Originally posted by Klikmaus
View Post
If this is your first non-RTF using a programmable gyro RX, the biggest concern is how you set up the AS3X and SAFE. I'm sure all your previous RTF/BNF have the RX pre-programmed. Read up on what gains/priorities to use for your plane and how to test it all out before taking to the air, making sure the gyro responses are all in the correct direction and AS3X can be switched off via a switch. Many a maiden crashes have occurred when gains are too high and/or when "head gain" is used when it should not have been or when gyro response was reversed. Also understand what "fixed" gain and "variable" gain is and what it does.
