  • rlcamden
    Received my B-25 last week. Had it together in about an hour. My club had our fall fly-in the past Saturday. It was a little cold and windy, but non the less, the plane handled it perfectly. The design and flight characteristics are excellent. Keep it up Flightline.
  • Fast N Light
    Anyone have the ESC calibration instructions? I didn't see anything on the Motion site. My 1st twin engine plane so I want to minimize the chances of messing up the beep, beep, beep...
    Did the basics: Tx on, 100% full throttle, motor on switch. Connect battery to ESC, beep beep, move throttle to 0%. Heard beep beep beep beep beep beep. Seems to be working OK.
  • Fast N Light
    Got started on my build and have the following updates on the scale rims. Thingiverse
    The OEM nose gear wheel measures 2.4inch and has very little radial clearance to the support strut. The Robart 2.5inch wheel measures ~2.64inch which results in interference with the support strut. I will evaluate the Robart 2.25inch wheel as a possible mitigation for this issue. Hope it fits without modification to the rim.
    Metal finish on the nose gear strut look pretty bad. Hope the metal structural integrity isn't compromised.
    The OEM main tires measure 3.33inch and the Robart 3.5inch measure ~3.53inch. The increased diameter can cause interference between the outboard gear door and the Robart tire. Moving the wheel inboard can address this issue. Removing the OEM 1.75mm aluminum spacer will create space for the outboard gear door to close. A ~1mm washer may replace the spacer with minor adjustment of the outer gear door push rod.
    The 3.5inch looks great but the fit to the gear door remains a close fit. I don't think the tires touch the doors on my setup. However, if you prefer more clearance, Robart 3.25inch should fit on the printed rims also.​
    PS - Thanks JD for the feedback!
    Click image for larger version  Name:	IMG_4060.jpg Views:	0 Size:	129.5 KB ID:	388181 Click image for larger version  Name:	IMG_4061.jpg Views:	0 Size:	101.7 KB ID:	388180 Click image for larger version  Name:	IMG_4062.jpg Views:	0 Size:	55.2 KB ID:	388179 Click image for larger version  Name:	IMG_4059.jpg Views:	0 Size:	70.0 KB ID:	388182
  • Jdcrow
    It is such a nice warbird. And thankfully as a bomber, it actually has that capability.
  • Fast N Light
    Look who showed up this evening....
  • desertdrifter7
    I have quite a bit more flaps in mine, 3/4 and 1 1/2” from memory. I have maybe 60 flights on mine that way.
    Evan, I saw your posting. That would be 19 and 38.1 mm respectively. I will give that a shot. Thank you.
  • desertdrifter7
    Have mercy. I must be brain dead. I reviewed the manual again and lo and behold, I found the flap settings. Completely missed them.
  • desertdrifter7
    Question: What are you guys using as flap settings. I am going to review the previous posts but I thought I would ask. If the flap settings are in the manual, I must have missed them. I saw the elevator mix suggestion in the manual.
  • desertdrifter7
    I put my plane together. Although the cardboard box was extremely damaged, not even a scratch on the plane itself. Everything was perfect thanks to the way MotionRC packs their planes for shipping. The plane itself went together even more easily than the videos demonstrated. The only challenge I had was getting the wing spars lined up. The wing takedown is marvelous. My spectrum receiver, that was a problem but that isn't MotionRC's concern. Got that squared away as well.
  • RCAZDES20
    Originally posted by Pboilermaker
    I finally received mine and the surfaces of -some- parts (especially the main fuselage) are definitely rougher than any of the online pictures or videos indicate they should be (foam appears somewhat more gatored, with large swaths of visible foam cells).
    Would excessive heat exposure during shipping cause these surfaces to become more pebbled?
    -Mike
    Possibly-maybe if it was packed on the top and/or sides of the intermodal container. Temps in the California holding yard for all them weeks was probably very warm-and very toasty inside the metal oven container unless it was staged inside a building or under cover all them weeks in the queue. I received my today and every part is in pristine condition true to MRC QC I've experienced in the past. MY only gripe for now is the cheap latching method used for the canopy. The retractable pin in the fuse just sticks into foam in the canopy. At this price point MRC should have provided a plastic reinforcement hard point to receive the pin. Yes, they did this also on the Bronco OV10 I have but its only a $400 plane.
    -Mike
    Mike, Welcome to Hobby Squawk, Sir.
    If you are able, post a few pictures of your issue.
    Uncertain about the heat explanation, as the whole box would have to 'heat soak' down to the paint finish.
    With all that 'foam and cardboard' inbetween, the airframe is well insulated.
    If there is a real issue, document it!
    Motion RC has great Customer Service.
    Best, LB
  • Pboilermaker
    -Mike
    I’d have that open so fast….
    is there any damage???
    Originally posted by desertdrifter7
    I received my B-25 today. When it was delivered the package looked like somebody had tried to skin it. I have notified Motion RC in the even I find damaged parts when I unbox it tomorrow. But I can tell you I wasn't a happy camper.
    Looks like Ace Ventura delivered it! Hopefully the interior is in good shape.
    Davegee
  • desertdrifter7
  • tab28682
    My B-25 is in the house!
    Originally posted by ajmillersr@aol.com
    Just delivered. Time to get to work
    AJ,
    Congrats and Welcome to Hobby Squawk, Sir.
    Might I suggest you change your User Name to something less personal.
    It is a private forum; however, it is open to the general public. Safety first.
    Best and glad to have you onboard,
    LB
  • ajmillersr@aol.com
  • rlcamden
    Originally posted by tab28682
    My B-25 is predicted to arrive tomorrow between 11am and 3pm.
    Same here. Just in time for our club's weekend fly-in.
