    • 8207
    Click image for larger version  Name:	b25.jpg Views:	57 Size:	61.9 KB ID:	380784
    The B-25 Mitchell, produced by North American Aviation, was named in honor of Brigadier General William "Billy" Mitchell and first introduced in 1941. The medium bomber was used in every theater of WWII by various Allied air forces and continued to serve after WWII ended, with over 10,000 developed in numerous variants.
    Motion RC is proud to bring the historic B-25 to the already impressive array of models from FlightLine. This model will satisfy any discerning B-25 aficionados with its fully operational servo-driven bomb doors complete with 4 dummy "bombs" for deployment. The scale CNC-aluminum alloy landing gear with gear doors really compliment the model's scale appeal. The B-25 comes with all digital servos ranging in plastic, hybrid, and metal gear at all the appropriate control surface points.
    Further scale details and amenities include two pilots, 3-blade propellers (normal and reverse), 3 decal sets (Heavenly Body, Executive Sweet and Mitch The Witch), LED lights, flaps and quick-release wings that need no screws for effortless transport. The FlightLine B-25 will unquestionably take over the industry as the finest scale, quality EPO foam B-25 on the market. Secure yours and grace the skies with this must-have for any warbird pilot!
    Effortless Transport with Quick Release Wings
    The FlightLine B-25J Mitchell comes with easy on, easy off quick release outer wings for extremely easy transport. No screws required! Simply clip or unclip the connector and engage the latch toggle levers to lock or unlock.
    3 Different Liveries To Choose From
    The B-25 comes with 3 different decal sets (Heavenly Body, Executive Sweet and Mitch The Witch) to choose from with the stars and bars pre-applied out of the box.
    Scale Details Throughout
    2 painted pilots, 3-blade scale propellers (normal and reverse), functional bomb doors, antennas, guns, LED lights and flaps bring the B-25 to life both on the ground and while flying sorties in the skies.
    Scale CNC-Machined Aluminum Alloy Gear
    The B-25 comes with CNC-machined aluminum alloy landing gear with sequenced gear doors to complete the scale appeal of this beautiful model.
    Fully Operational Bomb Doors
    The FlightLine B-25J Mitchell takes it to the next level in scale detail with the fully functional, servo-driven bomb doors complete with 4 dummy "bombs" you can drop during flight.
    FlightLine Quality You've Come To Expect
    The B-25J Mitchell is the latest model from FlightLine, a world-leader in EPO foam warbirds so you can expect a world-class quality model from nose to tail.
    Digital Servos Throughout
    The B-25J Mitchell employs digital servos throughout the model ranging in plastic, hybrid and metal gear, the latter used on all critical control surfaces like aileron and elevator.
    Counter-Rotating Props
    Counter-rotating propellers provide tracking stability, helping to cancel out the left torque tendencies of many a warbird, keeping your B-25 tracking straight and true down the runway.
    Movable Turrets
    It's just not a B-25 without turrets that can swivel to face those pesky axis fighters. The flightLine B-25 is no different, allowing you to angle your turrets any direction you desire.
    Fully Loaded with LEDs
    The B-25 comes with LED lights throughout adding to the impressive presence of the model. Clearly visible in both day and dusk conditions, the lights not only add scale appeal but practical visual reference in the sky.
    Features:
    • Servo-driven, fully operational bomb doors with 4 dummy "bombs" for deployment
    • 3 Different decal sets (Heavenly Body, Executive Sweet and Mitch The Witch) to choose from with the stars and bars pre-applied out of the box
    • Scale CNC-machined aluminum alloy landing gear with sequenced gear doors
    • Quick-release wings that do not require any screws for effortless transport
    • 15 Digital servos throughout including plastic, hybrid and metal gear
    • New 2023 structural and spatial design conception exclusively from FlightLine
    • Flaps, two pilots, 3-blade propellers, LED lights, antennas and armament complete the scale appeal
    Includes:
    • FlightLine B-25J Mitchell 1600mm (63") Wingspan - PNP
    • 2 Motors, 2 50A ESCs, 15 servos, LED lights, and retracts all pre-installed
    • Instruction manual
    • 4 Dummy "bombs"
    • 3 Decal sets
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :2 hours
    Model Scale 1/13
    Wingspan 1600mm / 63in
    Length 1280mm / 50.39in
    Empty Weight 3050g / 107.58oz (w/o battery)
    CG (Center of Gravity) 82mm (3.22") from the leading edge of the wing at the root
    Power System 2x 6S 3748-450Kv Brushless Outrunner Motors
    Electronic Speed Control 2x 50A, 7A BEC with EC5 Connectors
    Propeller / EDF 2x 12x7 3-Blade Propellers (Normal and reverse)
    Servos
    • 9g digital plastic gear standard with 100mm lead : right inside flap - MD31091-100
    • 9g digital plastic gear reverse with 100mm lead : left inside flap - MD31091R-100
    • 9g digital hybrid gear standard with 200mm lead : left outside flap, right outside flap - MD31093-200
    • 9g digital plastic gear standard with 300mm lead : left gear door, right gear door, bomb door - MD31091-300
    • 17g digital metal gear standard with 300mm lead : left aileron, right aileron, left elevator - MD31172-300
    • 17g digital metal gear reverse with 300mm lead : right elevator - MD31172R-300
    • 9g digital plastic gear standard with 500mm lead : nose cabin door - MD31091-500
    • 9g digital hybrid gear standard with 500mm lead : nose gear - MD31093-500
    • 9g digital hybrid gear standard with 600mm lead : left rudder, right rudder - MD31093-600
    Landing Gear Electronic retractable CNC aluminum alloy tri gear
    Required Battery 6S 22.2V 5000-5500mAh LiPo with EC5 connector (required)
    Required Radio 6 Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Yes
    Hinge Type Nylon Reinforced
    Material EPO Foam
    Skill Level Intermediate
    Build Time 2 Hours
    • 8207
      • Nov 2013
      • 2676
      • Cody, WY
      Originally posted by Aros
      This will be the official thread for an exciting long awaited new release from FlightLine! Announcement coming SOON! Stand by....
      Oh, goodie, goodie, goodie!!
      • SanExup
        • 912
        • Western Wy.
        B25! Awesome! Not an E2 Hawkeye, but oh well, just another cool plane to fly!
        • Flyhigh04
          • 9
          My attention is is peeking very much. A new release,now I’m excited.can’t wait to see what it is!!!!
            • 8207
            I'll update this thread in the morning. Beautiful new B-25 from FlightLine! Sign me up!
            • borntoolate
              Bomber Bob
              • Mar 2013
              • 424
              • California
              Finally!!! Ordered!!!
              borntoolate
              • f4u ausie
                • 1232
                • Melbourne
                Wanted a zeek but doolittle will be happy... finally 1600 fline... great subject matter,, what a story(none better) 1600 goes in ya car( truck)
                • Mikester
                  • Jul 2019
                  • 3
                  • Oklahoma
                  Outstanding ! I just placed my order. 😁
                    • 4823
                    F4u, Yeah, me too, though this will do nicely.
                    ?1600mm? Not a big girl, but not petite either.
                    Order's in with a July delivery! Wow!
                    Lookin' forward to flying this one.
                    Now what livery?
                    Best, LB
                    • DelRay
                      • Jun 2023
                      Just ordered the B-25, I've been wanting one for a long time, couldn't resist this one.
                      • ridgerunner
                        • Nov 2017
                        • 275
                        • Central Utah, USA
                        This is hands-down my favorite plane in RealFlight.
                        Mmmmm.... To order or not to order? (kinda spendy)
                        • Drdoom
                          • Jun 2023
                          • 5
                          • Aircraft Owner 1977 Cessna 177B Cardinal.
                          Got mine on order. My father was the radio operator on the B-25 in Germany during WWII. His Brother flew 25 missions as PIC in the B-25 in WWII. I am excited.
                            • 4823
                            ridgerunner this will be a 'must have' for many years to come. Just my $00.02 USD. If not now, then I figure she goes on your Wish List. Best, LB
                              • 8207
                              I won't lie, I was hoping it would be a 2000mm as I loved the size of the BH B-25. But alas, a 1600mm is still a nice size and easier to transport, and I love the easy on/off wings! I've always loved the B-25, such a beautiful twin bomber. I'll definitely be snagging one down the road!
                                • 5388
                                I agree. I ordered it first thing this morning but for a bomber I would have wanted it bigger. If a P-51 1600 would be perfect.
                                  • 4823
                                  Aros Happy to have a new Flightline Warbird!
                                  ... and there appears to be no Dihedral issues from the flight video.
                                  Best, LB
                                    • 8207
                                      • 5388
                                      Ohh… had to go there did ya!
                                        • 8207
                                        Laugh it up fuzzballs!!
