  • fredmdbud
    • 451
    Originally posted by The43rdHammer
    Hi all,
    Tell me I’m wrong if you like, but just throwing it out there.
    Is it possible that with the flaps down, at certain speeds and angles of attack, air is deflected from under the rear of the flaps up under the leading edge of the elevator, forcing the leading edge down and causing the aircraft to pitch down violently?
    Aside from the accuracy of the airflow illustrated, the plane wasn't anywhere near the ground. :/
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1676
      • Catalonia
      If a Version 2 of the MiG is released (who knows), it will be interesting to see what mods are done.
      If the best scenario turns out true and the scale shaft axis has been implemented in V2 (which is not super-likely but I'd like to see it), I'd have to sell mine to get the new one, lol
      • janmb
        Slow and low
        • 729
        Originally posted by 4qr1hu9n7
        How about just admitting "pilot error".? It's never the error of the pilot when a crash occurs. No. It has to be something else. Is this comment to your satisfaction ??
        A lot of crashing in general is indeed a matter of various pilot / owner error.
        But when a model start showing clear signs of having a very specific crash pattern, it is time to have a hard look at the specific models, as well as the specifics around the reported crashes. And in the case of the MiG, there is absolutely no ambiguity about whether or not it had/has issues at this point. The vast majority agrees that it does, including MRC who are withholding further batches.
        • janmb
          Slow and low
          • 729
          Even if that was the case, that alone would in my view most likely not solve the issues. It would certainly help, and be a very welcome change regardless, but unless the torsion strength in the tail sections, as well as the elevators themselves were improved, I think we'd still have issues.
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1676
            • Catalonia
            Today, after 67 flights and some touch and goes one of my landing gear legs came free... the whole plastic box unglued.
            Thankfully I was able to catch it before take-off so no accidents ensued. Add to your preflight checklists if it isn't there already to check for landing gear integrity regularly, preferably before each flight.
            Will try to tear the rest free from the fuselage and epoxy it back in.
            Consider that with the scale shaft, the loads would unload (pun intended) further ahead in the fuselage at a point which is much stiffer due to sheer volume of foam, so the torsion should be gone. The stab would also flex less itself from the distances of the trailing edge to the hinge-axis reducing.
            With better servos, pushrod linkages and power distribution/wires, the rest should be a no brainer.
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1676
              • Catalonia
              Just... what a fantastic jet!
              If only Freewing made a Su-57 or 30SM in this size...
              :cry:
                • 2709
                Outstanding flights and great videography, quite majestic! As close to a religious experience as I'm likely to get! If MRC doesn't bring this back, I'll have to boycott them forever!
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1676
                  • Catalonia
                  Hahaha! Thanks, I'm more than confident that they will!
                  • GliderGuy
                    • 1412
                    Beautiful flying! Thanks for posting these.
                    A good pre-flight visual clue is that the vertical main gear shafts are no longer vertical...but splayed outwards.
                    I have run up against this (reference my prior posts). I found that epoxy isn't the best/total solution. It is better to use FoamTac glue for re-attaching the plastic box. Epoxy alone is too brittle. I had my box break loose again after repair. FoamTac is more able to withstand the shock w/o fracturing.
                    The more permanent fix is a bit more involved and consists of the following:
                    After re-attaching the plastic block with FoamTac....(note..work one at a time because you need a secure anchor for the rubber band mentioned below)
                    • Carbon fiber sheet glued to the vertical wall (inside nearest the fuselage center) with epoxy. FoamTac would work most likely just as well. Be sure to remove the paint first.
                    • Metal 90 degree angle brace was then glued to the CF sheet and to the plastic box. I used one brace mid box, but you could possibly use 2 braces...one at the front and one at the rear.
                    • While the glue/glues are setting, attach a rubber band between the opposite side struts to ensure they dry vertically.
                    After the second repair with FoamTac, carbon fiber, epoxy, and the metal bracket/brace, the plastic box has not come loose again. I feel operations off grass will drive the need for this repair/modification almost without exception and sooner than for operations off pavement.
