New Avios Mig 17 ?
    Thanks! The arctic camo does nothing for me. Even regular camo is iffy. That's why I repainted the 90mm F-4 in Blue Angel. Probably the 20 years in Naval Aviation...
    I am a huge fan of the Arctic Camo scheme but man that red looks HOT Evan!
    Thanks!
  • RanGee
ID:	210021Click image for larger version
ID:	210020 Maiden day today. Flew surprisingly good. Easy 4 minutes on 6200 and easy 5 on 8000. Other than some trim no issues at all.
    Looks awsome Evan, great job with the red/silver scheme!
    Originally posted by RanGee
    Nice collection!
    On the Russian side, I own the Mig-21 and the Mig-17. I used to own the FW SU-35 and the FLyFly Mig-29 but soled them both
    Thanks. My favorite of all my jets and maybe even all my planes is still the SebArt Mig-29s. I may get a chance to maiden this 17 tomorrow and see how it fits in my fave list.
  • RanGee
    "The Russians are coming, the Russians are coming"! My hanger is full of them.
ID:	209901Click image for larger version
ID:	209902Click image for larger version
ID:	209903Click image for larger version
    Nice collection!
  • vduniec
    Thanks a bunch! Already printed some out. The OEM doors are very brittle.
    Just uploaded the Mig gear doors to thingiverse however it takes 24 hours before it gets published.
    https://www.thingiverse.com/thing:3800059
  • vduniec
    Looks really nice, Evan. Can’t wait to see it in person.
ID:	209857 Pitots on... they are a pain.
    I was asked about the paint I used. Pictures worth a dozen words. This is my first time using this paint and I’m not sure I’d use it again. I bought it all at Wally. The one I went to didn’t have primer so I used the granite. Took about a can and a half. Then I did the chrome. It turned out perfect, looks like aluminum. Then the Apple Red... notes... the foam on this is soft and dents easy, it’s not a FreeWing. The original paint peels off really easy. I’ve complained about FreeWing paint before but won’t again after this.
    The paint is fair, it covers well and dries reasonably quick to the touch, about a half hour. I let it dry a day in my attic workshop between each color and the clear coat... says 48 hours but I gave it 24.
    Wally has a no name paint that would probably be better and Model Master is definitely better (though expensive)...
    Use very low tac tape. Click image for larger version
  • RanGee
    Had a great day today at the field! Thank you Borntoolate for the awesome pictures!Click image for larger version  Name:	2019-08-11 (12).jpg Views:	0 Size:	33.6 KB ID:	209878Click image for larger version  Name:	2019-08-11 (11).jpg Views:	0 Size:	32.0 KB ID:	209879Click image for larger version  Name:	2019-08-11 (10).jpg Views:	0 Size:	107.0 KB ID:	209880Click image for larger version  Name:	2019-08-11 (9).jpg Views:	0 Size:	134.6 KB ID:	209881
  • t01ga
    Very very nice job t01ga!
    Thanks buddy. I am looking forward to your afterburner.
  • RanGee
    Originally posted by t01ga
ID:	209845Click image for larger version
ID:	209846Click image for larger version
ID:	209847Click image for larger version
ID:	209848Click image for larger version
ID:	209844 Some rivet detail...
  • t01ga
    Cool! I did some work on mine too...
ID:	209850Click image for larger version
    That is literally awesome!!!
  • t01ga
  • themudduck
    RanGee, that's cool, thanks! I printed and installed the tail skid, it fit perfectly and it's exactly what this plane needed. I flew three flights today. With the Admiral 5000 stuffed as far forward as possible, it still checked out tail heavy (a bit more than 1/4" further back than the manual's recommendation) but flew perfectly. When I flight-tested the balance (by flying inverted) it was not tail heavy. We're going to need to move the battery strap. It's not possible to secure the battery even with the strap all the way forward.
    I found it somewhat difficult to land, because it floats like no one's business all the way down the runway in ground effect. I discovered that it lands well on the grass at the end of the runway! You definitely need to slow this one down on final - and I need to do more flight testing to see how slow it will fly! I was landing with half flaps with the speed brakes deployed.
    I did need some up trim after takeoff. I found the elevator response to be normal but the aileron response was fairly soft - I have my controls set up with the control rods on the next-to-the-last hole so I think I may move the aileron control rods to the outer hole. And - its not extremely fast but flies really well. Stable and easy. I really liked it.
  • RanGee
    Elevator servo covers:
    https://www.thingiverse.com/thing:3801989
    Main landing gear doors:
    Both published now and ready to be downloaded
