Excellent job designing those scale wheels for the B-25. It makes a big difference over the OEM wheels!
Hey all,
Assembling my B-25 and I had removed the 'ribbon' cables from the fuselage Blue Box prior to priming and painting.
Need to know if these cables are specifically Right Hand and Left Hand from the "Blue Box" to each wing/nacelle.
I would think not, as one can change the servo directions from the Tx, but thought I should ask.
Any assist would be greatly appreciated.
Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
Denniswpb
50CalBrowningBarrels_1.35mmd_1.5mmd.stl
These are the redesigns for my Desert Warrior build of the OEM barrels.
I presume that is what you are wanting.
There are 2 sizes 1.35mm diameter and 1.5mm diameter.
You can resize these in your slicer program and then cut to any length after printing.
Best, LB
hope everyone had a good Memorial day ..to much traffic in our area and di not go fly today. late day photos ..Glad i made the effort to repaint the b25 and finish the rescaled 3d printed 8x 50 cal removable gun nose the all the green ones are almost identical . not a completely easy conversion but very worth it as i never liked the clear nose b25s unless it was a air Apache field conversion
- Likes 2
Are you replacing all the nose guns with better 50 cal prints?Originally posted by Denniswpb View PostThanks LB I got the 50mm cannon for the nose, I need the side machine guns, but I can scale that down to make it work. Appreciate it..
Your model looks great! I like the silver and for me the gunship nose is the only way to go.Originally posted by vrosi1963 View Posthope everyone had a good Memorial day ..to much traffic in our area and di not go fly today. late day photos ..Glad i made the effort to repaint the b25 and finish the rescaled 3d printed 8x 50 cal removable gun nose the all the green ones are almost identical . not a completely easy conversion but very worth it as i never liked the clear nose b25s unless it was a air Apache field conversion
For mine I stayed with olive/grey and made a drop in 3D printed nose. Replaced the 50 cal barrels all around including Browning M2 full bodies for the turret. Rims for Robart tires are available on Thingiverse.
Yours looks great. I went with the stock rims and Dave Brown foams that completely cancel out any bounce on a paved runway., the silver keep the plane very cool in the California summer sun , green will bubble the skin . will print a set of the 3d rims soon but use foams glued to the rim possibly. haven't mad a huge effort to detail the b-25 yetOriginally posted by Fast N Light View Post
F&L,Originally posted by Fast N Light View Post
For mine I stayed with olive/grey and made a drop in 3D printed nose. Replaced the 50 cal barrels all around including Browning M2 full bodies for the turret. Rims for ]
Great mods and perfectly executed per usual.
I need some assistance...I just assembled my Flightline B-25J last night following Wesley's video...and it went very well! He addressed needing a 7 channel receiver if using the bomb bay. Something that wasn't addressed is on each of my throttle wires, there is also a reverse brake connection. I assume they also connect to a Y cable, but I'm not sure where to plug it into the receiver. I have a Spektrum NX8+ transmitter, and do I just choose a switch for the brake or does it connect to the throttle somehow?
"Y" the 2 plugs together, knowing that the single wire on each is a "signal" wire (disregard the color). Plug that into an empty channel and then assign a switch to that channel. On your NX8, go for ch.8. I assign the long toggle on the right. It's a 3-way but just don't stop in the middle. Test to make sure both motors reverse together and at the same time.Originally posted by Craterman View PostI need some assistance...I just assembled my Flightline B-25J last night following Wesley's video...and it went very well! He addressed needing a 7 channel receiver if using the bomb bay. Something that wasn't addressed is on each of my throttle wires, there is also a reverse brake connection. I assume they also connect to a Y cable, but I'm not sure where to plug it into the receiver. I have a Spektrum NX8+ transmitter, and do I just choose a switch for the brake or does it connect to the throttle somehow?
Thanks It came out even better than I expected. Callie did a fantastic job on my custom graphics.Originally posted by vrosi1963 View Post
I have used Dave Brown tires extensively and they are great! However, I recommend Robart for the B-25 based on appearance. The 3.5" main wheel has presence, taking away the toy look of the OEM wheel. Both DB & Robart perform well as low bounce. Robart has a bit more weight, but it will have better durability in the long run.The B-25 can carry another oz or two...
