Does anyone know what's the voltage range for bluebox that comes installed in mig29? I tried to look around but could not find any official figures.
Reason I ask (and apologies for long read):
My stock elevator servos (and the replacement sent by motion) were vibrating big times and after motion sent me a replacement for the originals I didn't even want to go back.... I replaced stock elevator servos with hitec 5245mg (drop-ins) and problem solved (replacements servos are as smooth as it gets).
While I was trying to figure out elevator vibrations (and before swapping out stock servos) i replaced stock BEC with basic Castle 10amp v1 BEC and set the output voltage to 5.1v but I noticed that caused chattering and (minor) deflections in control surfaces (ailerons, flaps, rudders)... but when I increased the output voltage to 5.3v all chatter/minor vibrations went away and I was even able to do an uneventful maiden today. I am using Spektrum AR637T receiver.
I'm afraid that I might fry the blue box at 5.3v - anyone knows the real voltage numbers bluebox can support? also, any idea why I would have gotten the servo movements on 5.1v but not with 5.3v?
LOL - After several thousand flights on it, the FW MiG-29 remains the favorite of all my birds to fly...scale gear or not.
This is one well designed "wear tolerant" airframe....no fatigue cracks...nada/zip. Other than the occasional landing gear servo replacement, when one becomes intermittent, or a control servo replacement, when one begins to chatter...she's one tough bird.
As an update to prior posts, I've made a large number of landings after the replacement of the not-designed-to-be-replaced main gear plastic mounting box...some post-repair landings were not so good. It's holding up extremely well / better than I expected.
If you missed the details, below is a link to the prior post / how to do it.
#5186
Dec 12, 2021, 08:43 PM
Followed with more info in post 5187
-GGLeave a comment:
I just wanted to share that I had a dream last night that I owned this Mig-29. That is all
If grass is really that big of a problem, you can always just remove them. Then it can look unscale as this one does. ;)Leave a comment:
Nothing in this model offends me as much as the main gear. How it is solved by Freewing is profanation;). If they had done it from the fuselage and not from the wings, it would have looked better.Leave a comment:
... and there ya go! Ingenious, my friend! I have always wondered why Freewing just didn't make this scale in the first place. It really would have taken no additional thought.Leave a comment:
Yep... unpopular. But it is your opinion. Maybe you should have DM'd if you really wanted to keep it on track?Leave a comment:
This will be an unpopular opinion, but should these 'brave people' had not been 8 years crushing down on the freedoms of their countrymen in the East, they probably wouldn't have to fight for theirs now.
All war is horrible, but people seem to forget this one didn't start yesterday and that people being branded as heroes today have been murderers for a long time.
Not necessarily defending Russia on this, but Ukrainians have their hands filled with innocent blood too.
And we'd better not turn this thread into a political cesspool anyway, I'd suggest, feel free to DM your objections so the thread can stay on topic.Leave a comment:
Outstanding report. I've seen several accounts on the internet and Youtube today with similar reports and accounts, but this video seems to include some specific data on the aircraft that the Ghost (what an superb handle :ghost:) apparently shot down that I did not see in any others. Thanks for sharing this!!! All of the reports I've seen also indicate that this may be a rumor at this point or if any of it is true the numbers may not be accurate. The first air combat ace in 25 years and the first in over 50 years to do it in one day!! WOW, I sincerely hope that it is completely accurate, but if only a portion is (or even just a well planted rumor), kudos to every one of those brave Ukrainian pilots and to the soldiers and even the citizens doing their best to defend their country and their freedom. Too bad our politicians have not had the b.... to help in any meaningful way. My next Mig-29 build will be definitely be the Ghost Mig!Leave a comment:
That will work Pat. Thanks for the heads up.
Good to know Hugh. Thanks!Leave a comment:
Ironside if you can't get them printed for you, MRC has a few of those left in stock (6 I believe) and they are wing tip skids, SKU:DUB991 made my DuBro. Hangar Nine also used to make those in various sizes that I've used before and I think you can still get them on Ebay.Leave a comment:
Why not just buy some Dubro wingtip skids (which are what's pictured)? https://www.motionrc.com/products/du...20974166376561
These would not work as skids. The plastic is very thin and would scrape off the first time you dragged the tail. The Dubro skids are thick nylon and would stand up to several scrapes.Leave a comment:
We had a pilot lose control of his over the weekend (he also lost his F-22 so it was a very bad day for him). During flight he lost pitch control with the plane having and holding a full up pitch attitude. At the crash scene he found both elevator servos locked full up. Not to second guess anything else but I assume he had both servos going to the MCBe as he typically built things by the book. Sounds similar?
Thanks for the suggestion.
I actually changed the wiring to powerbox cable before the maiden. I’m also using savox servos which on 7.4V put out 15kg of torque. (To be fair as they’re only running at 5.1V it will be much less, but far more than the stock, even upgraded stock ones which are rated at 4.5kg)
Curious that both servos would do anything odd at exactly the same time.Leave a comment:
