Official Black Horse 2280mm F4U Corsair thread
  • Reennie the second
    Some progress on the tailwheel and doors. Testprinted some wheels and Quick & dirty painted the wing inlets...
    Tailwheel with new hinge point for the door rods.
    Little bit of paint on the wing inlet
    New hinges for the tail gear doors:
    Doors closed
    Wheel testprint. Rubber is still somewhat to hard, gonna reprint. Material of the tire is TPU Varioshore, rim is from plain PLA.
    Looks nice already... Some painting and then it's really nice...
    Corsair came in today. What a nice kit, really impressed. Landinggear is different than I saw in the forums. Hopefully finally stable and working. Included some pictures for those that might be interested.
    And the UMS 5-100 seems to fit!!
    Now printing some wing inlets to replace the ugly vacuumformed thingies...
    Couldn't help myself. Ordered the BH Corsair. Will post some pictures of the fitment of the UMS 5-100. First I have to wait for the delivery truck...
  • ltc
    For anyone with the electric motor setup on this plane…
    How much lead weight was needed to hit the CG ?
    Thanks
  • Fizeman
ID:	443857 Click image for larger version
  • Fizeman
    image widget
    Hi all, I got a fair deal on a UMS 100-5 radial and plan to put it on a Black Horse Corsair. I saw a picture somewhere on FB or RCGroups of this combination and it seems awesome to me. What do you guys reckon, would these two go nice together? I had a Phoenix 20cc Corsair (1,8m) paired with a Saito FG33R3 and this flew beautiful once in the air, but to get it in the air proved hairy at times (grass field and not to much power). Hope to have a more potent combination now...
  • ltc
    Can someone measure the distance from prop
    shaft to ground with the fuselage level (not sitting on the tail wheel)?
    Trying to determine maximum size prop that could be installed (greater than the 22” listed) and still not worry about prop strike
    Thank you
  • Fizeman
    Looks good and very light. Fuse only wheighs 1600 gr.
  • Fizeman
ID:	439598 Click image for larger version
ID:	439596 Click image for larger version
  • Fizeman
    Receiving my new BH corsair thursday. 😀 can’t wait to get started.
  • Fizeman
    Is saito fg60r a good choice for this model ?
    and how about the landing gear for the 2025 model ?
  • Pumadad
    Hi All,
    Has anyone removed the factory covering and refinished this model?
    Thanks Steve
  • pc1972
    Originally posted by TwistedGrin
    My weathering technique is to use a "craftsmart" Metallic Paint Pen silver.....make a dot and pull it back with my finger or que tip.....can tone it down with some grey chalk....no real way to mess it up. I think the trick is deciding when to stop....apply a couple dots and drag them back - walk away and figure out if you want to keep going. The perfect cowling does not look right with the rest of the skin replicating some sort of distress
    TwistedGrin
    Thanks, sounds simple and will give it a go on my cowl.
  • TwistedGrin
    TwistedGrin
  • pc1972
ID:	353763 Now that I have 6flights on this airframe with my Electric set up.......can honestly report it is a supurb flying aircraft. Probably due to the power to weight ratio (270Watts per Pound) and acceptible wing load factor. This power package puts the wing fully loaded for flight in just a few feet... withouth penalty. In fact you have to concentrate to take off slowly and looong for scale appearence - otherwise it's fully on the wing like a smaller high wing airframe. Once in the air.....the covering does not matter....in fact it looks excellent. The bottom weathering along with the color contrast is spot on. My BH F4U is flying true and straight as an arrow....the only trim I needed was a couple clicks of up trim with the elevators assembled and set absolute zero deflection. There is no tendency to roll or pitch or dive. The flaps slow this aircraft down to a crawl and landings are effortlessly smooth and consistant. However.....the motors of the stock (Phoenix) retracts are weak, the actual struts and carrier metal is just fine. I replaced the stock retracts with the $525.00 Robart Electric 14E-108 full retract assembies which took minimal effort to retrofit into the wings and work very nice.....however even with perfect level smooth greased in slow speed landings one of the Robart Electric Motor actuators stripped....the motor spins just fine but an interal gear is stripped. Robart has this as a replacement part available in stock so this will be an easy repair swap.
    I was and perhaps still am a little skeptical about the fiberglass sandwhich plywood webbed support frame as it looks and feels ....crispy.....fragile. I think the only balsa could be the wing sheeting. Wheras other WarBird giants I fly are much heavier using standard plywood balsa construction which looks and feels like they could suffer much more abuse. However the BH airframe is light and stiff with the gull wing dual wing tube designed to handle normal stress loads.....so far. The wing saddle cross support structure just appears to be fragile - but then again the dual wing tubes may be preventing force loads from translating to that cross section.
