  • Once FedX gets it you’ll get a proper delivery date. What you have now is generated from the Motion computer.
    • Whoo hoo! Mine is destined to wait under the Xmas tree. DOH!
      • As I recall, something was said that there were spare parts in the shipment. Any idea when they will be available? Ready to order the plane, but would like to get a few parts along with it.
        • Originally posted by Waynec53 View Post
          B-25 parts are in this shipment. it will take a few days to unbox/count all the B-25 parts and put them away. As soon as that is done, we will put all the B-25 parts in stock.
          • My B-25 is predicted to arrive tomorrow between 11am and 3pm.
            • Originally posted by tab28682 View Post
              Same here. Just in time for our club's weekend fly-in.
              • Just delivered. Time to get to work
                • Originally posted by ajmillersr@aol.com View Post
                  AJ,
                  Congrats and Welcome to Hobby Squawk, Sir.
                  Might I suggest you change your User Name to something less personal.
                  It is a private forum; however, it is open to the general public. Safety first.
                  Best and glad to have you onboard,
                  LB
                  "Strive to thrive in uncertainty."
                  • My B-25 is in the house!
                    • I received my B-25 today. When it was delivered the package looked like somebody had tried to skin it. I have notified Motion RC in the even I find damaged parts when I unbox it tomorrow. But I can tell you I wasn't a happy camper.
                      • Originally posted by desertdrifter7 View Post
                        Looks like Ace Ventura delivered it! Hopefully the interior is in good shape.
                        Davegee
                        • I’d have that open so fast….
                          is there any damage???
                          • I finally received mine and the surfaces of -some- parts (especially the main fuselage) are definitely rougher than any of the online pictures or videos indicate they should be (foam appears somewhat more gatored, with large swaths of visible foam cells).
                            Would excessive heat exposure during shipping cause these surfaces to become more pebbled?
                            -Mike
                            • Originally posted by Pboilermaker View Post
                              -Mike
                              Mike, Welcome to Hobby Squawk, Sir.
                              If you are able, post a few pictures of your issue.
                              Uncertain about the heat explanation, as the whole box would have to 'heat soak' down to the paint finish.
                              With all that 'foam and cardboard' inbetween, the airframe is well insulated.
                              If there is a real issue, document it!
                              Motion RC has great Customer Service.
                              Best, LB
                                -Mike
                                Possibly-maybe if it was packed on the top and/or sides of the intermodal container. Temps in the California holding yard for all them weeks was probably very warm-and very toasty inside the metal oven container unless it was staged inside a building or under cover all them weeks in the queue. I received my today and every part is in pristine condition true to MRC QC I've experienced in the past. MY only gripe for now is the cheap latching method used for the canopy. The retractable pin in the fuse just sticks into foam in the canopy. At this price point MRC should have provided a plastic reinforcement hard point to receive the pin. Yes, they did this also on the Bronco OV10 I have but its only a $400 plane.
                                • I put my plane together. Although the cardboard box was extremely damaged, not even a scratch on the plane itself. Everything was perfect thanks to the way MotionRC packs their planes for shipping. The plane itself went together even more easily than the videos demonstrated. The only challenge I had was getting the wing spars lined up. The wing takedown is marvelous. My spectrum receiver, that was a problem but that isn't MotionRC's concern. Got that squared away as well.
                                  • Question: What are you guys using as flap settings. I am going to review the previous posts but I thought I would ask. If the flap settings are in the manual, I must have missed them. I saw the elevator mix suggestion in the manual.
                                    • Have mercy. I must be brain dead. I reviewed the manual again and lo and behold, I found the flap settings. Completely missed them.
                                      • I have quite a bit more flaps in mine, 3/4 and 1 1/2” from memory. I have maybe 60 flights on mine that way.
                                          Evan, I saw your posting. That would be 19 and 38.1 mm respectively. I will give that a shot. Thank you.
