Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
  • 400driver
    • 46
    My friend Simon got his F35 airborne for the first time. He felt the gyro gain was too low and that it was very unstable in roll. I am lending him my programmer to increase the gyro gains. He commented that is was pretty good in pitch attitude on landing and that with the standard battery placement the CG was behind the factory suggestions.
      • 5398
      Now available at Motion.
        • 8789
        Right on schedule. RC Castle sold out their first batch. My friend got his earlier this week and has it built and ready to go for this coming weekend if the weather is good. Mine won't be available to ship till end of Sept.
        • flyjets01@gmail.com
          Flt Test
          • Apr 2026
          • 28
          • Western NC
          Buy Freewing F-35C Lightning II 12S 110mm EDF Jet with Gyro - PNP online at Motion RC. Order online with fast delivery.
          Looks like it's in Stock just ordered mine.
          Management is doing things right; leadership is doing the right things.
            • 5398
            Yeah, my post two above yours...
            • Reaper911
              • 90
              • Winterpeg, Canada
              Originally posted by 400driver
              Both F35 s arrived, my friend unboxed his today and was a bit dissapointed with the fuselage join. I will look at mine next week as I am away. Will post a picture on my return.
              That is rough
              • 400driver
                • 46
                Yes , mine is not the same but from a distance it’s not really noticeable.
                What is interesting is that the stock gyro setting are not enough or were not correctly set from the factory. He reported that it was pretty unstable in roll , not so much in pitch.
                He did not have a program box at that stage so I lent him mine and we looked at the settings and adjusted them upwards. He has flown it since and is much happier.
                i enclosed his settings. The CG is better with both batteries side by side rather than split as suggested. The CG is at least 15-20 mm behind the factory recommended mark.
                Nice and floaty is his feedback to me.
                • Giovanbattista
                  • Sep 2026
                  • 3
                  How the small wheel's gyroscope works
                  • Giovanbattista
                    • Sep 2026
                    • 3
                    And are the gains for the small wheel independent, or are they the same as for the main wheel?
                      • 8789
                      You must be referring to a "steering gyro". This is a built-in feature (pre-programmed). It helps the plane track straight down the runway. Also, when gear is retracted, the steering on the nose wheel is defeated. I'm not sure the gain for the steering gyro can be adjusted. If it works properly, leave it alone.
                      Why would you have "gains" for the main wheels? They don't steer. They also don't have brakes, so anti-skid gyro is not needed.
                      • Giovanbattista
                        • Sep 2026
                        • 3
                        Alright, thanks a lot. We’re eagerly awaiting its arrival here in Europe, but it seems there are transport issues due to current events, so it’ll take about another month. Let's hope it arrives sooner.
                        • Tygerman42
                          • Jul 2025
                          • 11
                          You cut off the top and the basic roll gain. We can see the auto level settings, but not the basic gains above.
                          • 400driver
                            • 46
                            Thanks for spotting that , they have now been raised to 50 on each. Better results.
                            • Shaun Evans
                              • Apr 2021
                              • 122
                              • California, USA
                              What are the main and nose wheel diameters?
                              • Fast N Light
                                • Apr 2021
                                • 113
                                Are you replacing the wheels or hoping to use them on another model?
                                  Flt Test
                                  • Apr 2026
                                  • 28
                                  • Western NC
                                  Has anyone tried adjusting the LED Afterburner for a more realistic setting. I can't find info on how to do this.
                                    • 5398
                                    No way to do this. If you want it different you need to put it on it's own channel with a mix to the throttle and alter the mix setting to suite your needs.
                                      Flt Test
                                      • Apr 2026
                                      • 28
                                      • Western NC
                                      Thanks Evan it's a real Rats nest the way its shipped. I will hunt around for the connection. I changed the EC5 to XT90.
                                      I'm curious to see how many Amps it pulls with the LHIV charged to 4.35 volts. Should know in the next few days.
