    LucB, Both a Congratulation and a condolence are in order here ti would appear. Glad to read you're rebuilding her. Nicely done on the "Top Score". Best of luck, LB
  • LucB
    I'm competing in our Belgian F4H (World Air Sports Federation aka 'FAI' flying scale model aircraft) championship with the B-25. After a top score for the first flight despite a "too fast' comment from the jury, for the second I tried to be more scale. Unfortunately, it was too slow for the bird and the take off did not end as expected... :disappointed:
    However the jury found the take off very scale this time.
    So a new bird and spare part (mid wing section) were ordered and delivered. The nacelle and fuselage, I'll try to repair them and convert the B-25 with the 3D gunship nose version because the front of the fuselage is not symmetric anymore. This will become my trainer. The new one will be my competition plane.
    Never give up!
    Regarding the CG and weight, mine is with recommended CG and 4.170 Kg, I'm using the Admiral 5000 (730 gr) batteries and I need a bit of extra weight in the front.
    I fly about 9 minutes and I have a bit more than 50% left in the battery.
    What I noticed after about 10 flights is the engines started to move in the nacelle one after the other... check your screws, they get loose!
  • BallinShark
    Hi, I'm installing new main gear doors after a crash, and I don't know where to insert the clevises and pin into the servo and gear door. The manual didn't really help me all that much. I would greatly appreciate it if someone could post a photo where both ends are inserted. Thank you so much.
  • tab28682
    Originally posted by Balsa Bob
    Using an Admiral 5000 6S. Battery placed all the way forward, landing gear down .... and plane is still a bit tail heavy. Are most people adding some nose weight ?
    Thanks. Bob
    Mine balanced correctly with a 6s 5000 lipo and no additional weight was needed. Note that different batteries have different weights and some aircraft might indeed need a little extra weight.
  • Balsa Bob
    Thanks. Bob
  • Wild Man
    Originally posted by Corsair24
    Nice first flight. Question what are everyone's opinion on the B25? Without me reading all the post are there any upgrades required out of the box?
    Have a great holiday.
    Keith
    No. there are no needed upgrades just assemble program and go fly. There is an assortment of different Liveries you can install or you can find many more at Callie Graphics for this B-25
  • Corsair24
    Keith
  • Wild Man
    Finnaly got some decent weather here in the Black Hills. So I loaded up my Flight Line B-25 and put the Test flight on it today. The B-25 First flight went trouble free and very little trim change She's a Keeper I went ahead and put 6 Flights on it. This first landing was not the greatest but I'll take it LOL!!! https://youtu.be/wIqxbg-tNFY
    commented on 's reply
    Yep, Test flight or first check flight are my preferred.
    Not certain why 'maiden' just doesn't quite fit for me, either.
    Respectfully, LB
  • Wild Man
    Not sure how to respond. I guess I retract my good luck wishes. Didn’t mean to offend you.
    No need to do that Sir. Thank you for your comment I hope I didn't offend you. I am just an old fart that just doesn't
    like that nomenclature been around full scale Pilot's to long LOL!!! I need to keep my Opinions to my self some times. I apologize to any one I may have Offended with my maiden comment
  • Wild Man
    Good luck with the maiden!
    You mean TEST FLIGHT I have heard of test pilots, but not maiden pilots, For some odd reason I just do not like that term. but that's me LOL!!!The Test Flight went off just fine. Now it's going to a friend of mine for the nose art and detailing. The man is an awesome artist with an Airbrush. In fact last year EAFB had him do the Art work on the tail of a B-1B for the Anniversary of the Doo Little Raiders. he is a retired Airman
  • Wild Man
    To many planes not enough time. I have had mine ready now for four week. and will have a 2hour window tomorrow morning to test fly it. I am flying mine with the Admiral 5100 carbon 70c batteries every thing programmed, plane balanced ready for the Wild blue
    Click image for larger version  Name:	8E97B101-4BDE-4604-8DF1-2E89ED005C3C.jpg Views:	0 Size:	189.5 KB ID:	403438
  • FlightlineB-25
    I'm new to flying RC planes. I have flown some small 2-foot wingspan planes before, but this is my first significant plane. I have a 12-acre field surrounded by trees, and I was wondering if that would be an adequate-sized area to take this plane. How much room do I need for this plane, and what is the service ceiling? Do I need to worry about this plane going higher than 400 ft? Also, I only have a rough gravel drive for a runway. Is that recommended, or should I find an AMA field with an asphalt runway?
    Charlee. Nicely done and Welcome to Hobby Squawk. Best, LB
  • Charlee
    8-gun and cannon nose conversion of a Wing Mfg kit.
  • borntoolate
    Originally posted by Cubcrafter60
    Very nice work Bob! My first choice would be a 498th aircraft but that falcon looks a little intimidating (painting wise), the 499th ship would be a very close second, and easiest of all (but still kind of interesting) would be the 501st ship.
    Robin
Name:	North American B-25J-11 Mitchell 014.jpg
    The painting was actually ptryy easy.
    The yellow and green are the paints. The other - the eye, mouth and diagonal jagged line ant tail are decals from Callie-graphics.On a scale of difficulty 1-10, this scheme ia about a 3.
    Mask off windows, spray the green uppers and grey lower sides, and apply decals.
  • Cubcrafter60
    Robin
  • borntoolate
    That's what I'm talking about! 😎 Is that the older FMS B-25? If so very nice job on the conversion! I was thinking about carving a one off nose from balsa or foam but after reading through the thread and seeing a lot folks saying that they're having to move their battery as far forward as possible, I was thinking a 3D printed or fiberglass nose might help (not trying to add 'dead' weight). I was excited to learn of Fast N Light's efforts as today a 3D printed nose would be more practical but I'm more familiar with the fiberglass route. I've been gathering all the info I can find on the 8-gun noses. I sure wouldn't have wanted to be on the PO'd end of 14 - (with the top turret swung forward) .50 cal. machine guns pointed my way!
    Yessir! This is the FMS B-25. It still has the masking on the cockpit windows in this pic. I vacuum formed the "J" solid nose and formed them out of abs. I also vac-formed the short "H" nose. I did the 498th scheme as well as the PBJ marine version solid nose. It was my first attempt to vac-form anything. I was pretty happy with the result.
    Bob