    I will state since the model flies so well...any percieved detratction of the printed covering for me is a non-issue. I simply weathered the nose cowling a little and it brought the entire airframe into a different perspective. I used a silver paint pen to rub on some contrasting weathering effect to the fuselage as well and it took without issue. This leads me to beleive a little bit of sanding and the entire airframe could painted over. However after just weathering the cowling I don't see the need. In fact the airframe was well received by my clubs master builders stating the flight performance and the airframe itself is impressive.
    I also fly the Hanger 9 86inch wingspan Ki-43 Oscar with the same power plant....this BH F4U Corsair is on par if not more nimble than the Ki-43. Both are truely amazing performing airframes....only one is available for purchase at this time.
    You can doll up a poor flying airframe and dread flying it or you can doll up a great flying airframe and love flying it....if you don't like the pre-printed covering on this model it is well worth the effort to doll it up to your satisfaction.
    It does not have the gear doors for the mains nor a bomb drop or canopy pull....however for those that obsess with master building....this should be an airframe that could be infinately modified.
    I think BH added some washout to the wing tips and maybe added some beef to the vertical stabilizer....I challenge anyone to actually prove it against 100% scale. My point is Black Horse has delivered a true performance flier and not a hanger queen.....this is what I tend to enjoy rather than hesitating to fly a high percentage scale model that is a brick to fly.
    My2Cents and observation
    This is my power train.... respectible speed and sound, gobbs of power and more to spare.
    22lbs flying weight
    6134 Watt power
    270Watt per pound
    Wing Loading 38.3/oz/sqft
    RC Juice / HobbyStar dual 6s (12S) 8000mAh 100c LiPo (891grams each)
    Agressive throttle with 82mph highspeed passes 5.30min - Landing at Battery at or near 3.77v per cell
    Scale cruising throttle with mixed aerobatics 6.30min - Landing at Battery at or near 3.77v per cell
    ZYHobby 1.75inch 44.5mm Two Blade Spinner assembly drilled for DLE30/55 (TrueTurn is no longer in business)
    https://zyhobby.com/products/175inch...mld35-us-stock
    24x12XOAR Prop
    Admiral GP60-180Kv Motor
    Castle 160amp ESC
    Dual 6s 100C 8000mAh LiPo (12S)
    3200mAh Life receiver battery
    2200mAh LiPo retract battery
    Robart Electric 14E series 90 degree rotating rectracts with controller board and wire extensions
    Stock Wheels
    Auroa 8 Stabilizer
    Spektrum DX8 Gen2 Transmitter
    TwistedGrin
    Hi Twisted Grin.
    Very impressed with your weathering of the cowl. Did you airbrush the detail or is it all brushwork? Would like to do the same to mine.
    Cheers Peter
  • CorsairJock
    Finally some updates: mine is ALMOST ready to fly, but with winter coming on and I am a "Snowbird"/ will be heading south in 2 weeks, it aint gonna fly until April.
    OK, first up is my tailwheel: on full scale Corsairs the tailwheel does not retract completely, the wheel it self partially protrudes from the bottom of the fuselage. That said, I installed 2 nuts on the work drive which causes it to stop before going up all the way, pictures show it in both positions. It took a LOT of time and fine tuning to get it there, but worth it IMO
  • CorsairJock
    Since I had to re-cover the rudder, decided to re-cover the fin also, AFTER re-shaping it to a more accurate scale profile.
    Painted both with rattle can Rust-Oleum Ultra Matte Nantucket Blue.
  • CorsairJock
    BEWARE!!! ELEVATOR & RUDDER CONTROL HORN INSTRUCTIONS ARE WRONG!!!
    First pic is screen shot of how to attach control arm to the rudder. The diagram shows a M3 x 30 bolt being inserted into the control arm, and screwed into the rudder. Nothing more, thats it.
    SO, that's what I did, screwed into the rudder until it protruded out the other side, it wasn't getting any tighter and the control horn had obvious slop.
    Looking back at the instructions, I see a nylock nut mentioned, and altho it didn't mention the square piece with a hole in it: I assumed it should go on the other side where the bolt was sticking out, then the nut should be added.
    NO WAY that nut was going to fit into that hole in the square piece, and even if it did there would be no way to tighten it.
    SO, I reasoned the screw must go into the square piece, then thread into the control horn, THEN somehow thread the nut on.
    Well, that did the trick, only because I could not see the sides of the rudder, I didn't realize until too late that I was crushing and distorting the balsa. UHHHG! Now I am bummed, I figured the rudder was ruined, and being less that a week from completion and the weather up here turning colder, I need a new rudder NOW!
    Instead, I stripped the covering off, repaired and reinforced the damaged area, covered in some old flat gray MonoKote that I had, put everything back together the RIGHT way, and now ready to install after I throw a cote of paint on it. The paint doesn't match, but I eventually want to paint the whole thing anyway so that'll do for now.
    SO, in summary: the M3 x 30 bolt goes thru the square piece, then the rudder, then the control horn. Good luck adding a nut, I just added a regular M3 nut and put CA all over and around it, but the bolt threads nicely into the control horn anyway.
