  • Chris F
    Originally posted by Radar-Guy View Post
    Highly recommended!
    Replacement of the stock thrust tube to a more scale appearance. Added upthrust to help reduce down pitching with throttle applied.
    I currently have the V1 A10 and fly with my CG at 95mm. I have printed the new thrust nozzles but would like to know if I should now move my CG forward? Thanks for any help.
    CF
  • Reptielenfreak
    Originally posted by Andyb1029 View Post
    Morning all
    I'm looking in to getting the Freezing A10 and apologies if this gets asked a lot.
    Is there a list/record of all the mods so I could make an ultimate A10, add ons, mods, improvements and tweaks. Does anyone sell mods ready to install as I don't have a 3D printer and work away on ship a lot so things already painted would be ideal.
    This is the package I'm looking at, any recommendations for the electronics such as Gyros, and such that would dramatically help out with balanced flight and keeping her steady for take off and landing?
    Well everyone has his own list but i fly of grass and very bumpy runway with a real gear bender/braking reputation.
    nose gear mod: railer link and 3d printed brace (must i.m.o)
    Main gear mod: 3d printed brace.
    i have the as3x /safe reciever but i only use it when landing, in flight only AS3X.
    I use the landing flaps with up elevator mix since this i never made a bad landing again. this model is well known of bumpy landing when you dont land it the right way causing it to bump the nose gear badly.
    Im a big gyro fan because it helps out with smoother flights.
    I think the 80mm is fast and strong enough. I fly with 5600 80c packshot and get 7min with storage volt left in the packs. But im thinking about going to 5000mah.
  • Andyb1029
    Morning all
  • Corsec
    LB, thank you sir. I went ahead after reading your post and just worked around the edge with x-acto and then worked the nozzle around some. It did come loose with a little paint :-) but as you say nothing shows with the new nozzle in place. Thanks so much!
    Originally posted by Corsec View Post
    Got the printer running again. Side note, stepper motor Anti-corrosion coating had began to come off stator and was causing excessive dragging this the motor issue, ultrasonic cleaner for a couple minutes and clean up with a plastic bristle brush runs like a champ again.
    Got the nozzles printed. But how to remove the stock nozzles without tearing up foam? Any pointers? They seem to be glued in? I can’t see any glue but they are firmly in place. Get rough with it? Or is there a secret to taking them out?
    thanks!!
    CS, As I recall, I cut the OEM nozzles in a couple places fore to aft. I pried up on an edge without much damage. In any event, clean up was minimal and not much shows after you reassemble the nacelles . Hope I've helped. Best, LB
  • Corsec
    thanks!!
    commented on 's reply
    CS, now that truly sucks. Best, LB
  • Corsec
    Went to print them and my x axis motor crapped out. Ah well. Next weekend!!!
    Highly recommended!
    RG, I know, right?! What's not to like?! Thanks for including the the URL. Corsec, these nozzles by Dirty Dee are great and a drop-in install. Best, LB
  • Radar-Guy
    Highly recommended!
  • Corsec
    Thanks!! I will check it out.
    Does anyone know where to find an stl for modified exhaust nozzle to correct thrust line? Originally I had seen a post about them but the links to thingiverse returned 404 so I have searched and searched but no luck yet. Thanks!!
    CS, were the A-10a nozzles you are looking for on Thingiverse, designed by Dirty Dee?
    If so, DD has smartly moved all his designs to the Cults3D website.
    Check there anyway, his nozzle design is top-notch.
    Best, LB
  • Corsec
  • GliderGuy
    Originally posted by Warthog View Post
    Does anybody make parts to make the canopy open on the A-10?? Thank you. John
    See post below...scroll up to 9910 and read down to 9918 for more info and possible contacts who might help.
    #9918
    Mar 30, 2020, 06:07 AM
  • Warthog
  • starcop
    Originally posted by Elbee View Post
    starcop & Griffon Wings, There are myriad others who have accomplished much more. I will say that it is a rare thing when we have that epiphany and humbly realize how little we know. Best, LB
    It from guidance and, being prepared to know the difference. No such thing as Luck! When you enjoy when people smile, it should ring a smile back. Friendships are so important in life. (134) E-Flite Carbon Z Prometheus Taking It To The Limit! Fun Flight And Review by Merry Boozer RC - YouTube something to share with you.
  • Griffon Wings
    VOTE ELBEE FOR PRESIDENT !!
    Starcop , yours are Holy words. Nothing to add .
  • starcop
    SC, you flatter me, I was really an old dude during that time and considerably older now. Think 'Cold War' era and you're warmer. Best, LB
    Elbee, I have sincere heartfelt respect for you now. Those were difficult times for everyone in our past. You are still one Amazing person to us all, as we are younger and, should be still learning from you. I respect my elders as they should always be. The heart is something people our age can misinterpret the most. It took a lot more effort and heart in the past, to get through the war, segregation. I salute you, Sir!
    Originally posted by starcop View Post
    How about this for a co-pilot... They make a great team! Elbee, you were a Commander in Desert Storm per se?
