You can see HHH standing up against a wall, ready for its next flight.
      Click image for larger version  Name:	IMG_3885.jpg Views:	0 Size:	82.7 KB ID:	452102 Click image for larger version  Name:	IMG_3886.jpg Views:	0 Size:	42.8 KB ID:	452103
        • Nov 2013
        • 2789
        • Cody, WY
        I took my FMS P-47D razorback Ol' Cock out from the rafters in the garage to do some more drop testing and get it back flying before I put it back for the winter. It flew great, typical of this FMS airplane, and I did two drop tests of a foam centerline drop tank. I especially worked on dropping the tank in a specific area where I could retrieve it ok afterwards. I think this was about the 55th flight of this airplane, and it worked out great.
        Also flew my FMS F-86F for a flight and was pleased with its performance. I have a nagging problem with the small gear strut doors breaking off from one of their mounts. Even with a good landing, these very fragile pieces can break off and have to be repaired or replaced. I fixed mine again today after today's flight and will put it up tomorrow to see how it goes. They were out of replacement parts at FMS, but finally got restocked so I ordered two more sets. Everything else about the plane is great, no issues.
        Here's some pics from today.
        Click image for larger version  Name:	IMG_3892 (1).jpg Views:	0 Size:	168.6 KB ID:	452150 Click image for larger version  Name:	IMG_3887.jpg Views:	0 Size:	143.1 KB ID:	452151 Click image for larger version  Name:	IMG_3889.jpg Views:	0 Size:	165.8 KB ID:	452152
          • Nov 2013
          • 2789
          • Cody, WY
          Took out my FMS P-47D modified bubbletop to run a test on the 150 gallon drop tank that Danger Dan and I have been working on. This was its third operational drop test and that thing is built like a Sherman tank! It was printed by Craft Cloud and I finished putting it together, adding an E Flite drop mechanism, and painting it. Worked great, again. I don't think we need to test it any more. It's good to go.
          Also photographed the plane with the cylindrical silver 108 gallon drop tank, and shots with 500# bombs under the wings, and the M10 bazooka rocket launchers that they experimented with to knock out ground targets in France. It had limited success for them but were more successful in other theaters of the war. The 56th Fighter Group and Hairless Joe flew a few missions with them. They didn't do all that much with them after tthat. Another problem was you could not jettison the tubes when expended, a big drag item.
          Click image for larger version  Name:	IMG_3909.jpg Views:	7 Size:	138.0 KB ID:	452219 Click image for larger version  Name:	IMG_3911.jpg Views:	7 Size:	144.7 KB ID:	452220 Click image for larger version  Name:	IMG_3907.jpg Views:	7 Size:	183.0 KB ID:	452221
            • Nov 2013
            • 2789
            • Cody, WY
            Took my Flightline B-25J up again for some landing practice and dropping of scale "parafrag" bombs, those dropped from very low altitudes in the Pacific Theater in WWII. These explode-on- contact bombs were dropped by parachutes from extremely low altitudes, well under 100 feet. The parachutes gave the planes just enough time to get away from the explosions. The airplanes were modified to have tremendous forward fire power brought to bare against enemy targets at low altitudes. In my plane's case, they had eleven 50-caliber machine guns facing forward for devastating fire brought to bear on the enemy ships, armor, and personnel. This particular airplane was lost with all five crewmembers killed on a mission over Saigon in-then French Indochina in January 1945.
            Also got a flight in with my F9F Cougar with all the "bells and whistles" attached like the nose-mounted aerial refueling tube.
ID:	452288 Click image for larger version
ID:	452289 Click image for larger version
            • jetfool
              • Nov 2022
              • 1371
              • Crawfordsville, Indiana
              Good looking planes
                • Nov 2013
                • 2789
                • Cody, WY
                I'm running through all my airplanes, all of them flyable, as we have some good flying weather with fairly low winds, for now. Most of the planes will go into storage over the winter. I still have an ace up my sleeve, the EFlite Timber, which can fly in almost any weather, snow or clear, hot or cold. It's a blast to keep some semblance of my flying skills up during those months.
                Today, I flew my Penrod and Sam for a couple of flights, and the FMS F-86F. Both flights went well, the first flight with the P-47 I dropped the foam centerline belly tank for grins, and just flew it for fun the rest of the flight and the second flight. The F-86 was its usual self, a great flyer and has a beautiful presence in the sky.
                Cheers
                Davegee
ID:	452305 Click image for larger version
                • f4u ausie
                  • 1242
                  • Melbourne
                  Spring hàs has just come(yesterday). Down under so looking forward to some warm weather
                  .. just don't like the mid summer 🏝️ heat. Here. As always great pics dave. And that pilot does look awesome.. no doubt from the Grossman stable.
                    • Nov 2013
                    • 2789
                    • Cody, WY
                    Happy Spring Down Unduh! I wish you a happy season of spring and summer (when not too hot!) flying rc airplanes and other fun stuff. We'll stay tuned for your posts!
                    Yes, that pilot was painted in the Grossman Paintworks, and he does a marvelous job! Now he's painting smaller 1/16 scale tank figures which will hopefully bring a lot of armor clients to him to paint their crews.
