The B-25 Mitchell, produced by North American Aviation, was named in honor of Brigadier General William "Billy" Mitchell and first introduced in 1941. The medium bomber was used in every theater of WWII by various Allied air forces and continued to serve after WWII ended, with over 10,000 developed in numerous variants.
Motion RC is proud to bring the historic B-25 to the already impressive array of models from FlightLine. This model will satisfy any discerning B-25 aficionados with its fully operational servo-driven bomb doors complete with 4 dummy "bombs" for deployment. The scale CNC-aluminum alloy landing gear with gear doors really compliment the model's scale appeal. The B-25 comes with all digital servos ranging in plastic, hybrid, and metal gear at all the appropriate control surface points.
Further scale details and amenities include two pilots, 3-blade propellers (normal and reverse), 3 decal sets (Heavenly Body, Executive Sweet and Mitch The Witch), LED lights, flaps and quick-release wings that need no screws for effortless transport. The FlightLine B-25 will unquestionably take over the industry as the finest scale, quality EPO foam B-25 on the market. Secure yours and grace the skies with this must-have for any warbird pilot!
Effortless Transport with Quick Release Wings The FlightLine B-25J Mitchell comes with easy on, easy off quick release outer wings for extremely easy transport. No screws required! Simply clip or unclip the connector and engage the latch toggle levers to lock or unlock. |
3 Different Liveries To Choose From The B-25 comes with 3 different decal sets (Heavenly Body, Executive Sweet and Mitch The Witch) to choose from with the stars and bars pre-applied out of the box. |
Scale Details Throughout 2 painted pilots, 3-blade scale propellers (normal and reverse), functional bomb doors, antennas, guns, LED lights and flaps bring the B-25 to life both on the ground and while flying sorties in the skies. |
Scale CNC-Machined Aluminum Alloy Gear The B-25 comes with CNC-machined aluminum alloy landing gear with sequenced gear doors to complete the scale appeal of this beautiful model. |
Fully Operational Bomb Doors The FlightLine B-25J Mitchell takes it to the next level in scale detail with the fully functional, servo-driven bomb doors complete with 4 dummy "bombs" you can drop during flight. |
FlightLine Quality You've Come To Expect The B-25J Mitchell is the latest model from FlightLine, a world-leader in EPO foam warbirds so you can expect a world-class quality model from nose to tail. |
Digital Servos Throughout The B-25J Mitchell employs digital servos throughout the model ranging in plastic, hybrid and metal gear, the latter used on all critical control surfaces like aileron and elevator. |
Counter-Rotating Props Counter-rotating propellers provide tracking stability, helping to cancel out the left torque tendencies of many a warbird, keeping your B-25 tracking straight and true down the runway. |
Movable Turrets It's just not a B-25 without turrets that can swivel to face those pesky axis fighters. The flightLine B-25 is no different, allowing you to angle your turrets any direction you desire. |
Fully Loaded with LEDs The B-25 comes with LED lights throughout adding to the impressive presence of the model. Clearly visible in both day and dusk conditions, the lights not only add scale appeal but practical visual reference in the sky. |
- Servo-driven, fully operational bomb doors with 4 dummy "bombs" for deployment
- 3 Different decal sets (Heavenly Body, Executive Sweet and Mitch The Witch) to choose from with the stars and bars pre-applied out of the box
- Scale CNC-machined aluminum alloy landing gear with sequenced gear doors
- Quick-release wings that do not require any screws for effortless transport
- 15 Digital servos throughout including plastic, hybrid and metal gear
- New 2023 structural and spatial design conception exclusively from FlightLine
- Flaps, two pilots, 3-blade propellers, LED lights, antennas and armament complete the scale appeal
- FlightLine B-25J Mitchell 1600mm (63") Wingspan - PNP
- 2 Motors, 2 50A ESCs, 15 servos, LED lights, and retracts all pre-installed
- Instruction manual
- 4 Dummy "bombs"
- 3 Decal sets
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 6 Cell 22.2V 5000 - 5500 mAh LiPo Battery with EC5 connector - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery with EC5 Connector
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :2 hours
| Model Scale | 1/13 |
| Wingspan | 1600mm / 63in |
| Length | 1280mm / 50.39in |
| Empty Weight | 3050g / 107.58oz (w/o battery) |
| CG (Center of Gravity) | 82mm (3.22") from the leading edge of the wing at the root |
| Power System | 2x 6S 3748-450Kv Brushless Outrunner Motors |
| Electronic Speed Control | 2x 50A, 7A BEC with EC5 Connectors |
| Propeller / EDF | 2x 12x7 3-Blade Propellers (Normal and reverse) |
| Servos |
| Landing Gear | Electronic retractable CNC aluminum alloy tri gear |
| Required Battery | 6S 22.2V 5000-5500mAh LiPo with EC5 connector (required) |
| Required Radio | 6 Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | Yes |
| Hinge Type | Nylon Reinforced |
| Material | EPO Foam |
| Skill Level | Intermediate |
| Build Time | 2 Hours |
