Official FlightLine 850mm P-51D Mustang Thread
Welcome to "The Squawk" Adam! Some paints can be terribly finicky on particular surfaces and this appears to be one of those models. Personally I would simply just paint over everything and then do your trim work once the new base coat has completely dried. Then you shouldn't have any issues using painter's or Tamiya curve tape. You can also help "de-tack" the tape rubbing it a few times on your pants. Hope this helps and be sure to add your photos once you're done! -
Hey All, new on hobby Squawk myself!
Ive just picked up this little baby and am looking to give her the Ferocious Frankie scheme. Ive got the colours sorted but have just been playing around with masking tapes. Following the advice in this forum elsewhere, I have tried the Tamiya curvy masking tape on the top of the wing just as a tester... and its peeled the original silver paint right off!!! Not even pressing down hard and practically laying it on the original paint, I’ve tried it again and same thing, just rips the paint off, not good.
Does anyone have any suggestions to help before I strip my entire model of silver paint?! Is normal old painters masking tape any better? Not that the Tamiya stuff is particularly sticky, must admit I was surprised this happened. Not sure how well the paint is applied on the model :/
Thanks for any help you guys have!!Leave a comment:
I already have the low adhesion masking tape, just need to buy some acrilic paint. Tnx for the info m8
Yes, I did use regular polycarbonate spray paint together with low adhesion masking tape.
It really was easier than I thought as you can nicely cover the parts with the tape and also use newspaper or some other plastic to cover larger parts to prevent the tiny color particles / spray mist to attach to these parts.
Then just spray in fine layers with enough distance to the object. Do 3 or 4 layers and let the color dry a bit between each layer. This should give you a nice covering color that you can also top with clearcoat for more shine (but I did not use clearcoat myself)Leave a comment:
HelloDid anyone notice that the Decal Placement Guide shows the Stars 'n Bars on the wings pointing aft? Looks like at least McLogo went into this trap. In addition, the S/N on the decal below the cockpit is wrong as well ;)
Maidened my P-51 today with 4s 2200 power. Lots of fun!
I didn't like the instrument panel and made a 3DP part plus a gunsight. Files are attached, feel free to make your own. The pilot is available from Thingiverse, scaled by 87% plus a slicer cut in height. Just search for "ww2 pilot USAAF", there are different choices (goggles on/off, oxygen mask). I added rivets using the toothpick method and added some TAMIYA Panel Line Accent Color.
I saw that you insert pilot in your 850 mm Mustang. Can you pls explain how did you open the canopy and how did you trim and fix the pilot ?
TnxLeave a comment:
Where do you put the Admiral 4s 2200 for CG? I'm finding it to be at the front edge of the canopy where it goes into the fuselage.Leave a comment:
Thanks! This was my first ever attempt at weathering.
Credit for the Citadel NULN Oil paint for weathering goes to the Merry Boozer YouTube Chanel, They have some good videos on weathering techniques.Leave a comment:
Very nice! Subtle weathering, especially on a smaller model, is the way to go. Good job!Leave a comment:
Can you pls explain the process of painiting? Did you use water based color, and did you spray painted it or did you use handbrush?Leave a comment:
Yes - This is a great flying plane once you get the toss part down. I have mine set up now with slight up elevator in launch mode and an overhand toss with my left hand and 2/3 throttle. Lots of uneventful launches with this method!
My experiment with the admiral recovery mode when I tried it didn't go as planned. I gave it an underhand toss but the down elevator made it dive into the ground before any recovery! Amazingly it didn't break a prop and just wrinkled the foam a bit.
The heat has the foam gatoring under the canopy but in 90 plus heat that is to be expected.Leave a comment:
I did my maiden today. I was able to get 2 flights in before dark. There was definitely some torque with the hand launch, but the gyro really tamed it. This plane was everything I was hoping for.. Low level passes were like it was on rails. I turned off the gyro and Couldn't really tell any difference. This thing is every bit as fast as my FW 64mm F-18, but instead of 3 minute flights I'm getting 8 minutes with room to spare.
This plane is gonna get a lot of time in the air!Leave a comment:
Thanks!Yep she's a blast. Just be mindful of the torque when you go to underhand toss her...Went through a few stock props...A bit of a learning curve. I found about half throttle and a touch of right stick works well. I also upgraded to an APC prop which is far less brittle than the stock prop. Enjoy!
I watched your videos. I may do my maiden toss with my gyro on.Leave a comment:
Yep she's a blast. Just be mindful of the torque when you go to underhand toss her...Went through a few stock props...A bit of a learning curve. I found about half throttle and a touch of right stick works well. I also upgraded to an APC prop which is far less brittle than the stock prop. Enjoy!Leave a comment:
I decided to go ahead and get one of these as a simple hand toss yank and bank. I went with the Shanghai LIL scheme.
I plan on using my Admiral 4S 2200 45C's that I use in my 64mm edf's. Set up and CG'd it based on the manual. I had an extra Eagle A3-L gyro laying around, so I dropped it in.
Looks like it should be a fun plane.Leave a comment:
Welcome to Hobby Squawk Vefrancis! This model is 1/13 scale. Plus Callie is so good all you have to do is tell her what model you want decals for and she will know the size.
New to this forum. Looks like alot of knowledge on here. What size graphics do I order from Callie for the Mustang 51d 850 mm version? Thanks in advance VernLeave a comment:
As I mentioned in my first post, I am green as grass as a pilot, but both flying scale and flying fast sounds good to me😊Welcome to Hobby Squawk Mr. Black! I use the 4S Admiral 2200 mAh in mine and she scoots like a rocket! 3S 2200 flies decent as well...Just not with the same top speed. If scale flight is your style I would recommend the 3S, but if you feel the need for speed, definitely go the 4S route.
So, Im gonna get:
Spektrum DX8
Admiral Rx600SP
3 2200 Mah batteries ( 3 and 4 S ). What temperature should I take?
charger that James recommended
I will also buy 2 spare props, glue and foam tape for painting the tail, nose and wingtips
Anything else I should buy?
Thank you
