Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
    • 8826
    Originally posted by flyjets01@gmail.com
    Evan what's your Cell % after 7.5 min?
    Here is my Maiden.
    Watch this on YouTube and select HD. As seen embedded here, the quality is at 240p, very fuzzy. HD is MUCH better.
      • 5409
      I don't remember but around 59-60% and just at 3.9V. I'll probably add another 30 seconds for my next flights.
      She really floats, doesn't she? This is the only plane I have to use full flaps landing to get it slowed down.
      • flyjets01@gmail.com
        Flt Test
        • Apr 2026
        • 31
        • Western NC
        Evan I think it's the weight that keeps it's moment up. Reminds me of my larger Turbine models.
        Ian
        Management is doing things right; leadership is doing the right things.​
        • Giovanbattista
          • Sep 2026
          • 26
          Hi Evan, so did you use the Flapperon setting? If you landed with the flaps down and then retracted them to use a single aileron… thanks
            • 5409
            Giovan, I'm not sure if flapperon is the correct term. I think that would be your ailerons also acting as flaps (or full span flaps). I pulled the flaps from the MCBe and mixed full span ailerons. So when on the flaps act as ailerons so it is full span ailerons. I am using them every flight. I have the mix on mu retract switch so when the gear are down they are not active and I have standard ailerons and standard flaps. When the gear are up then the flaps are mixed with ailerons for full span ailerons.
            • Giovanbattista
              • Sep 2026
              • 26
              Oh, okay, Evan. I get the model now—you’ve just been experimenting with different mixes. If it gives you such amazing results, I’ll give your great idea a try.
                • 5409
                I wanted more roll rate but didn’t want to do tailerons since I am using the stock gyro.
