PIC OF THE DAY..
  • hotrod23t
    jim jets
    • Nov 2017
    • 312
    • EUSTIS FL.
Name:
ID:	128725 I AM SUFFERING FROM AIR SICKNESS:):):pop
    • BluesDragon
      RC Planes Fanatic
      • 574
      • Arizona
      There are worse things to suffer from.... says one addict to another. :)
      Dynam; E-Flite; Freewing
      • hotrod23t
        jim jets
        • Nov 2017
        • 312
        • EUSTIS FL.
        YA I HEAR THAT i am hovering at 32 aircraft right now and holding...unless project foil is something i cant live without....:):):Cool::Confused::pop
        • BluesDragon
          RC Planes Fanatic
          • 574
          • Arizona
          Well, I've only got 3 for now, but thing is.. I'm still on the Mini Apprentice (Trainer)! :Silly:
          • hotrod23t
            jim jets
            • Nov 2017
            • 312
            • EUSTIS FL.
Name:
ID:	128737 that was me 4 years ago then i built this in my back yard the rest is history
            • BluesDragon
              RC Planes Fanatic
              • 574
              • Arizona
              Niiice!! That looks better then my club field out here!
              I was in Port Richey for 28 years, until about 5 years ago when I traded in the humidity for this dry desert heat. I used to ride up in your area quite a bit back then.
              • hotrod23t
                jim jets
                • Nov 2017
                • 312
                • EUSTIS FL.
                check me out on facebook and you tube ..RECTANGLE RC
                • hotrod23t
                  jim jets
                  • Nov 2017
                  • 312
                  • EUSTIS FL.
Name:
ID:	129521 Used f16 gets a paint job
                    That's hot bro!
                    • hotrod23t
                      jim jets
                      • Nov 2017
                      • 312
                      • EUSTIS FL.
                      THANKS.... just cant see them... old eyes ya know
                      • hotrod23t
                        jim jets
                        • Nov 2017
                        • 312
                        • EUSTIS FL.
                        gear upgrade and weapons set arriving today:Cool::Cool::pop
                        • hotrod23t
                          jim jets
                          • Nov 2017
                          • 312
                          • EUSTIS FL.
                          fouled nose wheel.:Angry:.%&*$$#@!&&^%$$.used plane ..no damage :):pop
                          • hotrod23t
                            jim jets
                            • Nov 2017
                            • 312
                            • EUSTIS FL.
                            Weapons arrived
                            • crankestein
                              • 316
                              Pic of the day...
                                Originally posted by hotrod23t
                                Weapons arrived
                                Then shootem! Lol
                                • CZ Flyer
                                  • 212
                                  So your ventral fins survived the belly landing? Same thing happened to my brand new one on its 4th flight! 3rd landing was lousy so the nose gear got bent back a hair causing it to jam in the retracted position. I check for retract function after every landing now, but when I discovered the problem I opted to leave the mains down to save the ventral fins, but the nose cone dug in instead, so I had to fix that too.
                                  • hotrod23t
                                    jim jets
                                    • Nov 2017
                                    • 312
                                    • EUSTIS FL.
                                    So your ventral fins survived the belly landing? Same thing happened to my brand new one on its 4th flight! 3rd landing was lousy so the nose gear got bent back a hair causing it to jam in the retracted position. I check for retract function after every landing now, but when I discovered the problem I opted to leave the mains down to save the ventral fins, but the nose cone dug in instead, so I had to fix that too.[/QUOTE]
                                    • hotrod23t
                                      jim jets
                                      • Nov 2017
                                      • 312
                                      • EUSTIS FL.
                                      dont know what haaped there..but yes thay survived with the heip of some glue and yes that is exactly what happed to the gear. might shim it up a little that works sometimes. hope to get in some flying this weekend weather been bad
                                      • CZ Flyer
                                        • 212
                                        Me too! I just took off the flimsy plastic cover & pull that sucker forward. Flies fine without it.
                                        • crankestein
                                          • 316
                                          Four stroke day
                                          not mine, belongs to a friend
