Official Freewing 70mm BAe Hawk T1 Thread
  • radfordc
    The Navy T-45 scheme. You can see it on the preview at her website
    Custom Graphics for your R/C Models! Choose from stock sets or request a quote for a custom scheme.
  • SanExup
    radfordc What was the livery for your Hawk repaint?
  • radfordc
    Originally posted by rolfman2000@gmail.com View Post
    I can't find the det-cord on Callies website any more,
    Send Callie an email and ask. The det cord was included in the graphics set I ordered from my Hawk repaint.
  • rolfman2000@gmail.com
    I have just received my Red Arrows bird from Motionrc.eu, and I would like to add a little more detail before I throw it into the scenery. I would like to get the det cord transfers for the canopy, and also maybe a better looking pilot or instrument panel just for display purposes. I can't find the det-cord on Callies website any more, and rcgeeks in the UK don't seem to do the pilot busts. Please can anyone help a fellow flyer in the UK ?
  • paulrkytek
    Link to Short video of My Freewing BAE Hawk with fms pro 70mm in-runner. I have fod guards on the macaducts and made up the air loss with 2 additional cheater intakes in the sides ( see under the word Royal on the logo on the side of the plane almost at the end of the video ) Kept loosing the camera crew so slowed it down for the second half of the video.
  • Andre B
    Originally posted by JamesonC View Post
    Which setup do you currently have in it? The 2210kv inrunner that comes in the HP version is a great upgrade if you don't already have that one.
    https://www.motionrc.com/collections...inrunner-motor
    Yes I pulled the trigger on the 2210kv inrunner. Have yet to fly it when the weather in New England gets a bit better!
  • long-love-rc
    Originally posted by SanExup View Post
    long-love-rc That's unfortunate! The fan and parts aren't that expensive if you look at the spare parts under the Bae Hawk. I would just replace it all. It's around $10. Better than worrying about fixing the old one and having it happen again or be imbalanced from wrenching on it.
    The new fan came this week. However, as I worried, I wasn't able to properly tighten it up on the motor shaft. This is a friction gripping mechanism. When I tried to tighened the locking nut up, the fan and collect turned together, So no effective tightening.
    The painful part is there is NO way to stop the fan from turning. Using fingers, just no enough force. Then I use a wood piece on a blade root to stop it, that simply broke the blade. That fan was damaged.
    Then I removed the damaged fan, put on the last fan which flied off last time. That fan is still good. This time I only used hand to tighten it up as much as I can, plus some loctite. Without surprise, when testing, it flied off again.
    Finally, I cut a slot on the collet. Insert a flathead screw driver into the slot, with the intention to stop it from turning. This somehow worked a bit, I believe I tighten it more what I can do with hands. However, the metal(those collect are made of junk metal) are so soft, the screwdriver eventually scrapped off some metal. So I don't expect very tight gripping. Now I am waiting for the loctite to cure, then to test it again.
    Lesson: for such kind of situation, it is better to just buy a whole EDF assembly, other than replacing the fan only.
  • RCFlyer271
    Originally posted by Adam1985 View Post
    Hi all,
    I’m looking for a little advice on a good colour match for the Red Arrows Hawk. After a few flights the model has a few scuffs and scrapes and I want to fix it up with some paint; I’ve been looking at the Tamiya XF-7 Red (I like Tamiya acrylic paints as I know they won’t melt foam) but I was wandering if anyone had tried this paint and whether it matched well, or if not, what other options there might be.
    Many thanks
    Adam
    I always take a part to Lowes or Home Depot and they'll do a color match sample can for about $5 or less. Match is usually really good and you get a lot of paint for touch ups.
  • long-love-rc
    Certainly I just ordered a replacement, ban and adaptor. Now I am worrying how to properly tighten it up... This kind of adaptor is not really robust, from my experience so far.
  • SanExup
  • long-love-rc
    HOW to repair? Bae Hawk, the EDF fan flied off.
    I have a Freewing Bae Hawk, which I purchased last year. It only has four flights on it so far, and a few on-ground testing... It is about 90% new, except a little bit of bend on the main gear which still functions fine though.
    I am considering to fly it tomorrow which will have wonderfully calm air! I will fly in local RC club which has a run way for EDF the first time.
    So I think it would be good if I measure how long it can safely run on a 4000mAh battery with 70% throttle, or 40%...
    I put it on ground, nose against a pillow, throttling up... At about 2 minutes 50 seconds, I heard the running loud sound suddenly gone! Stop to check, the fan flied off the motor! what a bummer.
    Here are the pictures, it is exceedingly hard to loose up the fan adaptor to put it back to the motor shaft. Any good idea?
    I used a clamper to hold the adaptor, which actually damaged it, and using a wrench from another side, try to loose it up... but not working. The adaptor rotated following my wrench, despite I tried hard to use clamper to stop the rotating.
    It is already damaged, I believe. I am asking here just out of curious, how to deal with this situation? thanks a lot!
  • ndrew3
    Hi all,
    Many thanks
    Adam
    I've heard there are hobby shops that do color matching, not sure specifics though and never done it myself. Maybe worth calling around a bit to see?
    Anyways, this is currently my go-to EDF for sure. Love the way it flies and lands. Here's my third flight with it:
  • JamesonC
    Originally posted by Andre B View Post
    Has anyone attempted a motor/edf upgrade. Am now very comfortable with this jet and could use a little extra to take off from grass. Any feedback is welcome.
  • Andre B
  • radfordc
    There is no concern about EPO foam melting from paint. Not even acetone will melt EPO.
  • Adam1985
    Hi all,
    Many thanks
    Adam
  • Richrfl
    Hi all,
    Sorry for the dumb question but can someone point me in the right direction on the MotionRC website regarding a new fan blade for the 70mm Red Arrow Hawk T1. I can see two types of 70mm fan blade, the first is called a ‘reverse’ flow blade and is in the spares section for this model. The same blade is available but doesn’t state reverse.
    So two questions, which blade do I need, the non reverse or reverse blade? Final question is what does it mean by reverse? That the motor spins the opposite way and so to produce rearwards thrust the blades are angled in a reverse manner to normal blades?
    Many thanks for your help!
    Adam
    I guess this is the fan you need: https://www.motionrc.com/products/fr...cted-fan-blade
    I haven't seen any reverse fan in the model spare parts.
    I am surprised you found there a reverse blade offering for the RAH T1. Normally you use a blade turning counter-clockwise when you look at the plane from the front. Even a reverse blade could be used, for what you have to swap one pair of the connections from the motor to the ESC, I do not know (may be someone smarter than me can give a more accurate answer) if the plane has any construction design which compensates for the torque produced by the fan. In Normal propeller driven planes they offset the axis of the motor relative to the plane longitudinal axis to compensate for the rotation. Reverse fan are normally used in dual EDF engines so that each one compensates for the torque of the other.
  • Adam1985
    Hi all,
    Adam
  • Randy H
    Hi, I maiden my Hawk today and it flew great with no trim adjustment needed. This is a first for me because all the models I have flown since I started in the hobby in the 1970's have had propellers up front. The model is fast and can be slowed down quite a bit for some easy flying. Landing with full flaps was a little rough since I bounced it but the new landing gear took the punishment with no damage. I used an admiral 4000 40c and set the timer for 2 1/2 minutes. Landed and checked the battery and still had 65% left in the tank, so it looks like I can extend my flight time. This jet is rock solid in the air and a joy to fly. Looking forward to many more flights as I learn to master this edf and move on to my next jet.
    I still love my warbirds (FW spitfire, FW190 and Bearcat, ME109 etc) but flying the Hawk brings another level to the hobby for me. Great job Motion RC.
  • Richrfl
    Tristar, I ended up crashing my Hawk after a good landing (big pilot error after landing). Anyway, I bought a new one, and I found that I was not able to use the gear upgrade, which was an outstanding solution to the steering problem. The part to be blamed is the nose strut. I was expecting to have the steering problem again, but to my surprise, I did not. With the original and ugly wire gear, the steering works incredible well. Just for the sake of confirming, replace the strut for the original wire gear in the nose wheel, and see what happens. It is obvious that the strut has some design and manufacturing problem, as the tolerances are way out of mechanical standards and that causes the nose weel to move sideways, front/back, and even rotating at its own pleasure.
    Good luck.
