Flightline RC Tigercat F7F
    • 7434
    Personally, I have a lot of 3600 PRO's so that's usually what I use, but I haven't a problem loading in the 4000's either.
      Indeed, I was wondering what fieldofdreamsflyer used as a single pack in this plane. I have the 4000s for mine with that parallel adapter. I am happy with the fitment as well. Just wouldn't think a single battery in this plane would balance without addition weight.
        • 7434
        Also, I put my new Admirals on a scale to compare them with the old, the new 4000's balance out lighter than the 3600 PRO's
        Take a look at the specs on the single battery and the two 4s that you would normally use. The weights will be in the specs, then you'll know what if any you would have to add.
          Yeah that's what I was thinking
          • fieldofdreamsflyer
            Banned
            • Jan 2013
            • 289
            4s 6000mah
              Nice, so still get generous flight time as well. I like it
                Banned
                • Jan 2013
                • 289
                I only fly for 5miin which is enough for me , and its mostly 3/4 power with a few fast flybys, but still have 40% left in the lipo
                My P-38 i used a single 4s 5500mah in it and was fine , When I get the B-24 it will be using a 3s 6000mah in it
                  Heck yeah brother, I like that!
                    So flew her today... the only negative I have to say is... there's never enough batteries! wow this thing is in the running for favorite plane neck to neck with the carbon z T28!
                    • Mad Baron
                      132 Aviation
                      • 547
                      • McMinnville Tn.
                      Well I've got the green light to get the Tigercat I just have to save up some cash to get it.:Sleepy:
                        It's a very awesome plane!
                          • 7434
                          Good move MB, you won't regret it, she's a gentle airplane, I love mine!!
                          • Mad Baron
                            132 Aviation
                            • 547
                            • McMinnville Tn.
                            When I do get the cash saved up I will have to get some more 4000s as well. Looking forward to getting this plane!
                              I got the nanotech 4000mah 25c and after 7mins they were still at 3.90volts per cell. And still cold like they were never run at all. For 36 a pop, a good deal
                                • 7434
                                The 3600's work great as well, that's what I usually go with.
                                  Indeed, just remember I am running mine with a parallel adaptor for safety reasons as well. You can't go wrong with either battery selection
                                  • Scamp73
                                    • 45
                                    • Autryville, NC
                                    Has anybody had to calibrate the ESC's to get them sync'd?
                                      Mine were on point from factory, but that doesn't mean every one will be. I still do the calibration flipflop before any maiden of any new plane I build.
                                      • Scamp73
                                        • 45
                                        • Autryville, NC
                                        Thanks, I could Alpha’s post on RCGroups for calibrating. All is good
                                          Right on, good deal!
