Official FlightLine 850mm P-51D Mustang Thread
    This one comes with torque roll for the hand tosses so be sure not to go full WOT or 3/4 power on the throw or she will torque in. Ask me how I know.
    I apply about 50% power tops and underhand toss her with about 30 degrees skyward and have a touch of right stick to counter the torque roll...Not perfect, but once she's up and you have both hands on the sticks she's just a ball.
    Also, I found the stock props especially brittle and broke 3...2 were hard landings and one just broke for no reason I could tell. So I swapped them out for a 9x6 APC. MUCH better. No matter the landing, those props just resist breaking.
  • Adam1985
    Thanks James!
    If anyone has any tips for flying this little beast then I’d appreciate hearing them!
  • James
    Originally posted by Adam1985
    Ferocious Frankie is complete! Now the first flight to come...
    So awesome Adam. Really well done. :punch:
  • GBLynden
    Originally posted by Woodcock
    I really like the yellow. Thanks for the vid, enjoyed it much, watched the whole thing. W
    Thank you very much
    Beautiful work! Looks fantastic, nice job!
  • Adam1985
  • Woodcock
    Originally posted by GBLynden
    This is the FlightLine P-51 Mustang With RECKEM ROYS RC on the sticks.
  • GBLynden
  • uscanuck1xa
    Looks great Adam!
    Nice work!
  • Adam1985
    Here’s some pics of my Ferocious Frankie, still got the stickers to put on but fairly happy with it! The masking tape peeling off the original silver paint proved a massive nightmare, lots of stressful moments getting it to this stage!
    I will post pics once the stickers are on. I did the rudder mod on it and it was very straight forward and good fun converting the model!
  • Drake
  • DDawg
    Hey all, me again and looking for some more advice!
    Ive bound my DX8 Gen 2 Tx to my new Admiral RX600SP, and everything is working apart from the throttle. No power seems to be going to the motor because it isn’t turning or doing a thing!
    Ive never used the admiral Rx before so just wandered if anyone out there had any issues like this themselves? Any input is most welcome and thanks in advance!
    Mine did the same thing. Re calibrating the ESC fixed it.
  • Adam1985
    Cheers all, and thanks for the tip coconut! You were right, it wasn’t the setup of the ESC but a setting essentially on the transmitter. All sorted now though and the rudder modification is all done and working! Surprisingly straightforward!!
    It’s going to be a little while, but once the plane is sprayed ill put some pics up.
  • Coconut
    Ive had the same problem with everything working except throttle. I dont remember exactly what I did. But, I know its something to do with the transmitter. You have to increase the throttle endpoint in the transmitter. Just a little at a time(like 5 at a time).
    You will want to calibrate your ESC. Check out this link to learn how...
    A very common reason a customer might call us is because they can't get their ESC to work. They bought a new airplane from us, receive the shipping package, excitedly put it together, following the in...
    Hope that solves it!
  • Adam1985
    Fantastic! Good luck and we look forward to the pics!
    When it comes time to hand toss, keep in mind that this one has that "torque roll" tendency so some are countering with right trim/Flight Modes, flaps or having someone else toss it for you so you have both hands on the sticks from the start. For me, I simply go to half throttle, give it a good toss about 30 degrees or so and have a touch of right stick going on until I can get her off and running...Has been working great for me the past dozen or so times...
  • Adam1985
    Thanks for the reply Aros!
    I think you’re right on the process of spraying the whole aircraft and then starting from there, and the tip about de-tacking the tape is brilliantly simple!
    Ive done the rudder modification so thats pretty much complete, time to get spraying! I will definitely post some pics once Frankie is done, just received my stickers from Callie Graphics today and they look perfect!!
