Think you need both reverse and forward ESC leads plugged in and reverse assigned to a switch for it to function correctly.
Official 64mm Freewing Banshee EDF Sport Jet Thread
Try the following:
Check that all 3 ESC to motor wires are pushed together tightly.
This plane has reverse thrust, right? Check that it's hooked up right. Perhaps you need to either reverse the throttle or flip the reverse switch.
You might want to lower the throttle trim to the lowest position and re-bind if the above doesn't work. If you do this, remember that throttle cut will have to be adjusted, too.Comment
It's working now after doing what Jake suggested. I changed the switch to one on the right side I never use. The plug is in my gear channel, and I don't want to crash thinking I need to put the gear down. So it's now reversing. That's a lot easier than on spektrum receivers.Try the following:
