PIC OF THE DAY..
There are worse things to suffer from.... says one addict to another. :)Dynam; E-Flite; FreewingComment
Well, I've only got 3 for now, but thing is.. I'm still on the Mini Apprentice (Trainer)! :Silly:Dynam; E-Flite; FreewingComment
Niiice!! That looks better then my club field out here!
I was in Port Richey for 28 years, until about 5 years ago when I traded in the humidity for this dry desert heat. I used to ride up in your area quite a bit back then.Dynam; E-Flite; FreewingComment
fouled nose wheel.:Angry:.%&*$$#@!&&^%$$.used plane ..no damage :):popF16 Freewing 70 mm...... fouled gear bellylanding.... First flight..used plane...no real damageComment
So your ventral fins survived the belly landing? Same thing happened to my brand new one on its 4th flight! 3rd landing was lousy so the nose gear got bent back a hair causing it to jam in the retracted position. I check for retract function after every landing now, but when I discovered the problem I opted to leave the mains down to save the ventral fins, but the nose cone dug in instead, so I had to fix that too.Comment
So your ventral fins survived the belly landing? Same thing happened to my brand new one on its 4th flight! 3rd landing was lousy so the nose gear got bent back a hair causing it to jam in the retracted position. I check for retract function after every landing now, but when I discovered the problem I opted to leave the mains down to save the ventral fins, but the nose cone dug in instead, so I had to fix that too.[/QUOTE]
dont know what haaped there..but yes thay survived with the heip of some glue and yes that is exactly what happed to the gear. might shim it up a little that works sometimes. hope to get in some flying this weekend weather been badComment
Me too! I just took off the flimsy plastic cover & pull that sucker forward. Flies fine without it.Comment
.png)
