  • jetfool
    • Nov 2022
    • 1282
    • Crawfordsville, Indiana
    Davegee,
    Great to know the bomb drop works. Will install one for flying this season.
    Yes, I'm getting excited. The P-47 is finished and sitting on our dining table until we leave, wife is very encouraging but now I have to run the vacuum every week in the house. Things we put up with to enjoy our hobby.
    Working on the docs book and getting all the little things in my toolbox to take just in case I need to repair, clean at the show. Our motel room at the convention has been made. Helped my buddy spray his clear coat on his Jenny so we are almost ready. Still moving on the Phantom but slowly.
    Best Regards, Rex
      • 4827
      Originally posted by jetfool
      ......wife is very encouraging but now I have to run the vacuum every week in the house
      Hah
      Tamms gave me an Official Patch.
      Best, LB
      • vrosi1963
        Hobby Squawk Pilot
        • Aug 2016
        • 71
        • Califorina
        The canopy plug is nearing completion ,way more print grain that the 1.2m for some reason and sanding and polishing with mothers mag polish .will post a pic before it goes to parkflyer plastics vac people next week.
          • Nov 2013
          • 2681
          • Cody, WY
          Thanks.
          davegee
            • Nov 2013
            • 2681
            • Cody, WY
            Working on the sway braces for the belly tank. These are scratchbuilt aluminum tubes and can accommodate this foam scale 108 gal. drop tank and eventually a new and unique printed rectangular steel drop tank that was also used commonly during this period in 1944. On a previous post I added an actual pic of Hairless Joe on the hardstand with one of these attached, taken at Boxted Air Base in Essex, England. Both of these type drop tanks should easily survive dropping during demonstration flights later this summer.
            Click image for larger version  Name:	IMG_3504 (1).jpg Views:	0 Size:	108.7 KB ID:	446044
            • jetfool
              • Nov 2022
              • 1282
              Good job!
                • Nov 2013
                • 2681
                • Cody, WY
                Good job!
                Thanks, that should dampen out any undesirable movement in the air stream until it is released from the EFlite bomb/tank drop. My team scale partner back in the day just HATED droppables, but I loved and still love them. On our blue camo Fire Ball that you saw in Florida, we did drop that very large scale 215 gal. tank (over 16 inches long in1/6 scale) in a very realistic manner and looked spectacular as it tumbled down end-over-end to the ground, always undamaged. It was the same one that you would have seen mounted on the plane in its display case in Titusville.
                Cheers
                davegee
                • jetfool
                  • Nov 2022
                  • 1282
                  Davegee,
                  Your P-47 in Florida is a masterpiece. I remember the tank on it. I took lots of pictures that day of it to use some of your ideas on my Yellow P-47 when I got home. Keep thinking about a P-47M and after yours is completed I may order the conversion parts to have on hand for a later build. Dave Platt rule #7 (Scarfology) Get it while you can.
                  Glad I'm just taking one model to Toledo; I have been adding the engine parts like yours and every time I look at it I see more little things. Same with the Phantom so will take my time on it. Talked to the event director about the static rules (same as AMA) and he said they are adding cash prizes this year in hopes to entice more entrants. I know of 4 guys going so the competition should be pretty tough this year.
                  Best Regards, Rex
                  • jetfool
                    • Nov 2022
                    • 1282
                    Added the back cylinders to the engine and making up the ingnition harness and wiring. Need to paint before assembly. Think it will look ok when installed.
                    Best Regards, Rex
                      • Nov 2013
                      • 2681
                      • Cody, WY
                      Best Regards, Rex
                      Click image for larger version  Name:	IMG_4146.jpg Views:	11 Size:	94.4 KB ID:	446059
                      Click image for larger version  Name:	IMG_4147.jpg Views:	7 Size:	96.3 KB ID:	446060
                      Thanks, Rex. The last time I flew Fire Ball was in 2008 at the US Scale Masters Contest in Sarasota, FL. We were cruising to a first place finish in our division, Team Scale, and then Disaster Struck! We could get through most of our routine, and then the motor would thin out and quit. It became a nail-biting conclusion to see if it would crack up or not. We got all our required maneuvers in, or most of them, but we just couldn't figure out why the motor was doing that, a DA 50. On one of the rounds, Bob, the pilot, landed a little short with a dead engine, and it hit hard, tearing at least one main gear out of the airplane. Not to be deterred, I worked all night in my hotel room with Fire Ball to get it flyable again. In the end, we dropped from a sure first place prize to fourth place, but we still got a trophy. On that last flight, the engine quit again, and the whole crowd yelled in unison: "GO FIRE BALL, GO !!!!" It was touching.That last flight, Bob brought it down for a perfect dead stick landing with no additional damage.
