  • sam51401
    With Horizon being the primary supplier and it being listed as discontinued, I didnt hold much hope to find one. Wish there was enough interest to restock those but I dont think one plane will support that.
    That's why I opted for a still supplied option.
    Will like to see the install with strut to see how the 105 degrees works out.:pop
  • TBolt
    no longer on Amazon either :(
  • wrangler1
    Originally posted by Kangi1954
    Where did you get the 105 degree retract? Thanks for the updates.
    On Amazon.
  • Dirty Dee
    Originally posted by mtnbiker63
    Dirty Dee, are your OV10 mods on Thingiverse?
    Currently print to order, will host on cults3d for a small fee soon.
  • mtnbiker63
  • sam51401
    I like to know also as it is listed discontinued on the Horizon site and i did a google search for same under shopping with no hits other than the 25-45 size unit. I already placed order with Robart but may have swayed me to use what i have on hand if it wasnt for not finding one those.:Angry::Crying:
  • Kangi1954
    Originally posted by wrangler1
    Update..... MRC is sending a replacement wing in exchange for the incomplete one. Also i received the EFLITE NOSE RETRACT of 105 degrees, im just waiting for the YAK gears to arrive so i can test it.
    For the ones that choose to put the FMS F7F TIGERCAT power plant on this model, be aware that the motors comes without the metal "x" plate, you have to order separately ( That was my case and i ordered them directly from FMS).
  • Rosytime
    I have some photos of my progress. You can see the nose gear retracted and extended and you will notice the nose wheel sticks out a bit. Also, it is raked forward as mounted. You can also see the wire harness that is for each boom. The only difference is that one has an extra servo wire for the elevator. I have decided to get the multi servo connectors for the booms so that when I want to disassemble the plane I can leave the bulk of the harness in the wing. The battery leads will have another EC5 connector in line to accomplish this along with the multi connectors. The harness comes out of the fuselage easy enough so that's not a problem. I might put another multi connector for the receiver to try and make it easier to hook all the servos up on that end. It's getting close to assemble and start doing the CG and servo throws. Also check out the pull-pull system for the nose wheel. Not to my liking but it works. Click image for larger version
Name:	IMG ov-10 1.JPG
ID:	204135Click image for larger version
Name:	IMG ov-10 2.JPG
ID:	204136Click image for larger version
Name:	IMG ov 10 3.JPG
ID:	204137Click image for larger version
Name:	IMG ov 10 4.JPG
ID:	204138Click image for larger version
Name:	IMG ov 10 5.JPG
ID:	204139Click image for larger version
Name:	IMG ov 10 6.JPG
ID:	204140Click image for larger version
Name:	IMG ov 10 7.JPG
ID:	204141Click image for larger version
Name:	IMG ov 10 8.JPG
ID:	204142Click image for larger version
Name:	IM ov 10 9.JPG
  • wrangler1
  • fjkelley@cox.net
    I'm a +3 for Dirty Dee and his exhaust stacks. Perfect!!
  • walkerm45
    Let me see what I can come up with......mike
    PS check your mailbox....
  • Dirty Dee
    Originally posted by sam51401
    Yep, Chris still amazes me with his skill set. He and I go back when he started on his A10 and then around the second EDF Jet Jam. Should have seen his A330 this year, great work.;)
    Thanks Sam!
    Originally posted by walkerm45
    Dirty Dee, make us a 'long nose' for an OV-10D.....
    The D was always my favorite variant. If I am provided with good contour gauge data, measurements, and a direct side-shot picture of the nose area with the canopy, I can make it happen.
  • walkerm45
  • TBolt
    Yup, just got back from a little trip, and found my Exhaust stack waiting for me. Very impressive. Thanks Chris.
  • sam51401
  • MikeT
    You will love the exhaust that Dirty Dee produces, They look great, and are well worth the money....... extra something for the appearance. I would gladly trade my antenna for the exhaust. (hint, hint)
    +1, they are real nice and he's great to deal with.
    Mike
  • walkerm45
  • sam51401
    Well call me gullible, slap me silly, I went with a full Robart gear solution since i called and the July 4th special is out now. I was calling to order the main struts....but:Silly::Confused::Cool:
    SO as I have been still looking around for options, i think i found the next best thing for the mains to Robarts and that is the EFlite 30cc Spitfire main retracts(95 degree) They will take a 13mm(1/2") strut, are still available but not sure how long as the Spit was discontinued. So for a cost effective(????), near scale looking gear, here is my recommendation.
    Nose
    Robart 553RSE 105 degree retract($119.95), needed controller,($99.95 or $69.95 depending on full program or simple) using the #668($83.45) 7/16" trailing forked strut with a 2.75" wheel
    Mains
    EFlite 30cc retracts that are recommended for the H9 Spitfire ARF that use to be available($89.95 ea,Listed as a "replacement") Gear controller is $38.24. There are replacements listed as RH and LH but you can order 2 of the same as the ONLY diff is the side of the trunion that the cinch screw is accessed from. Other than that one diff, they are identical.
    The struts would be 7/16" 669L and 669R($89.95ea) trailing arm struts and 3.25" wheels.
    After adding up the cost($671) of the above, i came out about the same on a complete Robart solution but then using the July 4th discount it came to under $500. Yea i know us scale anal picky guys got to have what will get us closest to scale without truly braking the bank. Now the one OTHER option is air retracts, use 552RS($164.95/set),558RS($93.45) plus an air kit($40-70) or EFlite 90 degree 60-120($159.99) for mains set and a simple 90 degree nose EFlite unit($85.99).
    Least cost option for what is currently available: $245 EFlite 90 degree 60-120($159.99set) for mains and a 90 degree nose EFlite unit($85.99), use provided struts and wheels. The trike set isnt listed any longer.
    Air Robarts: $573, Mains, nose and air kit plus same struts. $308 if using kit provided struts/wheels.
    MotionRC XWave retracts: $39.99 ea x 3 = $120 ***several months till available**** Might get them before winter or late fall.........:Scared::Yawn:
    By far the cheapest cost: $00, use what ya got:Silly:
    Here is the outfit I ordered from Robart
    Nose: Same as listed above, 558RSE, 668 strut
    Mains: 552RSE 95 degree mains and 669L/R struts including controller plus extensions to reach the contoller:Whew:
    I did inquire to Sierra and got a reply from Darrell. He was straight shooting and bottom line, his struts wont fit "our small model" and if people "dont want to pay him $500 for a gear set and have orders of a dozen or more, it isnt worth their time".
    Now im off to inspect the 3D printed exhaust i just received from DirtyDee:)
  • walkerm45
    Welcome to twins, Twice the fun, and 4 times the work.......
  • Rosytime
    I continue to plod along on this build. I found that the retracts from the Freewing A-10 work perfect . The A-10 weighs just a tad less than this model when loaded with batteries so they should be okay for now. I'm waiting for the recommended retracts to come into stock and then I'll use them since the A-10 retracts are all plastic. I guess it's a good thing I kept all those parts from my crashed A-10 since it's providing the retracts, ESCs, BEC, and the long battery leads needed for this bird. I'm sorry that I haven't provided any photos but I'll try and get some posted in the next few days. I tried to use a steering arm for the front nose gear but it just wont work with the space available. I went ahead and use the pull-pull system they supply and what a pain. A little grind here and there and the steering arms don't hit the servo plate. I'm assuming that the metal retracts don't have this problem. The system is not a direct shot but turns a 180 in the fuselage. Look at the instructions and see what I mean. It works but I'm not happy with it. If I can figure out another way I'll try that.
    So now that the retracts are mounted, I just need to put some servo extensions on them and start getting all the wiring rigged in place. If you haven't looked, there's a lot of extensions used to bring it all to the fuselage. I then want to figure out a way to make it easier to take the plane apart and not spend 20 minutes putting back together all the wires. I know about the multi servo connectors but with all the wyes needed it's get complicated.
