There is nothing 100%, as in life too............but if your reasonably prudent you try to minimize your exposure. ;)
Flightline RC Tigercat F7F
HSD Skyraider FlightLine OV-10 FMS 1400: P-40B, P-51, F4U, F6F, T-28, P-40E, Pitts, 1700 F4U & F7F, FOX glider Freewing A-6, T-33, P-51 Dynam ME-262, Waco TF Giant P-47; ESM F7F-3 LX PBJ-1 EFL CZ T-28, C-150, 1500 P-51 & FW-190 -
I'm gonna have to go to lowes or home depot tomorrow, had some glue stick to my fingers and it pulled small bits of paint off. :(Comment
Naw just keeping with the stock paint. I just had an unfortunate incident with the CA and the wire track covers. The glue got on my fingers before I knew it and I pulled some paint off the bottom wing... really sucked.Comment
Oh, so you will be doing some paint work. LOLLOL"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
My 4000 4s packs just arrived and the test fit worked out to where no shaving was needed for the hatch, now to work out the cg! Woohoo! I'm stoked guys! WHOOA!Comment
Well I put my batteries as per the flight video with the 4000s where Ryan was setup. And I'm about 1/4 inch on the nose heavy side still, (checking with gear down) so 57mm. So now just trying ideas to get closer to where it needs to be hopefully without adding weight...Comment
57mm CG.................NO NO NO RiflemanWell I put my batteries as per the flight video with the 4000s where Ryan was setup. And I'm about 1/4 inch on the nose heavy side still, (checking with gear down) so 57mm. So now just trying ideas to get closer to where it needs to be hopefully without adding weight...
You CG aft swinging gear with gear up first of all, thus when it is down you will have a somewhat nose heavy condition which is OK.........a lot better than a tail heavy bird when retracted.
A picture is worth a 1000 words. This is where my flies rock solid.
Minor cuts needed to move the battery straps around, but I got it and the cg was on the same point yours was, right at 70mmComment
I set flaps @ 15 degrees for T/O and 30 degrees for Landing. Your gonna luv this bird RM.
I liked it's overall flight characteristics sooooo much that the jump into a giant scale twin for me was without a doubt the ESM 2110mm Tigercat.
I'll be starting a build thread on that in the not to distant weeks. ;)Warbird Charlie
She's like a high wing trainer to fly!
I went with Charlie's recommended flap settings and at half flap I have no elevator mix and a slight amount at full flaps. You can land without flaps if you have to, no biggie, but at 15 degrees its even easier to land, you can try full flaps and determine just how much elevator mix you want.
This is a dream plane to fly!!
Once you get into it, we'll let the modder come alive and the next thing you know you'll be yanking motors for more speed!!
Grossman56Team Gross!Comment
What size battery do you use in the tigercat? 5k? I ask because that's what I was using in my P38Comment
