Official Freewing 70mm BAe Hawk T1 Thread
    • 2137
    • On planet earth....right
    Originally posted by bkjohns
    Does the new 'high performance' version include the upgraded landing gear with the oleo strut and springs?
    • Chilly Bear
      • Nov 2018
      • 61
      It does.
      • Chilly Bear
        • Nov 2018
        • 61
        Does the BAe Hawk high performance version come with push rod keepers for the elevator? I was looking up a part and saw this picture which is the spare push rod set. I didn't think I had those so I looked and I did not. I ordered a set after looking for keepers by themselves for a while unsuccessfully. The push rod set came, but no keepers. Click image for larger version
        • long-love-rc
          • Jul 2020
          • 91
          Can you experienced pilots please share how slow I can fly the Bae Hawk? I enjoy slow flying, like cruising... Will a 30% throttle plus half flaps be able to maintain level flight?
          • cashmoneybrother
            • Aug 2017
            • 69
            She flies nice slow
            • Whiskywhisky
              • Sep 2020
              • 2
              Hi from Germany,
              some day’s ago I bought the Hawk. Several times in this board people talk about operating on a grass field and how to prevent FOD through the cheater holes.
              Because our field is grass only I have made some parts for 3d-printing. I can’t compare if there is a difference when you use these parts or not because I didn’t fly without them.
              For those (as me) who have to operate the plane on a grass field I have made a protection to prevent FOD through the cheater holes.Just sand a little bit (if necessary) und glue the parts in.I have printed the parts upside down because the side where the raft was located, is not visible when build in. Support is not required
              Download files and build them with your 3D printer, laser cutter, or CNC. Thingiverse is a universe of things.
              • Randy H
                • 63
                • Surprise AZ
                Hello I have just gotten the Hawk and I am preparing for the maiden, this is my first edf model. I have only flown prop war birds in both electric and nitro engines for many years. After reading the majority of posts and looking at the maiden flights it looks like most of you are using flaps for take off. I fly off of a 400 foot paved runway here in AZ and was wondering if you all would suggest flaps for take off or not. Thanks in advance or the feed back.
                • Gremlin
                  Blue Good, Green Bad
                  • Dec 2018
                  • 8
                  • Ireland
                  Apologies if this has been previously covered but I just thought I'd share a little mod in case it hasn't and is useful to someone. Front leg support. I'm operating off grass and I found that the front nose oleo was getting pushed back even on mormal landings, so I designed up and installed a nose wheel support (similar to ones available for other front wheel edf jets). Link to the STL file is at the bottom of this post.
                  Remove the front plastic belly pan. There should not be this much glue in yours, I suspect. The first owner of mine got a bit too happy with the foam tac. Glue in the support brace.
                  Glue the belly pan back in place and your done.
                  STL file link
                  Hope someone finds this useful.
                  Happy Flying.
                  • Whiskywhisky
                    • Sep 2020
                    • 2
                    Happy Flying.
                    Hi, I printed and intalled it before the maiden flight and I think it is very useful. But I glued the part in without removing the belly pan, was no problem.
                    thx for sharing the stl-file
                    regards, Wolfgang
                    • GBLynden
                      • 198
                      • Lynden, WA
                      Originally posted by Whiskywhisky
                      Hi from Germany,
                      https://www.thingiverse.com/thing:4592286
                      Great work!
                      • TriStar
                        • Sep 2020
                        Originally posted by Richrfl
                        Hi people. After a while sitting in my hangar, I started to fly the Bae Red Hawk 70mm T1. I am having a lot of problems with the steering, and I would like some on to give me some clue on what's wrong with it. Running in the tarmac runway, at low or medium speed, everything works just fine, but when going closer to take-off speed, I have no control on the steering. Kind of the plane drives like a crazy squirrel. I do the take-off run at low rate in the steering, which is set with 32% expo, 10% throw. One thing that y noticed is that the nose wheel has (what I think) too much free movement. Therefore, the question is, if this is normal, or I have some issue either with the pin or the hub of the retract. Help, please!
                        I’m bringing up this post from a year ago, because I have the same problem. While I’m certainly not the best RC pilot, I have been flying for nearly 10 years, operating numerous taildragger aircraft that I somehow manage to keep straight. This is my second edf, the first being a beat up old Habu, that I can keep straight on our dirt runway. As in the post quoted, the nose gear (upgraded strut) has a lot of play, both rotating left and right, and the whole strut wobbling loose in the retract unit. I don’t use a flight controller. Any help would be appreciated. It’s downright embarrassing when I takeoff, so much so that my Hawk is in danger of becoming a static model.
