Official 64mm Freewing Banshee EDF Sport Jet Thread
  • carypond
    • Oct 2022
    • 33
    Got it figured out !! Easy fix.
    • carypond
      • Oct 2022
      • 33
      Found out I’m running an inrunner motor in a outrunner fan. Do I need to get the V2 inrunner fan ? The 3100 inrunner motor does mate up with the stock fan and run. Will I get better performance if using the V2 fan ?
        • 5389
        There is no inrunner and outrunner 64mm V2 fan. Both the outrunners and inrunners use the same fan and shroud. And you can't mix up the fan from a V2 into an older shroud as the fan is a bigger diameter. You could have put the motor into an older fan and shroud, one from say a Stinger 64, or the earlier F-16 or F-22. But the Banshee originally had a V2 fan and shroud so you should be good.
        • carypond
          • Oct 2022
          • 33
          Thank you Evan for clearing this up !!
            • 5389
            Happy to help. If you read between the lines anyone that has the Banshee or any plane with the V2 fan (2840-2280kV outrunner as stock in this or the F-16 and F-22) can swap in the 6S 2949-2500kV inrunner and have an awesome plane. Of course if going to 6S you need a 6S ESC capable of handling the amps too...
            • carypond
              • Oct 2022
              • 33
              Yes, will be putting in a 60 amp esc. Will take out the stock motor and esc when Banshee comes in from RC Castle and replace with 2500 kv motor
              • carypond
                • Oct 2022
                • 33
                Just put together the <a href="tel:2949-2500">2949-2500</a> freewing motor with 60 amp esc on the Banshee and Wow !!! What an improvement !! The 2500 puts out 1930 grams of thrust, where the 3100, I had in it only put out 1300 grams thrust. Running CNLH 2200 mah 6S packs in it. Get5 minute flights with 32% left. I was not pushing it hard on the initial flight. Got it set up on FPV. Video to follow.Click image for larger version
                  • 5389
                  Welcome to the dark side!
                  • carypond
                    • Oct 2022
                    • 33
                    Been here since 2017 !!
                      • 5389
                      The dark side of crazy power
                      • DougCLind
                        Hobby Squawk Pilot
                        • 30
                        • Roan Mountain, TN
                        ok, I'm having the same problem that Cary Pond had in getting the fan tightened down on the shaft. In my case I'm using the 6S 2500kv motor and the stock fan and shroud. I bought it from rc castle and after 40 or so flights the fan flew off the shaft, chewing up the foam a little and destroying itself in the process. I bought 2 V2 EDF units from Motion and tried to put the motor on and assemble it all together but I couldn't get the nut tightened onto the shaft. I finally gave up trying to tighten it more and put a drop of loctite on the shaft and tightened it up the best I could. So that's lasted about a dozen flights and the fan flew off again, destroying itself and chewing up a little more foam.
                        So for those who have more mechanical talent than I do, is there a secret here to doing this? Or do I need to weld the darn thing on! Maybe I need stronger glue?
                        • DougCLind
                          Hobby Squawk Pilot
                          • 30
                          • Roan Mountain, TN
                          Beyond my vexation at trying to put the fan on the EDF unit, I actually have a couple of things I can contribute to the discussion.
                          People were just talking about batteries for the 6S Banshee and I've been doing a lot of work in that area. People should check out this video from Tail Heavy Productions:
                          He's done a lot of battery testing and he talks about the big scam of C ratings. But one of the takeaways I got was a heads up on SMC batteries, which I had never heard of before. I checked out their website and for those of us flying 6S Banshees this 2400 mAh LiHV battery looks awfully good. I've ordered two of them. LiHV charge up to 4.35 Volts/cell. That gives you .9 Volts more than a regular LIPO and the weight is only 320 grams. But you do need a charger which can handle charging LiHV batteries. Not all can.
                          I fly with either 284 gram, 1800 mAh Spektrum SMART batteries, (which have outperformed their rating pretty consistently) or a pair of Roaring Top 3S, 2200 batteries in series. The total weight of the 2 RT batteries is 322 grams and I do get more flight time with the pair. Those SMC LiHV batteries weigh the same as the pair of RT batteries with 200 more mAh on the label and the boost in voltage. So we'll see. I'll give them a try and see. The guy in the video says a lot of things that I know are true and he's found other batteries that test well besides the SMC.
                          I've been doing a lot of work incorporating telemetry data into my flight log program over the last few months and I've derived some very helpful info. By analyzing voltage and current data I can calculate exactly how many mAh are expended during a flight and compare that to what's remaining in the battery after every flight. So I now have a way to see just exactly how good any battery is. Since all of us EDF flyers live and die by our batteries, this is sort of a top priority to know.
                          Here's a screen shot of telemetry data from tonight's flight with my 4S Banshee (I have 2 Banshee's.) I used one of my 2700 mAh Smart batteries and as usual it outperformed its label rating.
                          • Tipstalled10
                            • Sep 2023
                            • 21
                            • U.S.A. Georgia
                            Can someone tell me the wire diameter of the stock landing gear? Thank you !!
                              • 5389
                              If you look up the wheel it probably will tell you.
                              • thedarkwraith
                                • Apr 2024
                                • 13
                                I can tell you that Du-Bro low bounce 2" wheels fit perfectly on the front and rear (I have the upgraded gear).
                                Cat. # - Diameter Axle Dia. Weight Width
                                200T or R - 2.00" (50.8 mm) 1/8" (3 mm) 17 grams/wheel 0.750" (19 mm)
                                I bought my Banshee from AliExpress for $99. I got the 6S version with the upgraded landing gear. I can tell you it's a screamer! The Spektrum Radio ID module clocked it at 106mph in level flight.
                                I use Zee graphene 6S 2200mah batteries in her. Replaced all the wheels with Du-Bro low bounce 2" wheels because we are on a grass field that is very bumpy. You need to remove the weight from the nose if you are going to use 6S. It is one of my planes that I fly all the time when I go to the field. Very fast and very fun! Don't get it slow or it will drop a wing fast.
                                • xargsgrep
                                  • Jul 2021
                                  • 56
                                  Just got mine setup but I can't seem to get the CG correct. I'm using a 4S 2200mah 30C spektrum smart battery which is about 270g. With the battery all the way forward the plane is still extremely tail heavy on the default CG line. Do I need to get a heavier battery or am I doing something wrong? Any recommendations for a 35C+ battery that will result in a proper CG?
                                    • 5389
                                    Get a bigger battery. But I balance mine on the wire channel under the wing.
                                    • xargsgrep
                                      • Jul 2021
                                      • 56
                                      Got it, so you don't use the default CG marking and it still flies fine from the CG you have it set to? Ie, it's not heavily out of trim or anything like that?
                                        • 5389
                                        No, flys better than at the marks. Many jets are very nose heavy at the book CG spot.
                                        • jrguevin13@gmail.com
                                          • Jul 2025
                                          Are the servos that come with the Freewing Banshee 64mm fine or do people replace them with metal gear?
