Product page: https://www.motionrc.com/products/bl...rch-2850mm-arf
The Fieseler Fi 156 Storch (Stork) was a German liaison aircraft built by Fieseler before and during World War II. Production continued in other countries into the 1950s for the private market. It remains famous for its excellent STOL performance and low stall speed of 31 mph (50 kmph). French-built later variants are often seen at air shows today.
The model is scaled to approximately 1:5 and attention was paid to a true to original appearance and best flight characteristics. The model can be operated using an electric power system or with an internal combustion engine about 30-35cc displacement.
Features:
Features:
- High level of prefabrication right out of the box
- Lightweight, strong, and fully sheeted laser cut balsa and plywood construction
- Covered in high quality Oracover
- Heavy-duty hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed dummy radial engine, cockpit and interior included
- Fiberglass control horns with ball link connector
- Pull-Pull control system on the rudder for precision control and authority
- comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly.
- Fiberglass cowl
- Mounts for both electric and gas power options included
- Fully illustrated instruction manual included and also available for download (see tab above)
- Black Horse Fieseler Fi156C Storch 2850mm (112.2") Wingspan - ARF
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 2300-3300 Watt Brushless Outrunner Motor - we recommend the Admiral GP26 6330-245kV Brushless Motor
- 85-120 Amp Brushless ESC - we recommend ZTW Gecko 120A ESC OPTO High Voltage Brushless ESC
- 8-18 Amp UBEC - we recommend ZTW 18A BEC / UBEC
- 7-8x 45g standard servos - we recommend HS-625MG
- For 8S setup TWO 64 Cell 14.8V 5000 mAh LiPo Batteries with EC5 connector - we recommend TWO Admiral Pro 5000mAh 4S 14.8V 60C LiPo Battery with EC5 Connector
- 2 to 1 EC5 series adapter - we recommend Admiral EC5 2 to 1 Series Adapter
- Electric propeller - we recommend APC 19x10 Thin Electric Propeller
- Engine: 30 - 35cc 2-stroke, NGH GT35R recommended or 38-42cc 4-stroke, NGH GT38 recommended
- Gas Propeller: 18x10-20x8
