3d Printed Part Sets - Freewing 90mm F-22 Raptor
AMA#116446Comment
I didn't see them there, but a quick search on Thingiverse found this.
This is a file dump of the 3Dpup parts available on the F-22's support page. I am in no way taking any credit for the creation of these models. I simply wanted to make sure they were available from another source in case something ever happens to the original download link.Please visit the product's support page to get the original files:https://www.motionrc.com/products/freewing-f-22-raptor-90mm-edf-jet-pnp#support-tabComment
Thanks Elbee, much appreciated !mr.frankenjet, Very clever, Sir. Best, LB
Does anyone have the complete cockpit set files, likely they are out there but I don't know where (story of my life
rc flyin addictComment
DISCLAIMER: This thread is intended to organize all discussion regarding the 3DPUP ("3D Printed Upgrade Parts") Sets for the Freewing 90mm F-22 Raptor,
FJ, page 1 of this thread.
No worries, most guys have forgotten that's where all the STL files were originally posted, on or near the opening pages.
And you can call me LB, but whatever you do, don't forget to call me for dinner.....
Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
THANKS !!
Best, LBrc flyin addictComment
STL AIM9 Launcher Display SetTutorial 5: AIM9 Launcher Display Set
This set is intended as a STATIC DISPLAY ONLY. Comprised of six parts, this Set uses two magnets to attach to the side of the fuselage. An AIM-9X head is also in the works if you want to depict the F-22's recent HOBS capability.
What you'll need:
The six STL files attached below
4pcs Freewing magnets 26mm x 4mm x 2mm (This is the common magnet used in all Freewing ordnance, pylons, and most battery hatches) or similar
2pcs Freewing screws M1.75x5mm or similar
Steps:
1) Print the STL files
2) Paint and detail the parts as desired
3) Attach the two door halves with the two screws
4) Glue the missile parts together with hot glue
5) Glue the missile to the launcher with hot glue
6) Glue that assembly to the main assembly with hot glue
7) Glue the magnets in with hot glue. There are four holes available, but only the upper two are needed.
8) Mark and score the magnet positions in the fuselage.
9) Remove the required foam and glue in the magnets. Be sure to double-check the polarity before gluing!
Check your references such as these online photos for color and detailing ideas:
What are the six STL file names?
this is the symmetrical aim9 baseAttached Filesrc flyin addictComment
tip, tube and base with the cut offrc flyin addictComment
these are the files I have for the launcher and rail but I have not printed themrc flyin addictComment
Hey there,
great work here!
I've just ordered my F-22 90mm and can't wait to get it 😁
Will try to ramp up her scale level quite a lot in nearly every area 🤣
So let's see what we can achieve 😎
BenComment
Best, LB