                        • Richrfl
                          • Aug 2017
                          • 28
                          • Coral Springs, FL
                          Tristar, I ended up crashing my Hawk after a good landing (big pilot error after landing). Anyway, I bought a new one, and I found that I was not able to use the gear upgrade, which was an outstanding solution to the steering problem. The part to be blamed is the nose strut. I was expecting to have the steering problem again, but to my surprise, I did not. With the original and ugly wire gear, the steering works incredible well. Just for the sake of confirming, replace the strut for the original wire gear in the nose wheel, and see what happens. It is obvious that the strut has some design and manufacturing problem, as the tolerances are way out of mechanical standards and that causes the nose weel to move sideways, front/back, and even rotating at its own pleasure.
                          Good luck.
                          • Randy H
                            • 63
                            • Surprise AZ
                            Hi, I maiden my Hawk today and it flew great with no trim adjustment needed. This is a first for me because all the models I have flown since I started in the hobby in the 1970's have had propellers up front. The model is fast and can be slowed down quite a bit for some easy flying. Landing with full flaps was a little rough since I bounced it but the new landing gear took the punishment with no damage. I used an admiral 4000 40c and set the timer for 2 1/2 minutes. Landed and checked the battery and still had 65% left in the tank, so it looks like I can extend my flight time. This jet is rock solid in the air and a joy to fly. Looking forward to many more flights as I learn to master this edf and move on to my next jet.
                            I still love my warbirds (FW spitfire, FW190 and Bearcat, ME109 etc) but flying the Hawk brings another level to the hobby for me. Great job Motion RC.
                            • Adam1985
                              • Sep 2019
                              • 18
                              Hi all,
                              Sorry for the dumb question but can someone point me in the right direction on the MotionRC website regarding a new fan blade for the 70mm Red Arrow Hawk T1. I can see two types of 70mm fan blade, the first is called a ‘reverse’ flow blade and is in the spares section for this model. The same blade is available but doesn’t state reverse.
                              So two questions, which blade do I need, the non reverse or reverse blade? Final question is what does it mean by reverse? That the motor spins the opposite way and so to produce rearwards thrust the blades are angled in a reverse manner to normal blades?
                              Many thanks for your help!
                              Adam
                              • Richrfl
                                • Aug 2017
                                • 28
                                • Coral Springs, FL
                                Originally posted by Adam1985
                                Hi all,
                                Adam
                                I guess this is the fan you need: https://www.motionrc.com/products/fr...cted-fan-blade
                                I haven't seen any reverse fan in the model spare parts.
                                I am surprised you found there a reverse blade offering for the RAH T1. Normally you use a blade turning counter-clockwise when you look at the plane from the front. Even a reverse blade could be used, for what you have to swap one pair of the connections from the motor to the ESC, I do not know (may be someone smarter than me can give a more accurate answer) if the plane has any construction design which compensates for the torque produced by the fan. In Normal propeller driven planes they offset the axis of the motor relative to the plane longitudinal axis to compensate for the rotation. Reverse fan are normally used in dual EDF engines so that each one compensates for the torque of the other.
                                • Adam1985
                                  • Sep 2019
                                  • 18
                                  Hi all,
                                  I’m looking for a little advice on a good colour match for the Red Arrows Hawk. After a few flights the model has a few scuffs and scrapes and I want to fix it up with some paint; I’ve been looking at the Tamiya XF-7 Red (I like Tamiya acrylic paints as I know they won’t melt foam) but I was wandering if anyone had tried this paint and whether it matched well, or if not, what other options there might be.
                                  Many thanks
                                  Adam
                                  • radfordc
                                    • 375
                                    • Lansing, KS
                                    There is no concern about EPO foam melting from paint. Not even acetone will melt EPO.
                                    • Andre B
                                      • Apr 2019
                                      • 14
                                      Has anyone attempted a motor/edf upgrade. Am now very comfortable with this jet and could use a little extra to take off from grass. Any feedback is welcome.
                                      • JamesonC
                                        MRC fanboy
                                        • 619
                                        • Laurens, SC
                                        Which setup do you currently have in it? The 2210kv inrunner that comes in the HP version is a great upgrade if you don't already have that one.
                                        • ndrew3
                                          • Jan 2021
                                          • 41
                                          • SLC, Utah
                                          Hi all,
                                          Many thanks
                                          Adam
                                          I've heard there are hobby shops that do color matching, not sure specifics though and never done it myself. Maybe worth calling around a bit to see?
                                          Anyways, this is currently my go-to EDF for sure. Love the way it flies and lands. Here's my third flight with it:
                                          Nelson Hobbies on Youtube:
                                          https://www.youtube.com/channel/UC3M...ljJd2Md45tOJsw
