Not sure who used the term "V2", but I don't think there's anything to indicate that it's an updated or upgraded version. However, looking at the video from the FMS page where RCInformer flew it at SEFF last year around October, he did say that his had the 360kv motor and that's the way it came. So if it came that way last year, it may have just been something that FMS did to appease the masses, just like they did for the 1700mm Corsair, which they did call a "V2".
New E-flite P-51D 1.5
Sorry, that was me. I used v2 incorrectly when I should have just said 360kv version. I see Horizon is due to get them in early august; it will be interesting to see if it does indeed have the 360.Comment
OK, everyone tell me where we can get replacement locking blocks for the EfliteP-51 landing gear. The retract locking blocks that come standard are "pure junk". Some kind of cheap cast pot metal with no strength at all. A little side load on roll out an the gear collapses cause the lock block breaks. Of course Horizon doesn't sell just the lock block..have to get the complete gear.."Help" there must be a better gear that fits or someone making replacement lock blocks??Comment
I'm not familiar with the term "locking block". What exactly is that?OK, everyone tell me where we can get replacement locking blocks for the EfliteP-51 anding gear. The retract locking blocks that come standard are "pure junk". Some kind of cheap cast pot metal with no strength at all. A little side load on roll out an the gear collapses cause the lock block breaks. Of course Horizon doesn't sell just the lock block..have to get the complete gear.."Help" there must be a better gear that fits or someone making replacement lock blocks??Comment
You will find the "lock block" my terminology when you open up the electric retract screw drive. The lock block travels with the pin on the screw drive...when the gear is in the fully up position the lock block locks the gear up not allowing movement. When the landing gear is down & locked the lock block has traveled along the screw drive over throwing to the locked down position. The lock block is the key to the gear locking up & down...the darn one supplied is cheap pot cast metal / aluminum with absolutely no strength at all..Comment
He's referring to the Trunnion XV
Those FMS made trunnions have a long history of being made from pot metal :angry:Warbird Charlie
I've never had a "trunnion" break on me. I've had the plastic casing of the retract break. I've had the strut pin break and I've even had the worm drive strip. I think you can get aftermarket "all metal" retracts that have much higher strength components but I just can't think of the seller at the moment. I think FMS even makes an all metal retract but it may not be the right size for this plane. Also, doesn't MotionRC sells some all metal retracts?Comment
This plane comes with some very hard tires which tend to aggravate the landing bounce. This can crack all kinds of things in and around the retracts. I replaced the main tires with softer, low bounce tires to make the landings a bit more user friendly. If this bouncing is still a problem for you, then do what you can to reinforce everything in the gear. Squeeze glue into all the crevices you can get between the retract mount and the foam so their less likely to yank right out on a hard landing. FoamTac all the screw threads and "C" clips in the struts. Land on grass if you can or at least till you don't bounce anymore.
Oh, and the strut springs are also very stiff. Some guys replace them with softer springs.Comment
Another thing worth mentioning has to do with the tail retract. From day one, mine worked intermittently and I couldn't for the life of me figure out why this was happening. I even unplugged the retract from the main gear control box and wired it directly to the RX. Still intermittent. Every time I cycled the gear, I could hear it click and do nothing and then sometimes it would just work. Took it out of the plane and it worked on the servo tester every time. I thought maybe something was pinching the wires when it was installed. I had an old retract of the same size that I transplanted the whole strut/tire/trunion assembly into it and on the bench, it worked fine on the servo tester. Put it into the plane and the same thing happened - sometimes worked, sometimes didn't. Then I figured it out. It was the door spring that was not allowing the retract to fully retract and trip the end point contact. When I pushed hard on the strut to compress the spring, it worked the next cycle. I had to modify the spring so it wasn't so fat where the strut caught it. Didn't have to replace the retract after all. :triumph:Comment
In Need of an answer.
I did a maiden flight yesterday landed after 4 minutes the Motor was SUPER HOT! to touch. Outdoor temp. 76, battery SMART 5000 30C
Anybody help with the why??
ThanksComment
How was the ESC? HOT? I had a plane where both the motor and ESC were HOT. It turned out that a couple of the solders were insufficient. Check all solders in the connectors (both sides) from the 3 wires at the motor to ESC, from the ESC to battery. Also, have you changed anything that might cause a restriction of airflow from the nose through the interior?Comment
Remember those guys get commission on the planes sold so to be honest I mean they do what they have to do to make moneyAnyone see the new E-flite P-51D Mustang 1.5 from HH? Its pricey but appears to be true to scale with plenty of power (6s), all the new tech, good size and snap on/off outer wings making it easily transportable which I really like. Its clearly made by FMS but does not seem to be a simple upgrade to their P-51 1450 v8. It won't ship until l mid-month but there are You Tube vids by Pilot Ryan and RC Geek who really like it. Despite the price, I'd seriously consider it but for the paint scheme. Apparently, its modeled after an actual WW ll fighter which was later sold to a private owner who restored and repainted it for the Airshow circuit. Why HH chose to replicate the show plane and not the combat livery is beyond me. IMHO, an iconic warbird should look like a warbird. Thoughts,comments?
My take is with the exception on receivers I avoid HH like the plague
I'm committed on radio gear I have alot of planes and without exception 100 percent every single plane I've gotten from HH has had very specific issues that truly irritated and disappointed
Example
Lack of parts many new 1700 p51s are sitting idle for months ...
Why?
No retracts available imof it took HH over six months from release to have a simple propeller or spinner in stock
Or ....
They were big on selling FMS
Well 4 FMS predetor escs burning out or freezing up in four different planes tells me they don't care about things like reliable electronics
Just slap a paint job on some phone make it look good put crap in it then after it flys once or twice
Crashes
Customer calls two hours on hold to be told
You crashed pilot error not responsible
Run to bank rinse and repeat
So they don't see a dime of my money never again but hey
It's a free country your money do what you want with it good luck
Not I really dig some HH airframes like the SU
I won't buy it
Or the aero cobra
Or the F16 (I have that one) good model no nose gear for a year but mine has held up
The big p51 for almost five hundred that I literally have away cause for a year no parts
Mind you I used other vendors parts to fix things but
It's a pia since HH deliberately makes stuff fit for the aircraft it sells
Then doesn't stock parts so
The middle finger goes up lesson learned screw you
If it sounds like I'm mad I'm not I learned and HH will learn like BH and Nitro planes learned
It's a free country so I spend elsewhere
My freewing and flight line stuff 90 percent success rate and the ten percent is manageable
HH is easily 50 percent fail and fifty percent aggravation
FMS well ever single one doesn't hold up or crashes for stupid stuff
Like bad speed controllers
Bad spinners
Bad clevises or horns.
or glass retracts not in stock
Now guys online on you tube they know this but like I said they get paid and end of the day
They have sold out integrity and honest reviews in order to sell you something make money
That's why I look at those who put up private reviews who just fly for fun
My two cents but to those guy who right now are Rah rah Eflite
You know you guys who get free stuff and a couple of bucks to con the rest of us
Took a few years for you to build audiences it take just a season of BS to lose that audience
Alot of flyers are hip to it now I mean who can forget Pete from BH
Haha apparently everyone last I checked he was hitching a ride in the desert trying to come back
To civilization
Now he is a distant memory
Learn from the mistakes of others
Buyer bewareComment
Hot mother generally is
Prop too big or too much pitch
Not enough cooling
Or HH got the current draw esc output wrong which sorry to say is nothing new with those clowns
Either way it goes don't fly it till they make good which they won't cause they suck
Sorry for your troublesComment
