Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
I don't remember but around 59-60% and just at 3.9V. I'll probably add another 30 seconds for my next flights.
She really floats, doesn't she? This is the only plane I have to use full flaps landing to get it slowed down.Comment
Evan I think it's the weight that keeps it's moment up. Reminds me of my larger Turbine models.
Ian
Management is doing things right; leadership is doing the right things.Comment
Hi Evan, so did you use the Flapperon setting? If you landed with the flaps down and then retracted them to use a single aileron… thanks
Giovan, I'm not sure if flapperon is the correct term. I think that would be your ailerons also acting as flaps (or full span flaps). I pulled the flaps from the MCBe and mixed full span ailerons. So when on the flaps act as ailerons so it is full span ailerons. I am using them every flight. I have the mix on mu retract switch so when the gear are down they are not active and I have standard ailerons and standard flaps. When the gear are up then the flaps are mixed with ailerons for full span ailerons.
Oh, okay, Evan. I get the model now—you’ve just been experimenting with different mixes. If it gives you such amazing results, I’ll give your great idea a try.
