  • Airguardian
    Old flights that I forgot to post...
  • Airguardian
    Yes. :)
  • jasmith41
    More pre-crash, no VT:
    6s and stock fans?
  • Airguardian
    Indeed, so much more stable and predictable with the stabs getting clean airflow! :p
    I think I have another couple of un-vectored videos to go (not counting pending air to air stuff that god knows when I'll find time to edit) and then it's vectored videos only going forward ;)
  • GliderGuy
    Interesting how the inverted high alpha characteristics differ considerably from the non-inverted characteristics.
    Anxiously awaiting your first VT video post.
  • Airguardian
  • GliderGuy
  • Airguardian
    Thanks!
    Pre-crash period still.
    I swear you will KNOW when the video features the jet with the VT installed ^^
  • GliderGuy
    Post repair + VT added or is this video some pre crash period?
    Enjoyed it regardless. You are always adding to your maneuver suite.
  • Airguardian
  • Airguardian
    Only without TV nozzles ;)
  • radfordc
    This plane is like a high strung pony...fun to ride until it turns around and bites you in the butt!
  • Airguardian
    Thanks GG!
    I didn't catch it on video this time but essentially another episode of bad-thrustline messing it all up.
    I was performing a kulbit and started at too low altitude. I didn't come out clean and immediately entered a high alpha lock. Had only some 15-20m clearance and it wasn't enough to pull out so I pancaked straight to the ground. Fuselage cracked in half in two spots, ducts slightly crushed and broken (nothing too bad), nozzles came out and a few other areas in the fuselage got cracks. Most of those have been fixed already, I'm waiting for the glue to dry and I'll start re-installing the ducts and adding the TV nozzles.
  • GliderGuy
    Congrats radfordc for the comeback! ;)
    Update: I am almost done repairing my MiG-29 after my later crash, and this time I'm adding the TV nozzles, so expect some interesting stuff coming up soon on my end! ^^
    (Though I still have a few unvectored videos to publish! ;) )
    The crash / What happened?….If you don’t mind sharing.
    Your inverted high alpha flying looks impressive!
  • Airguardian
  • jasmith41
    Originally posted by radfordc
    I flew my new Mig today. I don't mind saying I was a little nervous after destroying one last year. Three good flights with no squawks.
    You have bigger balls than me thus far. I still haven't even flown my EF SU-30 i bought and built a year ago, let alone unbox the Mig-29 I have...🤣🤣🤣
    And now i'm thinking i need the FW SU-35 to learn on...
    Congrats!
  • radfordc
  • jasmith41
    Mine is about 5mm behind the marks but sometimes I do 10mm. I do have the full span reflex in mine and TVs. Before the reflex and TVs I was a little further aft, 10-15mm behind the mark.
    Thanks man...
