  • paulrkytek
    • Jun 2019
    • 530
    • North of England
    todays test flight with new 1920kv 9 blade in-runner went well. sounds good, plenty of power flew off grass 1/2 flaps into 5mph wind no problem.
    • paulrkytek
      • Jun 2019
      • 530
      • North of England
      After previous flight in totally grey skies I decided to improve visibility with a few more red highlights, now moving towards Russian Knights colours. For some reason the external shots are pink as opposed to the internal shots which are the correct red ?
      • rms
        • Nov 2020
        • 63
        • Senja, North Norway
        Began to fly low High Alpha stuff...got to low speed on a dogleg landing, ending i broken landing gears...So nice this types of planes are easy to fix...
        • rms
          • Nov 2020
          • 63
          More Mig 21 flying
          • rms
            • Nov 2020
            • 63
            Originally posted by paulrkytek
            Installed new Freewing 9 blade 1920kv in-runner in the Mig today. Very well balanced fan out of the box. Thrust feels good. Will test fly tomorrow. Power meter readings static in the plane on a 6s 4500mah 40c zippy. 24.6v 85 amps 1997 watts.. For anyone interested I found basic motor power details on this link : -
            https://fr.aliexpress.com/item/40010...19419660%22%7D
            Very nice colors 👍
            • rms
              • Nov 2020
              • 63
              More Mig 21 flying...Very nice flying plane. Did a nice last landing👍
              • Dave Wave
                • Sep 2019
                • 18
                Is there a 3DP .STL file for a centerline fuel tank for this model? I did not find one on Thingiverse.
                Thanks!
                • SanExup
                  • 912
                  • Western Wy.
                  Dave Wave I've seen two Mig21s with centerline tanks. They just used one of the supplied tanks and installed the mounts from a spare plastic parts set from another plane. I can't remember the which spare parts set but it looked like such a clean and easy mod that I plan on doing it on my Mig and maybe on the Mirage as well using a smaller tank than the scale ones supplied.
                  • T- Elbert
                    • Sep 2020
                    • 98
                    • Helena, Montana
                    San exup is correct , I did a centerline tank
                    mod on 2 mig 21’s using the stock tanks and hardware then added rocket pods to the wings
                    • MeyerVW
                      crash test pilot
                      • 288
                      • Dude who likes flying.
                      Thinking about one of these. I see the blue version now has a 90mm fan. Has it always had that? How does it compare to the silver 80mm version? I fly off asphalt.
                      • paulrkytek
                        • Jun 2019
                        • 530
                        • North of England
                        80mm on USA and EU website so where did you get that info ?
                        • MeyerVW
                          crash test pilot
                          • 288
                          Motion rc site say new motor and fan.
                          Features:
                          • New! 90mm 9-blade ducted fan and powerful 3658-1920Kv brushless inrunner motor provides awesome power and incredible real life jet turbine sound
                          Is that an error on their end? Seems like that should say 80mm.
                          • MeyerVW
                            crash test pilot
                            • 288
                            I bought the silver/green version. Happy to have one one the way.
                            • paulrkytek
                              • Jun 2019
                              • 530
                              • North of England
                              • NEW! Powered by a new 9-blade EDF with all-new 3658-1920Kv brushless inrunner motor and 100A ESC is what it says ight now but definitely80mm not 90mm so are you sure ????. the 3658-1920kv motor refers to the 80mm edf, I have 3 of them in my Avanti, L39 and the Mig 21 in my post 784 above.
                              • radfordc
                                • 375
                                • Lansing, KS
                                Features:
                                Pretty sure it's a typo.
                                • MeyerVW
                                  crash test pilot
                                  • 288
                                  That was only for the blue grey version. The green silver version did not say that.
                                  • paulrkytek
                                    • Jun 2019
                                    • 530
                                    • North of England
                                    USA site only, Typo , 2 places states 80mm, it states 90mm under the features part of the description, no doubt lack of proof reading once again!!! It Is supposed to be a new website layout so no doubt there will be a few anomalies.
                                    • Dave Wave
                                      • Sep 2019
                                      • 18
                                      I am trying to get the stock MLG wheels off. The grub screw looks like it has loctite on it and a 1.5 mm hex is a loose fit. I tried heating with a soldering iron, but no luck. Any tips/ tricks to getting the screw out?
                                      • MeyerVW
                                        crash test pilot
                                        • 288
                                        I have found that SAE allens will fit better in some metric grub screws. And some metrics will fit better in SAE grub screws. I use both knowing the hardware is most likely metric. Also put the allen in the screw and give it a few taps with a hammer to loosen it up. Heat works too sometimes.
                                        • MeyerVW
                                          crash test pilot
                                          • 288
                                          Here it is. Love the look I got and I am very happy so far. Waiting on a nose brace and fire booty. When flap are deployed is there any need for elevator trim?