                      I took it home and did a proper repair after that. I gave the DA 50 to Bob to take to the manufacturer to see why it did that. When the airplane was restored, that's when I made arrangements to take it to Florida to the museum where you saw it.
                      That drop tank was rare, and special. It was a scale 215 gallon "flat" tank of the type used by the 56th FG on their M models in the last months of the war in Europe. It was released on each of our flights as part of the routine we did for the competitions around the country. On the real airplane, they were able to get to Germany and back with that tank on, as they had gotten orders to remove the wing pylons. They all breathed a sigh of relief when they got that order, as that now meant no more low level attacks, which were considered much more hazardous than high altitude fighting or bomber support missions.
                      Your engine cowl looks great, and I would hazard no one else will have such scratchbuilt details on their entries.
                      When are you leaving for Toledo?
                      Best of Luck!!!
                      Cheers
                      Dave
                      • jetfool
                        • Nov 2022
                        • 1282
                        Thanks Dave,
                        We are leaving for Toledo early Friday morning (3 am) April 10, about a 4 hr drive from our town. Have the room at the convention center reserved for Friday night. Hotel costs are crazy.
                        Best Regards, Rex
                          • 7337
                          Finally felt well enough to do some work on Schilling....
ID:	446079 Click image for larger version
                          (Dangerous Dan)
                            • 7337
                            Whipped out the Canon, better pics.
ID:	446084 Click image for larger version
ID:	446085 Click image for larger version
                            Obviously not done yet, but maybe 80%??
                            (Dangerous Dan)
                              • Nov 2013
                              • 2681
                              • Cody, WY
                              (Dangerous Dan)
                              Looking great, Dan!! I have the oxygen mask ready to install hanging from his helmet to finish it off for display when you're finally finished with it. No rush, still a lot of work to do on the fuse, especially cockpit and canopy when it comes, hopefully soon!.
                              Cheers
                              Davegee
                              • jetfool
                                • Nov 2022
                                • 1282
                                Outstanding work Dan. He should look great in Daves new Bubble Top P-47. Bobs says to tell the guys hello as he will be traveling on Republic Aviation business to upper Ohio for a convention shortly..
                                Best Regards, Rex
                                  • 7337
                                  Great to hear Rex, Dave and I are really excited to see how you make out. Take lots of pics!!
                                  (Dangerous Dan)
                                  • jetfool
                                    • Nov 2022
                                    • 1282
                                    Grossman,
                                    Plan to take my computer so I can post while at the show. Cash prizes this year so the competition should be pretty tough. Not worried about placing just enjoy the people and seeing what's new in the hobby. You guys helping makes it feel like a team entry Wish you guys could go.
                                    Best Regards, Rex
                                      • Nov 2013
                                      • 2681
                                      • Cody, WY
                                      Grossman,
                                      Best Regards, Rex
                                      We're all very proud of you for taking the effort to compete in this event, Rex. Best of luck, but probably more importantly, have a great time!
                                      Cheers
                                      Dave
                                      • jetfool
                                        • Nov 2022
                                        • 1282
                                        Work in process. Beginning to fit the wires and find tweezers and magnifier hood makes it easier to put these small pieces together. After 2 hrs. plus I had to take a break or go nuts. Still need to install the harness and wires for the top cylinders. Rex
                                          • Nov 2013
                                          • 2681
                                          • Cody, WY
                                          Coming along Great, Rex. I know that is tedious business doing this, but the results are good. It is complicated by the way the cowl/engine is molded making the upper parts more difficult to impossible to improve. But at least the lower parts of the engine will be very viewable, and the fact that you have a big fat prop in front of it reduce the amount of scrutiny the viewer can give to it! I think I and probably Danger Dan, too, also feel doing a little detailing to the round engine parts is well worth it, especially for contests like Toledo.
                                          The R2800 is one of my all-time favorite radial engines during WWII and afterwards. My favorite three warbirds all used the R2800: the P-47, Corsair, and F6F Hellcat. And they saw their way into many postwar aircraft like the DC-6, Convair 240-440 series, Martin, and many others.
                                          Cheers
                                          davegee
