Nose gear assembly help please. I crashed and need to replace. Diagram would be helpful. ThanksComment
AMA#116446Comment
AMA#116446Comment
LB I appreciate all of your posts and mods….if your opinion is the only real decision to be made is choosing the livery, well that’s good enough for me! I did just order the nomenclature decals from Callie. Not sure on my livery but looking forward to,the blue tape box!Comment
Jackcannon
You are too kind and I ordered those as well.
I have a 1/72 plastic model kit with the nomenclature layout I will PM you.
Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
Callie has a PDF with the nomenclature layout. She will email i to you upon request.LB I appreciate all of your posts and mods….if your opinion is the only real decision to be made is choosing the livery, well that’s good enough for me! I did just order the nomenclature decals from Callie. Not sure on my livery but looking forward to,the blue tape box!
Tip: air brush clear satin water based polyurethane on the nomenclature stickers to improve appearance.Comment
Trying to swap out the wheels with the du bro 3&1/4” (83mm) low bounce treaded wheels. Axel shaft is 5/32” (4mm). Problem is that after removing the grub screw from the bottom of the strut, I couldn’t remove the stock axel and wheel. I tried some gentle prying with a small flat head…nothing. Even tried tapping it with a center punch and small hammer… nothing. Anyone else run into this issue. TIAComment
Jackcannon
You might check that there isn't another 'grub screw' in the same location.
I have had retracts where 2 screws are used in the same hole.
Also, try using a little flame torch or similar to heat the aluminum strut.
AMA#116446Comment
Good point about two but the B-25 has just one. Heat is your best bet. If you are replacing the wheels just get a micro torch and heat the bottom leg up and tap out the axle. If you need to save the wheel it's harder and I usually use a soldering iron.Comment
Evan and Lb thank you for the tips. I just swapped out my Corsair wheels and axels but the retracts were already out. I hadn’t seen your tips yet so I went at it without heat… I really had to whack it hard with a hammer and punch to get it out. How rough are the landings with the stock wheels? Am I overthinking the importance of swapping the wheels?Comment
I think you are over-reacting with regards to the wheels. What is it about the stock wheels that make you want to change them? A few planes I've owned has a bounce problem on landing. This is not one of them. Totally stock, this is one of the best and smoothest landing aircraft of everything I fly. I and another club member got the HobbyKing Avios S. Tucano. I had it first and it was on my recommendation that he also get the S. Tucano. He was delighted with it and asked what plane he should get next that would fly and land as well as the S.T. I told him to get the B-25.Evan and Lb thank you for the tips. I just swapped out my Corsair wheels and axels but the retracts were already out. I hadn’t seen your tips yet so I went at it without heat… I really had to whack it hard with a hammer and punch to get it out. How rough are the landings with the stock wheels? Am I overthinking the importance of swapping the wheels?Comment
thank you viper I appreciate the input. The stock wheels are just so frickin hard. There’s no absorption there at all. Due to the difficulty of swapping out the axels, I think I’m just gonna fly it as is,I think you are over-reacting with regards to the wheels. What is it about the stock wheels that make you want to change them? A few planes I've owned has a bounce problem on landing. This is not one of them. Totally stock, this is one of the best and smoothest landing aircraft of everything I fly. I and another club member got the HobbyKing Avios S. Tucano. I had it first and it was on my recommendation that he also get the S. Tucano. He was delighted with it and asked what plane he should get next that would fly and land as well as the S.T. I told him to get the B-25.
Have you actually flown it yet and determined that the landing was not to your liking? Or was your decision to swap out the tires based solely on how hard the stock tires are? In this case, hard tires don't necessarily translate into bouncy landings. (Unlike the hard tires that come on the Eflite 1500mm P-51 Mustang which make for very bouncy landings and low bounce tires changes all of that.)Comment
I haven’t flown it yet but my concern is based on the hardness of the stock wheels, and the difference I experienced when I swapped out my 1600mm Corsair wheels. I followed Evans tip with the soldering iron to heat up the strut then punch out the axel. I got the du-bro soft bounce wheels on there and plan to maiden tomorrow.Have you actually flown it yet and determined that the landing was not to your liking? Or was your decision to swap out the tires based solely on how hard the stock tires are? In this case, hard tires don't necessarily translate into bouncy landings. (Unlike the hard tires that come on the Eflite 1500mm P-51 Mustang which make for very bouncy landings and low bounce tires changes all of that.)
got after it with the soldering iron and that did the trick! Definitely a very tight fit. Thanks for the tip!
