    Absolutely stunning Dave great 👍 job congratulations on maiden
    I remember our collaboration on putting the larger prop on these FMS P-47s a few years ago. That has been a wonderful mod, my flights with them you just have to be a bit careful not to scrape the prop tips on takeoffs or landings. Not too hard to do, but you have to be careful. But it sure Looks great with a more scale prop on it!
    Cheers
    davegee
    • Davegee,
      The photo's look fantastic. Your flight tests are a great help for those of us that are wanting to try the same thing. FMS should put you on their payroll for inovations.
      Best Regards, Rex
      • Originally posted by jetfool View Post
        Davegee,
        Best Regards, Rex
        Thanks, Rex. Since about 2000, study of the P-47 Thunderbolt has been a passion of mine. I enjoyed the challenge of converting this foamie, much thanks to James in California who did all the heavy lifting to make this conversion possible. I don't hold out much hope that FMS or any other company will make a model that will be acceptable to me as a bubbletop, but I haven't totally given up yet. And if that never happens in my lifetime, I'm happy I have this one completed and flyable.
        Cheers
        Dave
        • Looks amazing Dave!
          She flew as well as she looks I gather?
          Dan
            Looks amazing Dave!
            Dan
            Yes, the only thing I didn't care for is that the tailwheel turn left and right is too high and I'm not sure how to dampen that. It's wired into a control board in the fuse as is the rudder so they sorta work together but I don't have the ability that I know of to reduce that tailwheel throw. I get some fishtailing on the takeoff run close to liftoff, and on landings regardless of the rates setting, it is hard to just have a nice slowup and then put the tailwheel down softly and not have it sashay back and forth. I don't think my other jugs are like that.
            Would it help to increase exponential for the tailwheel for steering?
            Otherwise, it is a great flyer just like the others that I have had. Really a great design by FMS.
            Cheers
            Daee
            • What about reduced rudder throw sounds like U can't move the pushrod to the outer hole to reduce it... We have my first scale day at the club tomorrow. Will post pics on what did U fly. In the arvo
                I've never been able to really resolve this with these FMS P-47 airplanes. I do need quite a bit of rudder throw for takeoffs and landings, but for the straightaway takeoff and landing rollouts, it would be great to isolate the tailwheel to freeze it straightforward like the real ones do, and then "unlock" it at taxi speeds so I can use rudder and tailwheel to taxi on the ground. Right now, all my 8 channels are being used so I might try one of my other jugs to play with this with tailwheel control on a separate channel, or something.
                What would a higher expo on the rudder do for me, so I have to really crank the rudder stick to get a big movement on the rudder/tail wheel? It starts out fine on takeoff rollout or landing rollout, but then I seem to overcontrol it late in the takeoff or landing roll and it sashays left and right instead of just going straight. I'm sure there is a solution somewehere, I just have not figured it out yet for this airpalne.
                By all means, please share pics of your flying meet so we can see what all you guys are flying!
                Cheers
                Davegee
                • By your description. Simply more expo just may help.
                    I'll play around with that. I did bump up the expo some as an experiment, but didn't really dig into it more than that. I need to do some trials going up and down the runway at various expo settings. Maybe something will materialize. Thanks for your input!
                    Cheers
                    davegee
                    • Originally posted by davegee View Post
                      Here is another attempt to play my recording of the working canopy for my P-47D Hairless Joe. Here is the link below:
                      https://youtu.be/VpGkmjsVCqo​
                      Very cool Dave glad to see some one has some persistence and not just being happy with a stock Cooke cutter boring arf like the majority of the population. A++++++++++++++
                      • Yeeeaa. It works the vid and the sliding canopy
                        • Originally posted by vrosi1963 View Post
                          Thanks, James. Most of my models now that I come to think of it are modifications of something sold off the rack by one of the major rc companies. For my EFlite 1.5M P-51D, I carefully sliced off the foam fillet that runs from the fuselage to the vertical fin as this part did not come in the first batches of NA P-51D models from the USA. It was a bit risky doing this but it worked out great and the airplane flew great even without this part. It is painted up as LOU IV/ATHELENE, flown by 361st FG commander Col. TJJ Christian, Jr. in WWII. The stock paint job from the manufacturer roughly imitated a modern day version of this airplane, but is just a fanciful paintjob of something that never was in real life, at least in WWII. I tried to make my model look as close as possible to Christian's airplane in the summer of 1944.
                          Click image for larger version  Name:	IMG-0567.jpg Views:	0 Size:	151.9 KB ID:	448421 Click image for larger version  Name:	IMG-0570.jpg Views:	0 Size:	238.3 KB ID:	448422
                          • With the new Fliteline P51, the vertical stab is a separate piece like the FMS 1450 P51D. It should be a much simpler process with nowhere near the risk.
                            As someone who has seen Dave's work up close and personal, pics do not do them justice.
                            (Dangerous Dan)
                            • The advantage to living in Cody is that I can see all of Dave's creations in real time.
                              Up to his house today and checked out Hairless Joe. If you think the pics are good, the real thing is overwelming!
                              Click image for larger version  Name:	20260511_150933.jpg Views:	0 Size:	116.3 KB ID:	448517
                              Put in a pic with the right back drop and in black and white and you would swear it was a WWII period picture. Might be an idea to get the pic that Dave worked with and reproduce the angle. Something like this...
ID:	448518 Click image for larger version
                              (Dangerous Dan)
                              • Not sure on how it's done, but was it Rex' or Steve's wife that did something like that?
                                I'll have to look it up and see how.
                                Dan
                                • My attempt from my iPhone with Dave’s bubbletop, can’t say it’s great but I can try with my own Thunderbolt later in the future. If the shot was taken closer to the ground, it would definitely help. Click image for larger version
                                    • Thanks for doing that, Eagle15. I think it looks better in color than black and white somehow. The demarcations between the colors is pretty stark in b&w than when I look at it in my house or at the field. But very cool you made those pics and I thank you!
                                      davegee
                                      • I got 10 flights in on my Penrod and Sam yesterday. I was trying out some new Expo settings to try and reduce the tailwheel movement mainly on takeoff and landing rollout runs. Overall it went pretty well, although a few times I lost control of it near the end of the landing rollout and it went off the side of the runway sliightly. I was satisfied with most all the takeoffs that I did. Nothing damaged this time. Also did one drop tank release, worked great, as usual. Ended the morning with a flight of my FMS F-86F, one of my favorite jets. I hope to do some more tests maybe tomorrow morning, if the winds die down.
                                        Click image for larger version  Name:	IMG_3083.jpg Views:	0 Size:	82.2 KB ID:	448583
                                        • You might try dialing down the rate on your rudder as well, something like 80% is plenty for the scale like flying you're into. Too much expo and it starts acting like a wet noodle, I don't go over 30%.
                                          Also, is the control rod in the outermost hole? You can get more rudder with it in the outer hole on both the control arm and the servo control arm, that way, you can turn down the rate and not lose much control throw if you feel you need it. Personally, I use rudder for takeoffs and when in flight, to counteract adverse yaw. When landing, especially with narrow gear such as the Spitfire, I always keep the prop spinning to stop that pull to one side. As you know, you have to be on the ball when it comes to those last few feet of landing, adding too much expo will increase the amount of throw you have to apply before the rudder reacts.
                                          Dan