                    I think I flew my 80th flight on Penrod and Sam yesterday, and it is one of my favorite P-47s to fly, not that the other FMS planes are anything but great to fly. My Flightline Corsair is probably the best of them all slightly, and with the mods I've put on it like the Robarts hollow tires, it tracks the runway centerline with ease, especially with that wide-stance gear. I'm hoping for a long and glorious fall here in the northern hemisphere and can fly well into November before putting the toys away for the winter. However, I still have my E Flite Timber waiting in the wings for snow covered days just to let it rip and do impossible maneuvers I would never try with my scale planes!
                    Have Fun!
                    Cheers
                    Davegee
                      • Nov 2013
                      • 2789
                      • Cody, WY
                      I only got one flight in today because the winds came up, but it was worth coming out to do it. I did a drop tank release using the OEM stock foam silver drop tanks, a non-event these days. Might try again tomorrow if the winds stay light, but that might not happen. My Estes altimeter showed I attained a maximum altitude of 99 feet during the flight, for what it's worth! Danger Dan and I are doing a rework on the 110 gallon drop tanks as they were a bit too "fat" or large in diameter. Hopefully we'll get them spot-on for this iteration.
                      Cheers
                      Davegee
ID:	452346 Click image for larger version
ID:	452345 Click image for larger version
                      • jetfool
                        • Nov 2022
                        • 1371
                        Motion r/c need to retain you and Dan for added scale items for their fleet. Many modelers would be interested adding these. Be a great retirement adventure.
                        Best Regards, Rex
                          • Nov 2013
                          • 2789
                          • Cody, WY
                          Best Regards, Rex
                          Thanks, Rex. Perhaps. Although it is a passion for Dan and me, I don't know how many people really care about scale stuff. RC Geek has been very successful, not sure if we could approach the same experience as him, though. If nothing else, it's good to work the old brain cells to come up with some stuff that not that many have done before. Even if no one else is interested, it is worth the challenge to me, anyway. I've had a pretty good run with my PrecisionAerospace.com venture over the past 15 years or so. I'm going to go to Washington, DC probably the first week of December to check out several projects that I did as contract work for the NASM. By that time, the last of the exhibit galleries will be open.
                          Davegee
                            • 7434
                            Just got through with version 3A for the 108 gallon drop tank.
                            For anyone that hasn't designed on Tinkercad, here's a little tour...
Name:	Screenshot 2026-09-04 172442.png
ID:	452383 this is the fore section of the tank with the gas cap and blank separate.
Name:	Screenshot 2026-09-05 152156.png
ID:	452384 This is the whole tank, its actually three sections.
Name:	Screenshot 2026-09-05 152250.png
ID:	452385 The grey piece is the negative shape that carves out the positive shape. Just checking to see how it fits over the ring of the center section.
Name:	Screenshot 2026-09-05 152855.png
ID:	452386 The tip of the negative shape shows that I'm leaving some thickness to the nose for strength. Previous versions showed a weakness there when hitting the ground.
Name:	Screenshot 2026-09-05 152946.png
ID:	452387 This is what the finished piece looks like looking in.
                            As like anything in life, you get better the more you practice.
Name:	Screenshot 2026-09-05 153710.png
                            Dangerous Dan)
                            • paulrkytek
                              • Jun 2019
                              • 542
                              • North of England
                              Revamped my pre covid Mig 21 with the 3658 2159kv 12 blade, 4500Lihv lipo and repainted the top in desert scheme to contrast with original blue and white underside to make it easier to see in English grey skys. Just waiting for paint to go off for a couple of days before remaiden
Name:	Mig21 three.jpg
ID:	452397 Click image for larger version
ID:	452398 Click image for larger version
                                • 4874
                                [QUOTE=paulrkytek;n452396]Revamped my pre covid Mig 21..../QUOTE]
                                Great work, Sir.
                                She's a beauty.
                                Best, LB
                                  • Nov 2013
                                  • 2789
                                  • Cody, WY
                                  Dangerous Dan)
                                  This revamped version by Dan should be much closer to the dimensions at 1/7 scale of the real 110 gallon Bowater paper tanks that were manufactured in England during WWII. Although not perfect, (leaky sometimes necessitating filling the tanks at the last minute before engine start up for their missions) but they filled a gap when steel and aluminum tanks were not available.
                                  Dan has done a sterling job as we work through scaling these tanks for various airplanes like the P-47 and P-51. Then, to "flight test" where we see how well they did in practice, and learn from our mistakes. Then, we make improvements and go back and fly again until they are right!
                                  Excellent job on the designing, Danger Dan!
                                    • 7434
                                    I actually started out with a 1/32 size drop tank from my P51 and measured from there. How much the fore and aft sections were as a percentage of the whole length. That way, once the actual dimensions were know, it was pretty easy to upscale. The dang program is addicting, I swear!
Name:	Screenshot 2026-09-03 174955.png
                                    (Dangerous Dan)
                                      • 2818
                                      • Arlington, TX
                                      Got in 3 flights yesterday on my HSD 747 turned Shuttle Carrier Aircraft piggybacking the Shuttle Enterprise. The first 2 glides were a bit short and ended in the grass, but the last one made it to the runway.
                                        • 4874
                                        Incredilbe. What a great project. Congrats on the flights. Truly well done. Best, LB
                                          • Nov 2013
                                          • 2789
                                          • Cody, WY
                                          Very impressive!! Congrats on the successful flights of Both aircraft(spacecraft)!
                                          Davegee