                    Note: I was not able to completely remove the plastic block/box. I was afraid of damaging the outer thin area of foam as the box was securely attached there. So, I opted to dig a thin trench around the inner areas of plastic box with a Dremel tool (could also use a razor knife) where the plastic box contacts the foam and squirt FoamTac into this trench. So far, with this and the CF and metal brace...the inside area of the plastic box has remained secure. The outside area of the box where the thin foam is has remained securely glued in place.
                    While a total removal of the plastic block would be best, I tried...and could not get it to come out without risking additional damage.
                    • duke
                      • Aug 2013
                      • 45
                      Anyone remember the wiring( or the location number on this site) for the main ldg door opening and closing with the gear down?
                        First white wire in from the red and black.
                        • Airguardian
                          Post Stall Svengali
                          • Aug 2020
                          • 1676
                          • Catalonia
                          Thanks!
                          That's exactly how I noticed it (already in take-off run but I aborted as I saw this).
                          Thanks for the heads up.
                          We don't have Foam Tac around here and although I use something similar (UHU POR) it gets brittle with age so I tend to avoid using it for certain applications.
                          I managed to get my hands on some Gorilla Glue though... maybe I could test it out.
                          • Justwingit
                            • 46
                            • Las Vegas, NV
                            So here's Brent Hecht's Uber-Cool Luftwaffe repaint of his MiG-29 Fulcrum out at Rabbit a while back...😎
                            Be sure to watch as the canopy and pilot decided to DEPART the model in mid-flight 😲😂!!!
                            Enjoy 😁!
                            • sfcfury
                              • Mar 2019
                              • 490
                              • Baton Rouge, La
                              Enjoy 😁!
                              Well I saw the problem.... looks like at 1:25 an AMRAAM went streaking by... pilot didn't want to wait and jumped ship!!
                              • The43rdHammer
                                Smithy
                                • Aug 2019
                                • 118
                                • South East England
                                For those interested in doing more research on the topic, I leave this here:
                                https://www.nasa.gov/pdf/601262main_...ight-ebook.pdf
                                Thanks man... I didn't understand half of it, but the rest was only a complete mystery to me 😂😂🤣
                                • skybolt
                                  • Aug 2020
                                  • 24
                                  • South Wales UK.
                                  This is the easiest way no soldering. https://www.youtube.com/watch?v=oHdu3qAWwGI&t=2s page 70 for the other method
                                    • 2709
                                    So it looks like no matter if there are any upgrades to the Mig or not, based upon MRC's new price increases starting May 15th, the Mig will now cost a minimum of $64 US more without any changes. That puts it at $703 US base cost without any changes.
                                    And no doubt it won't be brought back before May 15th, cause if it does, definitely hitting the buy now option.
                                    • Griffon Wings
                                      • Mar 2020
                                      • 155
                                      Auch ! :hot_face:
                                        • 8814
                                        YIKES! That puts this plane into very exclusive territory for a foamie. There's something about going into that next 100 dollar threshold that sounds too much. If I were after this plane now and saw that price tag, I doubt I would jump in. Any newbies to this jet, would scan these threads and only see the posts and videos about the crashes and not look any further at the discussions about them and give further consideration to buying one. It was bad enough at 600 and something, but 700 and something is a psychological stumbling block for me, considering what I just bought for 600 bucks (Eflite Draco). Mentally, I consider the Draco to be a better value. But everyone has their own perception of such things.
                                          • 5401
                                          Motion says an average of 10% so it could be more or less. Interestingly I've had mine, with TV's posted for sale for weeks without a bite (granted at a rather high price). This tells me that, even though it's been withdrawn from sale over the crashes, there really isn't a very high of a demand for it.
                                          I wonder if FW and FL parts will go up too, it just says airplanes in the post. If they also raise the TV's 10% that's $803.
                                          There's a lot of if's in all this though.
